Hi. I was wondering if someone could help me with the following issue.
I've just installed Intel C++ compiler 11.1/059 on openSUSE 11.1 for x86_64. It appears that any program contaning the FD_ZERO macro with abort with an RTC failure if compiled in -debug -check-uninit mode. For example, put the following into a file called /tmp/foo.cpp:
#include
#include
#include
int main (int argc, char ** argv)
fd_set readfds;
FD_ZERO (&readfds);
return EXIT_SUCCESS;
Then compile it:
. /opt/intel/Compiler/11.1/059/bin/iccvars.sh intel64
icpc -debug -check-uninit -c -o foo.o foo.cpp
icpc -o foo foo.o.
Then run it and observe the crash:
$ /tmp/foo
Run-Time Check Failure: The variable '__d1' is being used without being initialized
Aborted
The '__d1' variable is used in the GLIBC's definition of the FD_ZERO macro in /usr/include/bits/select.h:
# if __WORDSIZE == 64
# define __FD_ZERO_STOS "stosq"
# define __FD_SET_BTS "btsq"
# define __FD_CLR_BTR "btrq"
# define __FD_ISSET_BT "btq"
# else
# endif
# define __FD_ZERO(fdsp) \
do {<><------><------><------><------><------><------><------><------> \
int __d0, __d1;<---><------><------><------><------><------><------> \
__asm__ __volatile__ ("cld; rep; " __FD_ZERO_STOS<-><------><------> \
<------><------><------> : "=c" (__d0), "=D" (__d1)<--><------><------> \
<------><------><------> : "a" (0), "0" (sizeof (fd_set)<-----><------> \
<------><------><------><------><------> / sizeof (__fd_mask)),<------> \
<------><------><------> "1" (&__FDS_BITS (fdsp)[0])><------><------> \
<------><------><------> : "memory");<><------><------><------><------> \
} while (0)
Any suggestions?
$ rpm -q gcc glibc
gcc-4.4-4.2.x86_64
glibc-2.10.1-10.4.x86_64
#include
#include
#include
fd_set readfds;
FD_ZERO (&readfds);
Then compile it:
icpc -o foo foo.o.
$ /tmp/foo
Aborted
# else
# endif
} while (0)
Any suggestions?
$ rpm -q gcc glibc
gcc-4.4-4.2.x86_64
Why not initialize it yourself, at least while using -check? Try several values to assure yourself the operation of your application doesn't depend on initial values.
Quoting - tim18
Hmm, I thought I was making sure my cross-platform application does not depend on initial values by using FD_ZERO in this particular case. Isn't the whole point of FD_ZERO macro is to provide a standard way to initialize an fd_set?
Same issue on Ubuntu 9.10 for x86_64. Seems like a generic problem that will occur on any system with a modern glibc (>= 2.10.x).
I can reproduce this in FC11 as well.
The compiler behaviour is correct. If you do not use -check-uninit compiler option then the compiler does not check for the uninitialized variables and the compiled binary runs.
Quoting - Om Sachan (Intel)
