Could someone please reply? Thank you
1>Compiling with Intel C++ 11.0.074 [Intel 64]... (Intel C++ Environment)
1>icl: error #10308: Failed to enable trusted storage check for licensing: WARNING: Enable Trusted Storage failed (flexnet error code 20). Trusted Storage based license could not be supported
The license file (.lic) is also sent by email.
Please save the .lic file tocommon filesintellicenses directory and set the env-var "INTEL_LICENSE_FILE=IntelLicenses".
Then install again.
Then install again.
