I ran into an issue when trying to compile the attached sample program with icpc (backend_signals.cpp)
Here is the information for the machine I was working on:Fedora release 8 (Werewolf) Kernel 2.6.23.1-42.fc8 on an x86_64
And here is the information about my version of icpc:> icpc -VIntel C++ Intel 64 Compiler XE for applications running on Intel 64,Version 12.1.3.293 Build 20120212
I have 4 different versions of gcc installed on my system: 3.4.6, 4.1.2, 4.3.6, and 4.6.0.I'm not completely aware of all the interactions that occur between gcc and icc, but thiscode sample does not compile with g++-3.4.6.
My commands:> icpc -c backend_signals.cpp[success]> icpc -g -c backend_signals.cpp(0): internal error: backend signals
compilation aborted for backend_signals.cpp (code 4)
The debug flag seems to be what triggers this internal error. I wasn't surewhere to post issues like this or if this was an issue with my code or withthe compiler itself. Please let me know what you think or redirect me tothe appropriate place to post this.
I was also wondering if there was some sort of documentation regardinghow icc interacts with versions of gcc (how does changing the availableversion of gcc affect the behavior of icc?). If there is no dependency, thenis there any relationship between the two?
Thank you (please let me know if you need any other information from me about this issue)
