Is it recomendable to recompile the dependent libraries of a project with ICC in order to gain performance improvement across all steps or doesn't this make any diffrence when i am compiling only the target project with ICC?
Viktor
Viktor
If (i) the code in the libraries gets pulled into the executable by the linker, (ii) the executable spends a significant fraction of its run time in the library code, and (iii) the library code is not already optimized: definitely yes.
Yes, it is the right thing to do. And icc is compatible with other compilers like gcc or VC, so it is supported as well.
Jennifer
Jennifer
Topic Options
