Intel® C++ Compiler
Recompile Libraries?
vrennert
Is it recomendable to recompile the dependent libraries of a project with ICC in order to gain performance improvement across all steps or doesn't this make any diffrence when i am compiling only the target project with ICC?
Viktor
mecej4
If (i) the code in the libraries gets pulled into the executable by the linker, (ii) the executable spends a significant fraction of its run time in the library code, and (iii) the library code is not already optimized: definitely yes.
JenniferJ
Yes, it is the right thing to do. And icc is compatible with other compilers like gcc or VC, so it is supported as well.
Jennifer
