Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Redistribute library from the compiler
Jump to solution
I found a similar post https://community.intel.com/t5/Intel-C-Compiler/redistribute-intel-libraries/m-p/856628 years ago and did not see the right answer on that post either.
One thing to figure out is the library come with intel c++ compiler, as it is a required library to run our application, so the question is how to make it with commercial use.
Can we pack them (e.g. libiomp5md.dll, libmmd.dll...etc.) with our application and do a release in public? Or we need to ask customer download redistributable packages from https://software.intel.com/content/www/us/en/develop/articles/redistributable-libraries-for-intel-c-...  by themsleves.
Thanks in advance.
Accepted Solutions
Highlighted
You can ship Intel Libraries which require to run your applications with your products.
Highlighted
I'm not quite sure of the procedure involved with respect to commercial usage of an application. I will forward this query to the concerned team, who will be able to help you better in this regard.
Rahul
Highlighted
Thanks Rahul.
Highlighted
