I am trying to compile hdf-4.2.11 for rhel 6; i have compiled required dependencies for hdf like zlib jpeg and szip using icc & ifort;
The configure script of HDF4 ran successfully ,
CC=$CCOMP F77=$FCOMP CXX=$CXXCOMP ./configure --prefix=$ROOT_DIR/hdf4 --with-zlib=$ROOT_DIR/zlib --with-jpeg=$ROOT_DIR/jpeg --with-szlib=$ROOT_DIR/szip
The configure log is :
CC=$CCOMP F77=$FCOMP CXX=$CXXCOMP ./configure --prefix=$ROOT_DIR/hdf4 --with-zlib=$ROOT_DIR/zlib --with-jpeg=$ROOT_DIR/jpeg --with-szlib=$ROOT_DIR/szip checking for a BSD-compatible install... /usr/bin/install -c checking whether build environment is sane... yes /home/puneet/hdf-4.2.11/bin/missing: Unknown `--is-lightweight' option Try `/home/puneet/hdf-4.2.11/bin/missing --help' for more information configure: WARNING: 'missing' script is too old or missing checking for a thread-safe mkdir -p... /bin/mkdir -p checking for gawk... gawk checking whether make sets $(MAKE)... yes checking whether make supports nested variables... yes checking whether to enable maintainer-specific portions of Makefiles... no checking shell variables initial values... done checking build system type... x86_64-unknown-linux-gnu checking host system type... x86_64-unknown-linux-gnu checking if basename works... yes checking if xargs works... yes checking for config x86_64-unknown-linux-gnu... no checking for config x86_64-unknown-linux-gnu... no checking for config unknown-linux-gnu... no checking for config unknown-linux-gnu... no checking for config x86_64-linux-gnu... no checking for config x86_64-linux-gnu... no checking for config x86_64-unknown... no checking for config linux-gnu... found Intel(R) Fortran Intel(R) 64 Compiler XE for applications running on Intel(R) 64, Version 15.0.0.090 Build 20140723 Copyright (C) 1985-2014 Intel Corporation. All rights reserved. checking whether make sets $(MAKE)... (cached) yes checking for gcc... icc checking whether the C compiler works... yes checking for C compiler default output file name... a.out checking for suffix of executables... checking whether we are cross compiling... no checking for suffix of object files... o checking whether we are using the GNU C compiler... yes checking whether icc accepts -g... yes checking for icc option to accept ISO C89... none needed checking whether icc understands -c and -o together... yes checking for style of include used by make... GNU checking dependency style of icc... gcc3 checking how to run the C preprocessor... icc -E checking whether we are using the GNU C++ compiler... yes checking whether icpc accepts -g... yes checking dependency style of icpc... gcc3 checking whether we are using the GNU Fortran 77 compiler... no checking whether ifort accepts -g... yes checking how to get verbose linking output from ifort... -v checking for Fortran 77 libraries of ifort... -L/opt/intel/composer_xe_2015.0.090/compiler/lib/intel64 -L/opt/intel/composer_xe_2015.0.090/mkl/lib/intel64 -L/opt/intel/composer_xe_2015.0.090/ipp/../compiler/lib/intel64 -L/opt/intel/composer_xe_2015.0.090/ipp/lib/intel64 -L/opt/intel/composer_xe_2015.0.090/tbb/lib/intel64/gcc4.4 -L/usr/lib/gcc/x86_64-redhat-linux/4.4.7/ -L/usr/lib/gcc/x86_64-redhat-linux/4.4.7/../../../../lib64 -L/usr/lib/gcc/x86_64-redhat-linux/4.4.7/../../../../lib64/ -L/lib/../lib64 -L/lib/../lib64/ -L/usr/lib/../lib64 -L/usr/lib/../lib64/ -L/opt/intel/composer_xe_2015.0.090/compiler/lib/intel64/ -L/opt/intel/composer_xe_2015.0.090/mkl/lib/intel64/ -L/opt/intel/composer_xe_2015.0.090/ipp/../compiler/lib/intel64/ -L/opt/intel/composer_xe_2015.0.090/ipp/lib/intel64/ -L/opt/intel/composer_xe_2015.0.090/tbb/lib/intel64/gcc4.4/ -L/usr/lib/gcc/x86_64-redhat-linux/4.4.7/../../../ -L/lib64 -L/lib/ -L/usr/lib64 -L/usr/lib -lifport -lifcore -limf -lsvml -lm -lipgo -lirc -lpthread -lirc_s -ldl checking for dummy main to link with Fortran 77 libraries... none checking for Fortran 77 name-mangling scheme... lower case, underscore, no extra underscore checking whether ln -s works... yes checking for ar... ar checking for bison... bison -y checking for flex... flex checking for diff... diff -w checking for makeinfo... makeinfo checking for neqn... neqn checking for tbl... tbl checking how to print strings... printf checking for a sed that does not truncate output... /bin/sed checking for grep that handles long lines and -e... /bin/grep checking for egrep... /bin/grep -E checking for fgrep... /bin/grep -F checking for ld used by icc... /usr/bin/ld checking if the linker (/usr/bin/ld) is GNU ld... yes checking for BSD- or MS-compatible name lister (nm)... /usr/bin/nm -B checking the name lister (/usr/bin/nm -B) interface... BSD nm checking the maximum length of command line arguments... 3458764513820540925 checking whether the shell understands some XSI constructs... yes checking whether the shell understands "+="... yes checking how to convert x86_64-unknown-linux-gnu file names to x86_64-unknown-linux-gnu format... func_convert_file_noop checking how to convert x86_64-unknown-linux-gnu file names to toolchain format... func_convert_file_noop checking for /usr/bin/ld option to reload object files... -r checking for objdump... objdump checking how to recognize dependent libraries... pass_all checking for dlltool... no checking how to associate runtime and link libraries... printf %s\n checking for archiver @FILE support... @ checking for strip... strip checking for ranlib... ranlib checking command to parse /usr/bin/nm -B output from icc object... ok checking for sysroot... no checking for mt... no checking if : is a manifest tool... no checking for ANSI C header files... yes checking for sys/types.h... yes checking for sys/stat.h... yes checking for stdlib.h... yes checking for string.h... yes checking for memory.h... yes checking for strings.h... yes checking for inttypes.h... yes checking for stdint.h... yes checking for unistd.h... yes checking for dlfcn.h... yes checking for objdir... .libs checking if icc supports -fno-rtti -fno-exceptions... yes checking for icc option to produce PIC... -fPIC -DPIC checking if icc PIC flag -fPIC -DPIC works... yes checking if icc static flag -static works... no checking if icc supports -c -o file.o... yes checking if icc supports -c -o file.o... (cached) yes checking whether the icc linker (/usr/bin/ld -m elf_x86_64) supports shared libraries... yes checking dynamic linker characteristics... GNU/Linux ld.so checking how to hardcode library paths into programs... immediate checking for shl_load... no checking for shl_load in -ldld... no checking for dlopen... yes checking whether a program can dlopen itself... yes checking whether a statically linked program can dlopen itself... yes checking whether stripping libraries is possible... yes checking if libtool supports shared libraries... yes checking whether to build shared libraries... no checking whether to build static libraries... yes checking how to run the C++ preprocessor... icpc -E checking for ld used by icpc... /usr/bin/ld -m elf_x86_64 checking if the linker (/usr/bin/ld -m elf_x86_64) is GNU ld... yes checking whether the icpc linker (/usr/bin/ld -m elf_x86_64) supports shared libraries... yes checking for icpc option to produce PIC... -fPIC -DPIC checking if icpc PIC flag -fPIC -DPIC works... yes checking if icpc static flag -static works... no checking if icpc supports -c -o file.o... yes checking if icpc supports -c -o file.o... (cached) yes checking whether the icpc linker (/usr/bin/ld -m elf_x86_64) supports shared libraries... yes checking dynamic linker characteristics... (cached) GNU/Linux ld.so checking how to hardcode library paths into programs... immediate checking if libtool supports shared libraries... yes checking whether to build shared libraries... no checking whether to build static libraries... yes checking for ifort option to produce PIC... -fPIC checking if ifort PIC flag -fPIC works... yes checking if ifort static flag -static works... no checking if ifort supports -c -o file.o... yes checking if ifort supports -c -o file.o... (cached) yes checking whether the ifort linker (/usr/bin/ld -m elf_x86_64) supports shared libraries... yes checking dynamic linker characteristics... (cached) GNU/Linux ld.so checking how to hardcode library paths into programs... immediate configure: creating ./config.lt config.lt: creating libtool checking if we should install only statically linked executables... no checking zlib.h usability... yes checking zlib.h presence... yes checking for zlib.h... yes checking for compress2 in -lz... yes checking for compress2... yes checking jpeglib.h usability... yes checking jpeglib.h presence... yes checking for jpeglib.h... yes checking for jpeg_start_decompress in -ljpeg... yes checking szlib.h usability... yes checking szlib.h presence... yes checking for szlib.h... yes checking for SZ_BufftoBuffCompress in -lsz... yes checking for szlib encoder... no checking for xdr library support... yes checking for ANSI C header files... (cached) yes checking whether icc and cc understand -c and -o together... yes checking how to run the C++ preprocessor... icpc -E checking whether ifort understands -c and -o together... yes checking size of int*... 0 checking whether byte ordering is bigendian... no checking for build mode... production checking for math library support... yes checking for fork... yes checking for system... yes checking for vfork... yes checking for wait... yes checking if deprecated public symbols are available... yes checking that generated files are newer than configure... done configure: creating ./config.status config.status: creating Makefile config.status: creating libhdf4.settings config.status: creating hdf/Makefile config.status: creating hdf/examples/Makefile config.status: creating hdf/fortran/Makefile config.status: creating hdf/fortran/examples/Makefile config.status: creating hdf/src/Makefile config.status: creating hdf/test/Makefile config.status: creating hdf/util/Makefile config.status: creating hdf/util/h4cc config.status: creating hdf/util/h4fc config.status: creating hdf/util/h4redeploy config.status: creating hdf/util/testutil.sh config.status: creating man/Makefile config.status: creating mfhdf/fortran/ftest.f config.status: creating mfhdf/fortran/jackets.c config.status: creating mfhdf/fortran/netcdf.inc config.status: creating mfhdf/libsrc/netcdf.h config.status: creating mfhdf/Makefile config.status: creating mfhdf/dumper/Makefile config.status: creating mfhdf/dumper/testhdp.sh config.status: creating mfhdf/examples/Makefile config.status: creating mfhdf/examples/testexamples.sh config.status: creating mfhdf/fortran/Makefile config.status: creating mfhdf/fortran/examples/Makefile config.status: creating mfhdf/fortran/testfortran.sh config.status: creating mfhdf/hdfimport/Makefile config.status: creating mfhdf/hdfimport/testutil.sh config.status: creating mfhdf/hdiff/Makefile config.status: creating mfhdf/hdiff/testhdiff.sh config.status: creating mfhdf/hrepack/Makefile config.status: creating mfhdf/hrepack/hrepack.sh config.status: creating mfhdf/hrepack/hrepack_all.sh config.status: creating mfhdf/libsrc/Makefile config.status: creating mfhdf/ncdump/Makefile config.status: creating mfhdf/ncdump/testncdump.sh config.status: creating mfhdf/ncgen/Makefile config.status: creating mfhdf/ncgen/testncgen.sh config.status: creating mfhdf/nctest/Makefile config.status: creating mfhdf/test/Makefile config.status: creating mfhdf/test/testmfhdf.sh config.status: creating mfhdf/xdr/Makefile config.status: creating hdf/src/h4config.h config.status: executing h4config commands modifying hdf/src/h4config.h Post process libhdf4.settings config.status: executing depfiles commands config.status: executing libtool commands SUMMARY OF THE HDF4 CONFIGURATION ================================= General Information: ------------------- HDF4 Version: 4.2.11 Configured on: Fri Apr 17 13:28:56 IST 2015 Configured by: puneet@shavakcuda Configure mode: production Host system: x86_64-unknown-linux-gnu Uname information: Linux shavakcuda 2.6.32-431.el6.x86_64 #1 SMP Fri Nov 22 03:15:09 UTC 2013 x86_64 x86_64 x86_64 GNU/Linux Libraries: Installation point: /home/puneet/hdf4 Compiling Options: ------------------ Compilation Mode: production C compiler: /opt/intel/composer_xe_2015.0.090/bin/intel64/icc ( Intel(R) C Intel(R) 64 Compiler Version 15.0.0.090 Build 20140723) CFLAGS: -O CPPFLAGS: -I/home/puneet/zlib/include -I/home/puneet/jpeg/include -I/home/puneet/szip/include -DSWAP Shared Libraries: no Static Libraries: yes Statically Linked Executables: no LDFLAGS: -L/home/puneet/zlib/lib -L/home/puneet/jpeg/lib -L/home/puneet/szip/lib Extra libraries: -lsz -ljpeg -lz Archiver: ar Ranlib: ranlib Languages: ---------- Fortran: yes Fortran Compiler: /opt/intel/composer_xe_2015.0.090/bin/intel64/ifort ( Intel(R) Fortran Intel(R) 64 Compiler Version 15.0.0.090 Build 20140723) FFLAGS: Features: --------- SZIP compression: enabled with decoder only Support for netCDF API 2.3.2: yes
but while make ing ; i am getting following error:
libtool: compile: icc -DHAVE_CONFIG_H -I. -I/home/puneet/zlib/include -I/home/puneet/jpeg/include -I/home/puneet/szip/include -DSWAP -O -MT dfcomp.lo -MD -MP -MF .deps/dfcomp.Tpo -c dfcomp.c -o dfcomp.o mv -f .deps/dfcomp.Tpo .deps/dfcomp.Plo /bin/sh ../../libtool --tag=CC --mode=compile icc -DHAVE_CONFIG_H -I. -I/home/puneet/zlib/include -I/home/puneet/jpeg/include -I/home/puneet/szip/include -DSWAP -O -MT dfconv.lo -MD -MP -MF .deps/dfconv.Tpo -c -o dfconv.lo dfconv.c libtool: compile: icc -DHAVE_CONFIG_H -I. -I/home/puneet/zlib/include -I/home/puneet/jpeg/include -I/home/puneet/szip/include -DSWAP -O -MT dfconv.lo -MD -MP -MF .deps/dfconv.Tpo -c dfconv.c -o dfconv.o ": internal error: ** segmentation violation signal raised ** Access violation or stack overflow. Please contact Support. compilation aborted for dfconv.c (code 4) make[3]: *** [dfconv.lo] Error 1 make[3]: Leaving directory `/home/puneet/hdf-4.2.11/hdf/src' make[2]: *** [all] Error 2 make[2]: Leaving directory `/home/puneet/hdf-4.2.11/hdf/src' make[1]: *** [all-recursive] Error 1 make[1]: Leaving directory `/home/puneet/hdf-4.2.11/hdf' make: *** [all-recursive] Error 1
earlier i had compiled hdf4 using gnu compilers successfully; so i guess intel compilers are at fault here;
eagerly awaiting you replies!
If that bug persists in a current icc update, it definitely should be reported. Preferable reporting would be on premier.intel.com, if your support account is working, or possibly by attaching the reproducer here.
i am using centos 6.5 as my development machine,
CXX_COMP=icc and F_COMP=ifort.
configure command:
LD_LIBRARY_PATH=$user1_install_path/Application_Dependencies/lib:$LD_LIBRARY_PATH CC=$C_COMP CFLAGS="-fPIC" LDFLAGS="-L$user1_install_path/Application_Dependencies/lib -lsz -lz -ljpeg" CPPFLAGS="-I$user1_install_path/Application_Dependencies/include" CXX="$CXX_COMP" CXXFLAGS="-fPIC" F77="$F_COMP" FFLAGS="-fPIC" ./configure --prefix=$user1_install_path/Application_Dependencies --with-zlib=$user1_install_path/Application_Dependencies/ --with-szlib=$user1_install_path/Application_Dependencies --with-jpeg=$user1_install_path/Application_Dependencies/ --enable-fortran --enable-netcdf
make
make install
Makefile is attached!
using this this error should be reproduced!
I don't have support account at present!
I am expecting a quick redressal of this problem , i even am ready to manually compile the dfconv.c file , please tell me the compiler flags !
i even tried:
icc -c dfconv.c
i have attached the dfconv.c !
-----------------------------------------------------------------UPDATE--------------------------------------------------------------------------
Thankyou , The same issue is posted here. v2015 update 3 fixed the compilation issue!
Hi Puneet,
Can you please attach a preprocessed file to this thread so we can investigate this further?
Kittur
Hi Puneet,
Please use the compiler option -E to generate the preprocessed version of the file.
Thanks and Regards
Anoop
