The following code with -w2
[cpp]struct Foo { unsigned char a, b, c, d; unsigned int intValue() const { return ((int)a << 24) | ((int)b << 16) | ((int)c << 8) | (int)d; } bool operator==(const Foo& rhs) const { // next line produces #981 return this->intValue() == rhs.intValue(); } }; [/cpp]
produces #981: operands are evaluated in unspecified order
Having done a search on #981, this remark would seem to be useless ... But before I simply add -wd981, I wondered if there was some optimization or some set of flags that you were intended to take into consideration?
I'm wary of just turning this warning off but since I can't figure out what the problem is, I'm having a hard time figuring how to fix some of these 981s aside from the laborious
[cpp]operator==(const Foo& rhs) { int myIntValue = this->intValue(); int rhsIntValue = rhs.intValue(); return myIntValue == rhsIntValue; }[/cpp]
(I'm guessing that there is some way to tell the compiler a function is entirely deterministic - that nothing is modified or changed by the calls,like the gcc 'pure' attribute, so that ordering is not relevant)
I checked with our other compiler experts too on this and this is what we have on icc:
ICCdoes recognize and process the "pure" attribute, much like GCC. Unfortunately, it matters only to the optimizer, and specifically, it doesn't affect the emission of #981. In C++, functions without side effects tend to be so common that our compiler developers recommend disabling #981 -- the noise-to-signal ratio is typically just too high. But for C code, #981 is more likely to be useful.
Hope the above helps. Let me know if you need any more info.
How can we disable it?
You can disable the remark with #pragma warning ( disable : 981 ) directive or in a VS project settings. Note: Take into account that some remarks can not be disabled due to some issues with Intel C++ compiler. I always try to use both ways to disable a warning or a remark.
Sergey, thanks for your reply:
Where could it be located within, say a source file?
Put the #pragma at the top of your file (or anywhere before the diagnostic is emitted).
Or just use the -Qdiag-disable:981 command line option.
I see you are on Linux -- in which case you can use the -diag-disable 981 command line option instead of a #pragma.
