Intel® C++ Compiler
Remarks without numbers
SergeyKostrov
Valued Contributor II
I detected a case when some Intel C++ compilerremarks are displayed without numbers. Please take a look on a generic form:
..\\.cpp(nnn): (col. 1) remark: ?@ has been targeted for automatic cpu dispatch.
Ascreenshot will be provided.
Here is a real example:
------ Build started: Project: IccTestApp, Configuration: Release Win32 ------
Compiling with Intel C++ Compiler XE 12.1.3.300 [IA-32]... (Intel C++ Environment)
icl: command line warning #10121: overriding '/EHs' with '/EHs-'
Stdphf.cpp
C:\\WorkEnv\\AppsWorkDev.R&D\\AppsSca\\ScaLib\\DataSet.cpp(132): (col. 1) remark: ?RunAlgorithm@CDataSet@@UAEEXZ has been targeted for automatic cpu dispatch.
C:\\WorkEnv\\AppsWorkDev.R&D\\AppsSca\\ScaLib\\MatrixSet.cpp(514): (col. 2) remark: ?MulHelper@?$TStrassenHBISet@M$02@@QAEXPAPAM00I@Z has been targeted for automatic cpu dispatch.
C:\\WorkEnv\\AppsWorkDev.R&D\\AppsSca\\ScaLib\\MatrixSet.cpp(612): (col. 2) remark: ?Add@?$TStrassenHBISet@M$02@@QAEXPAPAM00I@Z has been targeted for automatic cpu dispatch.
IccTestApp.cpp
Linking... (Intel C++ Environment)
xilink: executing 'link'
Creating library ..\\Release\\IccTestApp.lib and object ..\\IccTestApp\\Release\\IccTestApp.exp
Embedding manifest... (Microsoft VC++ Environment)
IccTestApp - 0 error(s), 2 warning(s), 3 remark(s)
========== Build: 1 succeeded, 0 failed, 1 up-to-date, 0 skipped ==========
Compileroptions are as follows:
/c /O3 /Ob2 /Oi /Ot /I "..\\..\\Include" /D "WIN32" /D "_CONSOLE" /D "NDEBUG" /D "_WIN32_ICC"
/D "INTEL_SUITE_VERSION=PE121_300" /D "_AFXDLL" /D "_VC80_UPGRADE=0x0710" /D "_UNICODE"
/D "UNICODE" /GF /EHsc /MD /GS- /fp:precise /Yu"Stdphf.h"
/Fp"Release\\IccTestApp.pch" /Fo"Release/" /W5 /nologo /TP /Qdiag-disable:473
/U "_WIN32_MSC" /U "_WIN32CE_MSC" /U "WIN32_PLATFORM_PSPC" /U "WIN32_PLATFORM_WFSP"
/U "WIN32_PLATFORM_WM50" /U "_WIN32_MGW" /U "_WIN32_BCC" /U "_COS16_TCC"
/QaxAVX /Qdiag-disable:111,673 /Zc:wchar_t /Zc:forScope /GR /Zm1000 /EHs-c-
My Development Environment:
OS: Windows XP 32-bit
IDE: Visual Studio 2005 SP1
Compilers: Intel C++ / Microsoft C++ / Borland C++ / MinGW / Turbo C++
Intel C++ compiler version ( Composer XE 2011 Update 9 ):
Sergey
Om_S_Intel
I am planning to submit a feature request to fix the remarks without numbers. It world be nice if you can help with small code segment that produces remarks without numbers.
Om
SergeyKostrov
Here is a screenshot:
Judith_W_Intel
Yes these type of diagnostics are emitted by the back end of the compiler and generally have to do with optimizations like loops being vectorized.
Did youhave a particular question or was this just an observation?Like would you expect that the names to be unmangled?
Judy
SergeyKostrov
Yes. I would be glad to seeall remarks with numbers, like:
..\.cpp(nnn): (col. 1) remark 12345: ?@ has been targeted for automatic cpu dispatch.
and then I could disable it with '/Qdiag-disable:12345'. Please consider this as a feature request.
No. Yes
Judy
Thank you, Judy!
Sergey
[Updated]
SergeyKostrov
I'd like to change my previous answer from No to Yes. That is, unmangled form will look better:
A generic form for a class:
..\.cpp(nnn):remark #nnnn: :: has been targeted for automatic cpu dispatch.
A real example for a class:
...\DataSet.cpp(132): remark #12345: CDataSet::RunAlgorithm has been targeted for automatic cpu dispatch.
levicki
I second this idea. It would be usefull to have unmangled names.
I thought that you can already disable those remarks?
SergeyKostrov
Hi Igor,
Quoting Igor Levicki
Unfortunately No because it doesn't have a number. ( I used '12345' as an example! )
I've done additional investigation and acompiler option /QaxAVX is the source of the remark.
Sergey
SergeyKostrov
Here is another set of Intel C++ compilerremarks without numbers:
...remark: PARTIAL LOOP WAS VECTORIZED.
...remark: loop was not vectorized: existence of vector dependence.
...remark: loop was not vectorized: notinner loop.
...remark: loop was not vectorized: nonstandard loop is not a vectorization candidate.
...remark: loop skipped: multiversioned.
levicki
Sergey, those remarks should not be output unless you use /Qvec_report switch with n > 0.
SergeyKostrov
Thanks, Igor. I see that there are three types of different diagnostic messages of Intel C++ compiler:
- warnings with numbers
- remarks with numbers
- remarks without numbers
So, remarks without numberslook like some inconsistency because:
- there are no warnings without numbers
- I can't disableremarks without numberswith a #pragma warning ( disable : nnnn )directive when
they aredisplayed
Also, maybe it makes sense to have a new #pragma remark ( disable : nnnn ) directive? Please consider it
Sergey
Om_S_Intel
Om
levicki
Remarks without numbers are output by compiler diagnostics and they are only output if you enable diagnostics remarks -- they are enabled and disabled as a group.
/Qvec_report:2 will output loop vectorization remarks without numbers. Conversely, if you remove /Qvec_report those remarks won't be output. There is no need for them to have a number when they can be enabled and disabled with a switch -- number doesn't add any value to their content.
I agree that other remarks without number should have it, but I disagree on vectorization and optimization diagnostics remarks.
SergeyKostrov
Om
I'll try to create a Test-Case for:
..\.cpp(nnn):remark: @ has been targeted for automatic cpu dispatch.
remark.
SergeyKostrov
Here is a Test-Case:
[cpp] ... // Sub-Test For Intel C++ compiler remark: ?@ has been targeted for automatic cpu dispatch #define _TESTDLL_EXPORTS #ifdef _TESTDLL_EXPORTS #define _TESTAPI _declspec( dllexport ) #else #define _TESTAPI _declspec( dllimport ) #endif class _TESTAPI CBaseObject { public: CBaseObject( void ){}; virtual ~CBaseObject( void ){}; virtual bool Method( void ) { return ( bool )true; }; }; class _TESTAPI CTestObject : public CBaseObject { public: CTestObject( void ){}; virtual ~CTestObject( void ){}; public: virtual bool Method( void ) { return ( bool )true; }; }; ... ... CTestObject to; to.Method(); ... [/cpp]
SergeyKostrov
Any updates on the issue? . >>>>Quoting Judith Ward (Intel) ... >>>>Like would you expect that the names to be unmangled? >> >>I'd like to change my previous answer from No to Yes. That is, unmangled form will look better: >> >>A generic form for a class: >> >>..\.cpp(nnn):remark #nnnn: :: has been targeted for automatic cpu dispatch. >> >>A real example for a class: >> >>...\DataSet.cpp(132): remark #12345: CDataSet::RunAlgorithm has been targeted for automatic cpu dispatch. . I think Microsoft / Intel C/C++ compiler predefined ANSI C macro __FUNCTION__ has to be used instead of __FUNCDNAME__ macro: . When used in a scope of 'CDataSet::RunAlgorithm' method __FUNCDNAME__ "returns" '?RunAlgorithm@CDataSet@@UAEEXZ' . When used in a scope of 'CDataSet::RunAlgorithm' method __FUNCTION__ "returns" 'CDataSet::RunAlgorithm' Best regards, Sergey
jimdempseyatthecove
Judith Consider #pragma remark(disable:"has been targeted for automatic cpu dispatch") Same with warning IOW permit either number or text (where text can be partial match using strstr). Jim Dempsey
SergeyKostrov
>>Consider >> >>#pragma remark(disable:"has been targeted for automatic cpu dispatch") >>Same with warning Unfortunately it doesn't work with Microsoft C/C++ compiler: When #pragma remark( disable : "has been targeted for automatic cpu dispatch" ) used in source codes the compiler outputs: ... ..\prttests.cpp(6594) : warning C4068: unknown pragma ...
jimdempseyatthecove
>>prttests.cpp(6594) : warning C4068: unknown pragma Then conditionalize for the compiler(s) supporting the feature. (or disable warning C4068 around the pragma) The point being to get rid of the anoying remark. Jim
SergeyKostrov
>>...Then conditionalize for the compiler(s) supporting the feature. (or disable warning C4068 around the pragma)... Thanks, Jim. I'll try it.
SergeyKostrov
>>...I think Microsoft / Intel C/C++ compiler predefined ANSI C macro __FUNCTION__ has to be used instead of __FUNCDNAME__ macro... I had a couple of issues with __FUNCSIG__, __FUNCDNAME__ and __FUNCTION__ macros when used on a project that was designed and implemented for several platforms. So, here is a piece of codes and I hope it will be useful: [cpp] ... #if ( defined ( _WIN32_MSC ) || defined ( _WIN32_ICC ) ) #define __RTFUNCTION2__( _fname ) __FUNCTION__ #ifdef _RTDEBUG #define __RTFUNCTION( _fname ) CrtPrintfA( "%s\n", __FUNCTION__ ) #else #define __RTFUNCTION( _fname ) #endif #endif #if ( defined ( _WIN32CE_MSC ) ) #define __RTFUNCTION2__( _fname ) __FUNCTIONW__ #ifdef _RTDEBUG #define __RTFUNCTION( _fname ) CrtPrintf( RTU("%s\n"), __FUNCTIONW__ ) #else #define __RTFUNCTION( _fname ) #endif #endif #if ( defined ( _WIN32_MGW ) || defined ( _WIN32_BCC ) || defined ( _COS16_TCC ) ) #define __RTFUNCTION2__( _fname ) _fname #ifdef _RTDEBUG #define __RTFUNCTION( _fname ) CrtPrintfA( "%s\n", __RTFUNCTION2__( _fname ) ) #else #define __RTFUNCTION( _fname ) #endif #endif ... [/cpp]
SergeyKostrov
Here are a couple of test-cases: [cpp] // On a Windows Desktop platform ... // Prints: CrtPrintf( RTU("Test-Case 1.1\n") ); // Test-Case 1.1 CrtPrintfA( "%s\n", __FUNCSIG__ ); // void __cdecl RunTest1017(void) CrtPrintfA( "%s\n", __FUNCDNAME__ ); // ?RunTest1017@@YAXXZ CrtPrintfA( "%s\n", __FUNCTION__ ); // RunTest1017 CrtPrintf( RTU("%s\n"), __FUNCTIONW__ ); // RunTest1017 ... // On a Windows Mobile platform ... // Prints: CrtPrintf( RTU("Test-Case 1.2\n") ); // Test-Case 1.2 CrtPrintf( RTU("%s\n"), __FUNCSIG__ ); // ``````````````` CrtPrintf( RTU("%s\n"), __FUNCDNAME__ ); // `````````Z%s CrtPrintf( RTU("%s\n"), __FUNCTION__ ); // `````7`````````Z%s CrtPrintf( RTU("%s\n"), __FUNCTIONW__ ); // RunTest1017 ... // On a Windows Mobile platform ... // Prints: CrtPrintf( RTU("Test-Case 1.3\n") ); // Test-Case 1.3 CrtPrintf( RTU("%s\n"), CA2W( __FUNCSIG__ ) ); // void __cdecl RunTest1017(void) CrtPrintf( RTU("%s\n"), CA2W( __FUNCDNAME__ ) ); // ?RunTest1017@@YAXXZ CrtPrintf( RTU("%s\n"), CA2W( __FUNCTION__ ) ); // RunTest1017 CrtPrintf( RTU("%s\n"), __FUNCTIONW__ ); // RunTest1017 ... [/cpp]
