Community
cancel
Showing results for
Search instead for
Did you mean:
Repeated failed installation of VS + Parallel Studio XE Cluster Edition for Windows
I can't manage to install any couple of VS+Parallel Studio on Windows 7.
My latest attemp is Visual Studio 2013 + parallel_studio_xe_2015_update6.
I have the following error :
Intel(R) Parallel Studio XE 2015 Update 6 Cluster Edition for Windows* Setup Wizard ended prematurely because of an error(s).
  Windows Installer failed to configure product:
Error message: An error occured during the installation of assembly component 98CB24AD-52FB-DB5F-A01F-C8B3B9A1E18E. HRESULT: 0x80070422.
Error code: 1603
File name: msvcrt_x86.msi
I have also tried more recent versions of both but the installation also fails for the same reason.
What can I do ?
Thanks for help.
Installer logs location: C:\Users\mottelet\AppData\Local\Temp\pset_tmp_PSXE2015_mottelet\2018.07.18_18.50.44_00000910\log\
