I just installed the Intel® Parallel Studio XE Professional Edition for C++ Linux* (evaluation version) for my Ubuntu 14.04.2 machine running on a "Intel Corporation Xeon E3-1200 Processor Family" processor.
I don't understand if this is a 32-bit compiler or not. I'm worried about this since during the installation a message reporting the absence of some 32-bit libraries appears on the console.
Since I'm interested to have the best performances (running time) of my code, does a 64-bit specific version exist for my machine?
Thank you
When you run install.sh as below, make sure to disable the installation for 32 bit and install only for 64 target as follows:
Select the architecture(s) where your applications will run. If unsure, accept
the default options below or see
http://software.intel.com/en-us/articles/about-target-architecture-selection-dur
ing-installation for more information.
Target Architecture(s) of your applications:
1.
2.
3. Finish architecture selection [default]
Now, disable the IA-32 option above by choosing 1. This way it'll only install for 64 bit targets.
Step 4 of 6 | Options > Architecture selection
1. [ ] IA-32
2.
After the above, continue the install. Hopefully you should not see any issue with 32 libs etc.
_Kittur
1.
2.
1. [ ] IA-32
2.
_Kittur
BTW, after installation you can check the version of the compiler installed by invoking "icc -V" command as follows:
%icc -V
Intel(R) C Intel(R) 64 Compiler XE for applications running on Intel(R) 64, Version 15.0.2.164 Build 20150121
Copyright (C) 1985-2015 Intel Corporation. All rights reserved.
_Kittur
thank you a lot!
Glad to know it's resolved. Again, appreciate your interest in evaluating the product and ensuring you have the right compiler for the right platform as well! Also, your evaluation survey feedback after your evaluation is much appreciated by the product team for product improvement in future releases.
_Kittur
