I recently installed the oneapi base toolkit after having used just the classic
fortran compiler, for a while to build a static lib. I mistakenly thought intel could do a better job than Microsoft. The install forced intel C++ down my
throat and, unbenounced to me, assumed a 64 bit target machine. Our app
is an older 32 bit app. When it went to link, all our pre-built 32 bit libraries
were tagged as no good because the miserable intel C++ said you can't use
32 bit libraries on a 64 bit target machine. THIS IS LUDICROUS! Somebody
should tell those bumbling idiots at intel that 32 bit code works JUST FINE
on a 64 bit machine. It 64 bit code that can NOT be run on a 32 bit machine.
How can I fix this mess to make my app get built?
Apologies for causing any inconvenience
Could you please provide a sample reproducer along with the steps you have followed so that we can try it from our end?
Also please provide OS details and compiler version being used.
Thanks & Regards,
Noorjahan.
We haven't heard back from you. Could you please provide an update on your issue?
Thanks & Regards,
Noorjahan.
We have not heard back from you, so I will close this inquiry now. If you need further assistance, please post a new question.
Thanks & Regards,
Noorjahan.
