Hi! I wanted to compile a c program that uses offloading stuff within it. The issue is that when trying to compiler I get a Runtime error and the compiler crashes, this is the message that get when I go to debug mode:
'gfx_linker.exe' (Win32): Loaded 'C:\Program Files (x86)\Intel\Composer XE 2013 SP1\bin\ia32_gfx\gfx_linker.exe'. Cannot find or open the PDB file.
'gfx_linker.exe' (Win32): Loaded 'C:\Windows\SysWOW64\ntdll.dll'. Cannot find or open the PDB file.
'gfx_linker.exe' (Win32): Loaded 'C:\Windows\SysWOW64\kernel32.dll'. Cannot find or open the PDB file.
'gfx_linker.exe' (Win32): Loaded 'C:\Windows\SysWOW64\KernelBase.dll'. Cannot find or open the PDB file.
The thread 0x8ac has exited with code 0 (0x0).
The program '[3156] gfx_linker.exe' has exited with code 3 (0x3).
Thank you,
Thom
Just as an addition. I have also run the compiler in administrator mode and the same thing happens. I thought maybe windows stupid privileges policy might be causing the problem, but no.
