I have a very simple 32 bit Xcode project setup running under OSX 10.9.5, Xcode 5.2
Main project - compiled by Intel C++ calling constructor of a class in a subproject. Subproject is a static library, compiled by llvm clang++.
In my main project (Intel C++) I have:
main.cpp:
#include "test.h"
int main(int argc, const char * argv[])
test t;
return 0;
In my subproject (LLVM Clang++) I have:
test.h:
class test {
public:
test();
test.cpp:
#include "test.h"
test::test()
try {
throw 1;
} catch (...) {
Exception, thrown in test::test() is not caught, causing abnormal termination.
When I change compiler of my main project to LLVM Clang++, the exception is caught as expected.
I've attached my test project.
Hi Sergei,
I've reproduced the problem and entered it to our problem-tracking database. I'll let you know when I have an update from engineering team.
Hi Sergei,
Today I was informed that IPS XE 2015 Update 2 contains the fix for this issue. You may download it at https://registrationcenter.intel.com. FYI.
