With the Microsoft compiler, compiling in C++ standard compliance mode of 2017 or later, I can use SIMD data types for example in std::vector without custom allocators. When trying to use Intel compiler from Visual Studio this does not seem to work. (I am new to using the Intel compiler, so I may just be missing some option, but I think I have tried the standard version settings etc)
I have attached example code at the bottom of this message. The memory allocations of course vary, and often produce aligned results, even if not set really set up correctly. The define (commented out) on the first line seems to be the one controlling the behavior in Microsoft header files, if it is used, then the code works also with Intel compilers. As the defined symbol is in "compiler namespace", I guess defining it as a user is not a clean solution.
There are some compatibility issues between Visual Studio 2019 and Intel compiler, so I have done my testing with Visual Studio 2017.
Eero
//#define __cpp_aligned_new 1 #include <stdio.h> #include <xmmintrin.h> #include <vector> struct Test_S{ __m128 v; float b; }; int main(){ fprintf(stderr,"Alignment requirement = %d\n",alignof(Test_S)); #ifdef __cpp_aligned_new fprintf(stderr,"__cpp_aligned_new defined\n"); #else fprintf(stderr,"__cpp_aligned_new not defined\n"); #endif std::vector<Test_S> a; a.push_back(Test_S()); fprintf(stderr,"addr=%p\n",&(a[0].v)); std::vector<Test_S> b; b.push_back(Test_S()); fprintf(stderr,"addr=%p\n",&(b[0].v)); std::vector<Test_S> c; c.push_back(Test_S()); fprintf(stderr,"addr=%p\n",&(c[0].v)); }
- Tags:
- CC++
- Development Tools
- Intel® C++ Compiler
- Intel® Parallel Studio XE
- Intel® System Studio
- Optimization
- Parallel Computing
- Vectorization
Can you provide the output when you compiled with icl vs. cl?
The template magic produces thousands of lines of assembly, which I found rather difficult to follow.
It is "easier" to follow the logic on debugger while single stepping. As mentioned the problems seems to start from a mssing __cpp_aligned_new preprocessor symbol, which in the header files is transferred to _HAS_ALIGNED_NEW symbol.
The _HAS_ALIGNED_NEW is used in xmemory0 header starting on line 138 for generating and selecting template functions for the allocator.
The call chain genrated by Microsoft compiler leads to this function:
; Function compile flags: /Odtp /ZI ; File c:\program files (x86)\microsoft visual studio\2017\community\vc\tools\msvc\14.16.27023\include\xmemory0 ; COMDAT ??$_Allocate@$0BA@U_Default_allocate_traits@std@@$0A@@std@@YAPAXI@Z _TEXT SEGMENT $T1 = -72 ; size = 4 __Passed_align$ = -4 ; size = 4 __Bytes$ = 8 ; size = 4 ??$_Allocate@$0BA@U_Default_allocate_traits@std@@$0A@@std@@YAPAXI@Z PROC ; std::_Allocate<16,std::_Default_allocate_traits,0>, COMDAT ; 143 : { // allocate _Bytes when _HAS_ALIGNED_NEW && _Align > __STDCPP_DEFAULT_NEW_ALIGNMENT__ push ebp mov ebp, esp sub esp, 72 ; 00000048H push ebx push esi push edi ; 144 : if (_Bytes == 0) cmp DWORD PTR __Bytes$[ebp], 0 jne SHORT $LN2@Allocate ; 145 : { ; 146 : return (nullptr); xor eax, eax jmp SHORT $LN1@Allocate $LN2@Allocate: ; 147 : } ; 148 : ; 149 : size_t _Passed_align = _Align; mov DWORD PTR __Passed_align$[ebp], 16 ; 00000010H ; 150 : #if defined(_M_IX86) || defined(_M_X64) ; 151 : if (_Bytes >= _Big_allocation_threshold) cmp DWORD PTR __Bytes$[ebp], 4096 ; 00001000H jb SHORT $LN3@Allocate ; 152 : { // boost the alignment of big allocations to help autovectorization ; 153 : _Passed_align = _Max_value(_Align, _Big_allocation_alignment); mov DWORD PTR $T1[ebp], 16 ; 00000010H push OFFSET ?_Big_allocation_alignment@std@@3IB lea eax, DWORD PTR $T1[ebp] push eax call ??$_Max_value@I@std@@YAABIABI0@Z ; std::_Max_value<unsigned int> add esp, 8 mov ecx, DWORD PTR [eax] mov DWORD PTR __Passed_align$[ebp], ecx $LN3@Allocate: ; 154 : } ; 155 : #endif /* defined(_M_IX86) || defined(_M_X64) */ ; 156 : ; 157 : return (_Traits::_Allocate_aligned(_Bytes, _Passed_align)); mov eax, DWORD PTR __Passed_align$[ebp] push eax mov ecx, DWORD PTR __Bytes$[ebp] push ecx call ?_Allocate_aligned@_Default_allocate_traits@std@@SAPAXII@Z ; std::_Default_allocate_traits::_Allocate_aligned add esp, 8 $LN1@Allocate: ; 158 : } pop edi pop esi pop ebx mov esp, ebp pop ebp ret 0 ??$_Allocate@$0BA@U_Default_allocate_traits@std@@$0A@@std@@YAPAXI@Z ENDP ; std::_Allocate<16,std::_Default_allocate_traits,0> _TEXT ENDS
On Intel compiler the call chain goes to: (Notice the comment fragment on line 19)
_TEXT SEGMENT DWORD PUBLIC FLAT 'CODE' ; COMDAT ??$_Allocate@$07U_Default_allocate_traits@std@@$0A@@std@@YAPAXI@Z TXTST66: _2__routine_start_??$_Allocate@$07U_Default_allocate_traits@std@@$0A@@std@@YAPAXI@Z_66: ; -- Begin ??$_Allocate@$07U_Default_allocate_traits@std@@$0A@@std@@YAPAXI@Z ;??$_Allocate@$07U_Default_allocate_traits@std@@$0A@@std@@YAPAXI@Z ENDS _TEXT ENDS _TEXT SEGMENT DWORD PUBLIC FLAT 'CODE' ; COMDAT ??$_Allocate@$07U_Default_allocate_traits@std@@$0A@@std@@YAPAXI@Z ; mark_begin; PUBLIC ??$_Allocate@$07U_Default_allocate_traits@std@@$0A@@std@@YAPAXI@Z ; --- std::_Allocate<8U, std::_Default_allocate_traits, 0>(size_t) ??$_Allocate@$07U_Default_allocate_traits@std@@$0A@@std@@YAPAXI@Z PROC NEAR ; parameter 1(_Bytes): 8 + ebp .B67.1: ; Preds .B67.0 ; Execution count [0.00e+000] ;;; { // allocate _Bytes when !_HAS_ALIGNED_NEW || _Align <= __STDCPP_DEFAULT_NEW_ALIGNMENT__ L384:: ;180.2 $LN2543: push ebp ;180.2 $LN2544: mov ebp, esp ;180.2 $LN2545: sub esp, 8 ;180.2 $LN2546: ;;; #if defined(_M_IX86) || defined(_M_X64) ;;; if (_Bytes >= _Big_allocation_threshold) mov eax, DWORD PTR [8+ebp] ;182.2 $LN2547: cmp eax, 4096 ;182.2 $LN2548: jb .B67.4 ; Prob 50% ;182.2 $LN2549: ; LOE ebx ebp esi edi esp .B67.2: ; Preds .B67.1 ; Execution count [0.00e+000] $LN2550: ;;; { // boost the alignment of big allocations to help autovectorization ;;; return (_Allocate_manually_vector_aligned<_Traits>(_Bytes)); push eax ;184.3 $LN2551: mov eax, DWORD PTR [8+ebp] ;184.3 $LN2552: mov DWORD PTR [esp], eax ;184.3 $LN2553: call ??$_Allocate_manually_vector_aligned@U_Default_allocate_traits@std@@@std@@YAPAXI@Z ;184.3 $LN2554: ; LOE eax ebx ebp esi edi esp .B67.10: ; Preds .B67.2 ; Execution count [0.00e+000] $LN2555: mov DWORD PTR [-8+ebp], eax ;184.3 $LN2556: add esp, 4 ;184.3 $LN2557: ; LOE ebx ebp esi edi esp .B67.3: ; Preds .B67.10 ; Execution count [0.00e+000] $LN2558: mov eax, DWORD PTR [-8+ebp] ;184.3 $LN2559: leave ;184.3 $LN2560: ret ;184.3 $LN2561: ; LOE .B67.4: ; Preds .B67.1 ; Execution count [0.00e+000] $LN2562: ;;; } ;;; #endif /* defined(_M_IX86) || defined(_M_X64) */ ;;; ;;; if (_Bytes != 0) mov eax, DWORD PTR [8+ebp] ;188.2 $LN2563: test eax, eax ;188.2 $LN2564: je .B67.7 ; Prob 50% ;188.2 $LN2565: ; LOE ebx ebp esi edi esp .B67.5: ; Preds .B67.4 ; Execution count [0.00e+000] $LN2566: ;;; { ;;; return (_Traits::_Allocate(_Bytes)); push eax ;190.3 $LN2567: mov eax, DWORD PTR [8+ebp] ;190.3 $LN2568: mov DWORD PTR [esp], eax ;190.3 $LN2569: ; std::_Default_allocate_traits::_Allocate(size_t) call ?_Allocate@_Default_allocate_traits@std@@SAPAXI@Z ;190.3 $LN2570: ; LOE eax ebx ebp esi edi esp .B67.11: ; Preds .B67.5 ; Execution count [0.00e+000] $LN2571: mov DWORD PTR [-4+ebp], eax ;190.3 $LN2572: add esp, 4 ;190.3 $LN2573: ; LOE ebx ebp esi edi esp .B67.6: ; Preds .B67.11 ; Execution count [0.00e+000] $LN2574: mov eax, DWORD PTR [-4+ebp] ;190.3 $LN2575: leave ;190.3 $LN2576: ret ;190.3 $LN2577: ; LOE .B67.7: ; Preds .B67.4 ; Execution count [0.00e+000] $LN2578: ;;; } ;;; ;;; return (nullptr); mov eax, 0 ;193.2 $LN2579: leave ;193.2 $LN2580: ret ;193.2 $LN2581: ; LOE $LN2582: ; mark_end;
I hope I got the code pieces right....
Eero
Sorry, what I meant was how to compile the test case (I didn't see error when compiled it) and what the results of executing the binary.
I saved my example file, and managed to compile it directly by just running icl test.cpp
(in shell started from the windows start menu entry for Intel 19.0 compiler)
Can you contact me directly, or provide more information here?
Eero
C:\Temp>icl test.cpp
Intel(R) C++ Intel(R) 64 Compiler for applications running on Intel(R) 64, Version 19.1.0.166 Build 20191121
Copyright (C) 1985-2019 Intel Corporation. All rights reserved.
test.cpp
Microsoft (R) Incremental Linker Version 14.23.28105.4
Copyright (C) Microsoft Corporation. All rights reserved.
-out:test.exe
test.obj
C:\Temp>test.exe
Alignment requirement = 16
addr=0000020AEDE8F9F0
addr=0000020AEDE8FB10
addr=0000020AEDE8FA20
C:\Temp>notepad test.cpp
#include <stdio.h>
#include <vector>
struct Test_S{
__m128 v;
float b;
int main(){
#else
#endif
Maybe the problem only exists with the 32bit target compiler?
I now tested the 64 bit target compiler, and it seems to avoid the problem, I have not gone through the code with debugger, so I am not 100% sure.
With the 32bit target I get results like:
H:\Dropbox\tmp>icl test.cpp Intel(R) C++ Intel(R) 64 Compiler for applications running on IA-32, Version 19.0.5.281 Build 20190815 Copyright (C) 1985-2019 Intel Corporation. All rights reserved. test.cpp Microsoft (R) Incremental Linker Version 14.16.27035.0 Copyright (C) Microsoft Corporation. All rights reserved. -out:test.exe test.obj H:\Dropbox\tmp>test.exe Alignment requirement = 16 __cpp_aligned_new not defined addr=00F2CA30 addr=00F2C9B8 addr=00F2CA08
Where the last two addresses would have crashed sse data loading from the pointer?
Eero
