Hi Everyone,
I have a matrix class with one virtual method (csi0) to access elements of the column major data pointer. I have declared it as SIMD-enabled function; however, when I check the IPO reports the overloaded binary operators are not vectorized. It complains there is vector dependence in the code.
Below you can find snippets from the class along with the optimization report.
# define MAT_ASSERT(cond, msg) if(cond){ } else { std::cerr << std::endl << "Error, assertion failed in file:'" << __FILE__ << "' at line:" <<
# define MAT_ASSERT_SHORT(cond) MAT_ASSERT(cond, #cond)
template <class V>
class matrix{
V * data;
int nrows, ncols;
unsigned char attribs;
// some constructor definitions
inline int numel() const{ return nrows*ncols; }
inline int size(int d) const{ return (d==1) ? nrows : ncols; }
#pragma omp declare simd
#pragma omp declare simd uniform(this)
#pragma omp declare simd uniform(this) simdlen(4) linear(i)
virtual inline V& csi0(int i) const{
return data[i];
template <class V1> friend matrix<V> operator-(const matrix<V> & a, const matrix<V1> & b) {
DEBUG_VERBOSE("op matrix<V> - matrix<V1>");
if(a.isscalar()){
matrix<V> c(b.size(1),b.size(2));
V v0 = (V)a.csi0(0);
#pragma omp parallel for simd
for (int i = 0 ; i < b.numel(); i++)
c.csi0(i) = v0 - b.csi0(i);
return c.set_attribute(TEMPORARY);
}else if(b.isscalar()){
matrix<V> c(a.size(1),a.size(2));
V v0 = (V)b.csi0(0);
for (int i = 0 ; i < a.numel(); i++)
c.csi0(i) = a.csi0(i) - v0;
}else if(a.samesize(b)){
c.csi0(i) = a.csi0(i) - b.csi0(i);
}else
MAT_ABORT("Matrix dimension mismatch in operation '-'.");
return matrix<V>::empty(); // never is reached
Here is the report ...
Begin optimization report for: operator-<double>(matrix<double> *, const matrix<double> &, const matrix<double> &)
Report from: Interprocedural optimizations [ipo]
INLINE REPORT: (operator-<double>(matrix<double> *, const matrix<double> &, const matrix<double> &)) [30/1774=1.7%] C:\Users\Mehdi-laptop\sico\pplab\pplab\atrix\atrix.h(694,92)
-> INLINE (MANUAL): (696,3) matrix<double>::isscalar(const matrix<double> *) const (isz = 5) (sz = 12)
-> INLINE (MANUAL): (1238,3) matrix<double>::numel(const matrix<double> *) const (isz = 2) (sz = 8)
-> INLINE (MANUAL): (697,14) matrix<double>::size(const matrix<double> *, int) const (isz = 3) (sz = 12)
-> INLINE (MANUAL): (697,14) matrix<double>::matrix(matrix<double> *, int, int, attribute) (isz = 59) (sz = 72)
-> INLINE (MANUAL): (409,3) matrix<double>::minit(matrix<double> *, int, int, attribute) (isz = 55) (sz = 66)
-> INLINE (MANUAL): (343,3) matrix<double>::isempty(const matrix<double> *) const (isz = 5) (sz = 12)
-> INLINE (MANUAL): (1241,3) matrix<double>::numel(const matrix<double> *) const (isz = 2) (sz = 8)
-> INLINE (MANUAL): (344,7) matrix<double>::numel(const matrix<double> *) const (isz = 2) (sz = 8)
-> INLINE (MANUAL): (348,11) matrix<double>::numel(const matrix<double> *) const (isz = 2) (sz = 8)
-> (348,11) alloc(unsigned int) (isz = 601) (sz = 609)
[[ Inlining would exceed -Qinline-max-size value (609>230) <1>]]
-> INLINE: (356,4) mem_profile_new(int, bool) (isz = 10) (sz = 17)
-> DELETED: (105,2) getProcId() (isz = 0) (sz = 4)
-> DELETED: (106,2) getProcId() (isz = 0) (sz = 4)
-> INLINE (MANUAL): (356,4) matrix<double>::numel(const matrix<double> *) const (isz = 2) (sz = 8)
-> INDIRECT- (VIRTUAL): (698,9) matrix<double>::csi0(const matrix<double> *, int) const (isz = 1) (sz = 9)
[[ Callee not m with inlining pragma <2>]]
-> INLINE (MANUAL): (700,15) matrix<double>::numel(const matrix<double> *) const (isz = 2) (sz = 8)
-> INLINE (MANUAL): (701,5) matrix<double>::csi0(const matrix<double> *, int) const (isz = 1) (sz = 9)
-> INDIRECT- (VIRTUAL): (701,5) matrix<double>::csi0(const matrix<double> *, int) const (isz = 1) (sz = 9)
-> INLINE (MANUAL): (702,4) matrix<double>::matrix(matrix<double> *, const matrix<double> &) (isz = 130) (sz = 139)
-> INLINE (MANUAL): (446,13) matrix<double>::size(const matrix<double> *, int) const (isz = 3) (sz = 12)
-> INLINE (MANUAL): (446,13) matrix<double>::minit(matrix<double> *, int, int, attribute) (isz = 55) (sz = 66)
-> INLINE (MANUAL): (448,23) matrix<double>::numel(const matrix<double> *) const (isz = 2) (sz = 8)
-> INLINE (MANUAL): (449,17) matrix<double>::csi0(const matrix<double> *, int) const (isz = 1) (sz = 9)
-> INDIRECT- (VIRTUAL): (449,17) matrix<double>::csi0(const matrix<double> *, int) const (isz = 1) (sz = 9)
-> INLINE (MANUAL): (702,4) matrix<double>::set_attribute(matrix<double> *, attribute) (isz = 5) (sz = 14)
-> INLINE (MANUAL): (702,4) matrix<double>::~matrix(matrix<double> *) (isz = 39) (sz = 44)
-> (509,7) ree(void *, unsigned int) (isz = 52) (sz = 59)
-> INLINE (MANUAL): (509,7) matrix<double>::numel(const matrix<double> *) const (isz = 2) (sz = 8)
-> INLINE (MANUAL): (512,4) matrix<double>::numel(const matrix<double> *) const (isz = 2) (sz = 8)
-> INLINE: (512,4) mem_profile_del(int, bool) (isz = 10) (sz = 17)
-> DELETED: (109,2) getProcId() (isz = 0) (sz = 4)
-> DELETED: (110,2) getProcId() (isz = 0) (sz = 4)
-> INLINE (MANUAL): (703,9) matrix<double>::isscalar(const matrix<double> *) const (isz = 5) (sz = 12)
-> INLINE (MANUAL): (704,14) matrix<double>::size(const matrix<double> *, int) const (isz = 3) (sz = 12)
-> INLINE (MANUAL): (704,14) matrix<double>::matrix(matrix<double> *, int, int, attribute) (isz = 59) (sz = 72)
-> INDIRECT- (VIRTUAL): (705,9) matrix<double>::csi0(const matrix<double> *, int) const (isz = 1) (sz = 9)
-> INLINE (MANUAL): (707,15) matrix<double>::numel(const matrix<double> *) const (isz = 2) (sz = 8)
-> INDIRECT- (VIRTUAL): (708,5) matrix<double>::csi0(const matrix<double> *, int) const (isz = 1) (sz = 9)
-> INLINE (MANUAL): (708,5) matrix<double>::csi0(const matrix<double> *, int) const (isz = 1) (sz = 9)
-> INLINE (MANUAL): (709,4) matrix<double>::set_attribute(matrix<double> *, attribute) (isz = 5) (sz = 14)
-> INLINE (MANUAL): (709,4) matrix<double>::matrix(matrix<double> *, const matrix<double> &) (isz = 130) (sz = 139)
-> INLINE (MANUAL): (709,4) matrix<double>::~matrix(matrix<double> *) (isz = 39) (sz = 44)
-> INLINE (MANUAL): (710,9) matrix<double>::samesize<double>(const matrix<double> *, const matrix<double> &) const (isz = 21) (sz = 30)
-> INLINE (MANUAL): (1244,3) matrix<double>::size(const matrix<double> *, int) const (isz = 3) (sz = 12)
-> INLINE (MANUAL): (711,14) matrix<double>::size(const matrix<double> *, int) const (isz = 3) (sz = 12)
-> INLINE (MANUAL): (711,14) matrix<double>::matrix(matrix<double> *, int, int, attribute) (isz = 59) (sz = 72)
-> INLINE (MANUAL): (713,15) matrix<double>::numel(const matrix<double> *) const (isz = 2) (sz = 8)
-> INLINE (MANUAL): (714,5) matrix<double>::csi0(const matrix<double> *, int) const (isz = 1) (sz = 9)
-> INDIRECT- (VIRTUAL): (714,5) matrix<double>::csi0(const matrix<double> *, int) const (isz = 1) (sz = 9)
-> INLINE (MANUAL): (715,4) matrix<double>::set_attribute(matrix<double> *, attribute) (isz = 5) (sz = 14)
-> INLINE (MANUAL): (715,4) matrix<double>::~matrix(matrix<double> *) (isz = 39) (sz = 44)
-> INLINE (MANUAL): (715,4) matrix<double>::matrix(matrix<double> *, const matrix<double> &) (isz = 130) (sz = 139)
-> INLINE (MANUAL): (718,3) matrix<double>::empty(const matrix<double> *) (isz = 63) (sz = 70)
-> INLINE (MANUAL): (1156,3) matrix<double>::matrix(matrix<double> *, int, int, attribute) (isz = 59) (sz = 72)
Report from: Loop nest, Vector & Auto-parallelization optimizations [loop, vec, par]
LOOP BEGIN at C:\prjdir\matrix.h(699,4)
rem17104: loop was not parallelized: existence of parallel dependence
rem15382: vectorization support: call to function virtual call: matrix<double>::csi0(const matrix<double> *, int) const cannot be vectorized [ C:\prjdir\matrix.h(701,5) ]
rem15344: loop was not vectorized: vector dependence prevents vectorization
rem25456: Number of Array Refs Scalar Replaced In Loop: 1
LOOP END
LOOP BEGIN at C:\prjdir\matrix.h(447,13) inlined into C:\prjdir\matrix.h(703,4)
rem15382: vectorization support: call to function virtual call: matrix<double>::csi0(const matrix<double> *, int) const cannot be vectorized [ C:\prjdir\matrix.h(449,17) ]
LOOP END
LOOP BEGIN at C:\prjdir\matrix.h(706,4)
rem15382: vectorization support: call to function virtual call: matrix<double>::csi0(const matrix<double> *, int) const cannot be vectorized [ C:\prjdir\matrix.h(708,5) ]
LOOP END
LOOP BEGIN at C:\prjdir\matrix.h(447,13) inlined into C:\prjdir\matrix.h(710,4)
LOOP END
LOOP BEGIN at C:\prjdir\matrix.h(712,4)
rem15382: vectorization support: call to function virtual call: matrix<double>::csi0(const matrix<double> *, int) const cannot be vectorized [ C:\prjdir\matrix.h(714,5) ]
LOOP END
LOOP BEGIN at C:\prjdir\matrix.h(447,13) inlined into C:\prjdir\matrix.h(716,4)
LOOP END
I have also studied the below section as discussed here ...
Nothings seem to me out of order ...
Any comment is much appreciate it.
Try this untested code:
template <class V>
class matrix{
V * data;
int nrows, ncols;
return data[i];
if(a.isscalar()){
V * _c = &c.csi0(0);
V * _b = &b.csi0(0);
_c[i] = v0 - _b[i];
V * _a = &a.csi0(0);
_c[i] = _a[i] - v0;
_c[i] = _a[i] - _b[i];
}else
Note, by making data public, you could use c.data[i] = a.data[i] - b.data[i];
etc... for the +/*,...
Jim Dempsey
I think the compiler can assume the &'s (references) can (potentially) be aliased, had you used * (pointer) then you could apply the "restrict" attribute. Try using a temporary pointer to the array, then call an inlined templated function using restrict on the pointers to perform the operation. Not sure if you can use restrict on a reference.
Jim Dempsey
Thank you for the clue ... however, the code is pretty big and changing signatures would be cumbersome at this point. Interestingly enough I can get pretty smooth vectorization using simplified examples (I was hopping I could reproduce the issue, which apparently failed
So I am guessing, there are other parts of the application that could possibly cause the issue (perhaps some sort of side effect maybe cause by template instantiation). In other words, in the smaller example, I can vectorize the operator+/- just fine, but in the main application vectorization fails due to vector dependence.
Do you thing inlining would be a hinderance for vectorization (causing vector dependence perhaps)? Hypothetically, Let say the overloaded operator+/- is hinted to have a simd-able loop (ie. using #pragma omp parallel for simd and #pragam omp declare simd for all functions called inside the + operator main for loop and all other fucntion called nested-ly in the loop) and I forgot to declare different simd variants of the inner functions (using #pragam omp declare simd) and the compiler tries to choose from smaller set of the simd-enabled inner function variants and then trying to inline the operator loop throughout the application. Then it realizes that it has to ignore vectorization to be able to inline the operator's code all across the application so that the operator+/- main operator's loop can be inline-able across the application. Would such sort of (probably ill-posed) scenario potentially cause vector dependence?
Many thanks for your valuable comments.
Could you please provide us a minimal reproducer so that we can work on it from our end
Vidya.
template <class V>
class matrix{
V * data;
int nrows, ncols;
return data[i];
if(a.isscalar()){
_c[i] = v0 - _b[i];
_c[i] = _a[i] - v0;
}else
Jim Dempsey
Hi Mike,
Could you please confirm if your issue is resolved and whether we can close this thread.
Vidya
Hi Mike,
Thanks for the confirmation!
As this issue has been resolved, we will no longer respond to this thread.
If you require any additional assistance from Intel, please start a new thread.
Any further interaction in this thread will be considered community only.
Have a Good day.
Vidya.
