Intel® C++ Compiler
Support and discussions for creating C++ code that runs on platforms based on Intel® processors.
SSE intstruction error
inteleverywhere
if a register has to be filled with data upto an arbitrary byte/word/dword position is it possible? for example:
if cnt = 0 or 1 or 2 or 3. how can the following be done
for (int i=0; i < cnt; i++)
Register = _mm_insert_epi32(Register, i);
Register1 = _mm_slli_si128(Register1, i);
Both are being dissallowed since i is required to be a constant value. Is there a workaround?
suppose at run time only two values are to be filled (cnt = 2).
Deepak
JenniferJ
Try to avoid the "for" statement. so like below:
[cpp]switch (cnt)  {
   case 1:
        Register  = _mm_insert_epi32(Register, 1);
        Register1 = _mm_slli_si128(Register1, 1);
        break;
  case 2:
        //! Second loop instance
        Register  = _mm_insert_epi32(Register, 2);
        Register1 = _mm_slli_si128(Register1, 2);
        break;
[/cpp]
