Community
cancel
Showing results for
Search instead for
Did you mean:
Smart_Lubobya
SSE2
how can i transpose a matrix using SSE INSTRUCTIONS?
TimP
Black Belt
Quoting - Smart Lubobya
If you mean by in-lined intrinsics, this is worth while only for certain cases (4x4 for float data type), which you could find documented. More generally, you would look at MKL library which comes with Intel C++.
JenniferJ
You can use /QxSSE2 or /arch:SSE2 to compile, use /Qvec-report3 to report if the loop is vectorized with SSE intruction.
Jennifer
Smart_Lubobya
Quoting - tim18
"certain cases (4x4 for float data type), which you could find documented".where are these documented?
joex26
Just guessing:
Intel optimization manual?
TimP
Black Belt
Didn't you get enough hits when you typed "SSE transpose" in the search box?
