Thanks, Tim.
I think that would probably do it, although I still need tobuild and run the STLPort unit tests to ensure that everything works OK.
Apparently, libmmd.dll only preemts some (or a lot of!) of the math functions. My main worries are more concerning memory allocation and deallocation.
"Option -i-static, or, if not using the OpenMP library, -static-libcxa, should do it."
Isn't libcxa for Linux?
After going through the help file again, it appears that there is a file libmmds.lib which is the "Static math library built with /MD option".
Should I becompiling with"-static-libmmds" on Windows IA32, or how do I link to that file and not to libmmd.libwith /MD?
Sorry about my linux orientation. I can only point out that you could name any static .lib you want explicitly, to force it to be used in place of the dynamic one.
Unfortunately, the Windows version of ICL doesn't seem to like any of the options you suggested (Warning: ignoring unknown command-line option ...[etc.])
But I can link everything separately and specify the libraries, it's just a lot more work that way.
