When executing the program below, icc produced different results for Y and Y2. The result of Y is 12. I guess it multiplied the VALUE constant first, and got the result of 4, then cast the int 4 as long long type. Finally it is multiplied by 3 to get 12. And the value of Y2 is -4611686044197191668. Instead, it is possible to convert the type t to long long first and then multiply the variables t to produce the result of 4611686009837453316 which is long long type. Finally it is multiplied by 3 to get -4611686044197191668.
Is this a correct behavior for intel c complier? Sorry if i misunderstood something.
TestCase:
#include <stdio.h>
#define VALUE ((int)((long long)U1 * (long long)3) + 2)
int main(void)
long long Y, Y2;
int U1;
int t;
U1 = -2147483648;
Y = ((long long)(VALUE * VALUE) * 3);
t = VALUE;
Y2 = ((long long)(t * t) * 3);
if (Y != Y2)
printf("%lld,%lld\n", Y, Y2);
return 0;
The OS is:
Linux version 4.15.0-65-generic
Compiler Version:
icc (ICC) 19.0.4.243 20190416
Output:
12,-4611686044197191668
Expected output:
12,12
- Tags:
- CC++
- Development Tools
- General Support
- Intel® C++ Compiler
- Intel® Parallel Studio XE
- Intel® System Studio
- Optimization
- Parallel Computing
- Vectorization
t is an int (t*t) produces an int (and in this case an overflowed value)
(long long)t produces a long long representation of t
((long long)t)*t would produce the correct (and desired) result
You need to place your type casting properly (according to the established rules of operation for C/C++).
Note, you are also down-casting the result, thus truncating the 32 msb's
Jim Dempsey
jimdempseyatthecove (Blackbelt) wrote:t is an int (t*t) produces an int (and in this case an overflowed value)
Jim Dempsey
Hi Jim
When the type casting is ((long long)t) * t, the result of Y2 is -4611686044197191668. But why is it also -4611686044197191668 when the type casting is (long long )( t * t), shouldn't it be 12?
IMHO (t*t) should produced an intermediary result of the type of t
-2147483648 = 0x80000000
The 32-bit result of 0x80000000 * 0x80000000 = 0x00000000 i.e. (t*t)
0 * 3 = 0, thus Y2 should have been 0, not 12
When promoting one or both of the numbers to 64 bits
0xFFFFFFFF80000000 * 0xFFFFFFFF80000000 = 0x4000000000000000
0x4000000000000000 * 3 = 0xC000000000000000 - -4611686018427387904
What you observe here may be the result of ambiguity in the specification, thus leaving this to an implementation issue. I am not savvy enough with the standards to provide a definitive answer. You can affect the desired result with the insertion of additional casting:
(long long)(int(t*t))
assuming that was your desired result.
Jim Dempsey
This is UB, According to C++11 standard, Chapter 5, note 4
If during the evaluation of an expression, the result is not mathematically defined or not in the range of
representable values for its type, the behavior is undefined.
if you compile with O0 you get expected 12,12 since it uses real registers. BTW GCC up to 4.7 have different output (-4611686044197191668,12)
But was is a rationale with playing with integer overflow?
Vladimir
jimdempseyatthecove (Blackbelt) wrote:IMHO (t*t) should produced an intermediary result of the type of t
0 * 3 = 0, thus Y2 should have been 0, not 12When promoting one or both of the numbers to 64 bits
Jim Dempsey
Sorry for the previous ambigious statement, t is -2147483646, not -2147483648.
-2147483646 = 0x80000002
If the expression is ((long long)(t * t) * 3), it will first play with integer overflow because (t*t) produce an int and then cast int to long long.
0x80000002 * 0x80000002 = 0x3FFFFFFE00000004(integer overflow)
0x00000004 * 3 = 0x0000000C
So, the result is 12.
If the expression is (((long long)t) * t * 3), it will first cast int to long long and then multiply 3.
0x0000000080000002 * 0x80000002 =0x3FFFFFFE00000004
0x3FFFFFFE00000004 * 3 = 0xBFFFFFFA0000000C
So, the result is -4611686044197191668, which is 0xBFFFFFFA0000000C’s decimal.
In the above program, T is equal to VALUE and it does the same operation, which is ((long long)(x * x) * 3). According to the rules, they should produce the same result 12, but ((long long)(VALUE * VALUE) * 3) = 12, and ((long long)(t * t) * 3) = -4611686044197191668. I wonder why they produce different results ?
Xing.
Vladimir Polin (Intel) wrote:This is UB, According to C++11 standard, Chapter 5, note 4
representable values for its type, the behavior is undefined.if you compile with O0 you get expected 12,12 since it uses real registers. BTW GCC up to 4.7 have different output (-4611686044197191668,12)
Vladimir
So is this an optimization problem for the icc compiler?
>>...since it uses real registers
The operations always use real registers.
IMHO, the (t*t) should have been computed using 32-bit registers, then promoted to 64-bit register.
This said, I suggest using an unambiguous cast: (long long)(int(t*t))
Jim Dempsey
jimdempseyatthecove (Blackbelt) wrote:>>...since it uses real registers
Of course this is my wrong statement:) I meant in O0 mode everything is computed in runtime using 32 bit registers without optimizations, in optimized mode the result is precompiled and loaded directly to result register without re-computation
Vladimir
qu, xing wrote:So is this an optimization problem for the icc compiler?
No, everything is according to C++ standard: garbage in -> garbage out. Standard says if you have an integer overflow an execution/compiler behavior is undefined.
Vladimir
Vladimir,
The problem isn't just integer overflow. In this particular case, the code (as was written) is relying on the integer overflow to be properly masked off at 32-bits.
qu, xing parenthesized (t*t) which should have produced a 32-bit intermediary result (granted with overflow, which should have been discarded). The compiler should not have performed the promotion to 64-bits until after the parenthetical operation had completed.
Consider for the moment the consequence of;
(long long)(t << 8) // rely on bits shifted out of 32-bit value and into the bit bucket (no different from overflows to be delegated to bit bucket)
Where initial value of t is 0xFF000001
The result should be 0x0000000000000100
Jim Dempsey
Well, first of all a programmer should follow the C++ standard. If the standard says UB then both gcc and icc are following the standard in their (gcc in more expected and icc in less expected) way :-)
Try this version which promotes "t" first and removes UB:
#include <stdio.h> #define VALUE (0x7FFFFFF & (U1 * 3ll) + 2) int main(void) { long long Y, Y2; int U1; int t; U1 = -2147483648; Y = ((long long)(VALUE * VALUE) * 3); t = VALUE; Y2 = (0x7FFFFFF & ((long long)(t)*(t))) * 3; if (Y != Y2) printf("%lld,%lld\n", Y, Y2); return 0; }
Vladimir
The point is not how to remove the UB.
Rather the point is the compiler is not generating code that produces/uses the precision of the parenthesized expression. This is in error.
Your line 13 is not the correct form of the original post expression. you have:
not Y2 = (0x7FFFFFF & ((long long)((t)*(t)))) * 3;
or Y2 = (0x7FFFFFF & ((long long)(t*t))) * 3;
In your case, the position of the up-cast was ambiguous, and thus permitted to be implementation defined
In the OP's case, ((long long)(t*t), there is no ambiguity as to how to perform the statement.
Jim Dempsey
jimdempseyatthecove (Blackbelt) wrote:Your line 13 is not the correct form of the original post expression. you have:
So you think if the answer for _int64(t*t) will be "3" instead of "4" it will be a correct UB result?
No, it is not. It is corrected from the starter post to remove standard's UB.
It is worth mentioning that ((long long)(t * t) * 3) will be "12" when there is no VALUE.
Testcase:
#include <stdio.h>
int main(void)
long long Y2;
int t;
t = -2147483646;
Y2 = ((long long)(t * t)) * 3;
printf("%lld\n",Y2);
return 0;
The OS is:
Compiler Version:
Output:
12
Thanks for your explanation.
Now I know that the expression Y2 = ((long long)(t * t) * 3) will play with overflow and produce an undefined behavior according to C11. And the expression Y2 = (0x7FFFFFF & ((long long)(t)*(t))) * 3 will remove the UB.
But the point I really want to make is that Y2 = ((long long )(t * t) * 3) should have the same result as Y = ((long long)(VALUE * VALUE) * 3). Both are ‘12’ or ‘-4611686044197191668’. Because they have the same operation. Even if they produce an undefined behavior, the behavior should be the same.
Let us know if this is still an issue. Otherwise, we will close it.
We will no longer respond to this thread.
If you require additional assistance from Intel, please start a new thread. Any further interaction in this thread will be considered community only.
