I receive an error: "inclusive_scan directive must be closely nested inside a simd loop directive" when I compile the following code.
// Prefix Scan Example - Worksharing Scan
// scan.h
// after McCool etal. (2012)
#include <omp.h>
template <typename T>
int incl_scan(
const T* in, // source data
T* out, // output data
int size, // size of data sets
T initial // initial value
int nt{ 1 };
#pragma omp parallel
nt = omp_get_num_threads();
#pragma omp for reduction(inscan, +:initial)
for (int i = 0; i < size; i++) {
initial += in[i];
#pragma omp scan inclusive(initial) // error flagged here
out[i] = initial;
return nt;
int excl_scan(
int nt{ 1 };
for (int i = 0; i < size - 1; i++) {
out[i] = initial;
#pragma omp scan exclusive(initial) // error flagged here
initial += in[i];
out[size - 1] = initial;
return nt;
template <typename T, typename S>
int scan(
int size, // size of source, output data sets
S scan_fn, // scan function (inclusive or exclusive)
return scan_fn(in, out, size, T(0));
// Workshop 4 - Prefix Scan - Serial
// scan.cpp
// 2020.10.12
// Chris Szalwinski
#include <iostream>
#include <chrono>
#include "scan.h"
// report system time
void reportTime(const char* msg, std::chrono::steady_clock::duration span) {
auto ms = std::chrono::duration_cast<std::chrono::microseconds>(span);
std::cout << msg << " - took - " <<
ms.count() << " microseconds" << std::endl;
int main(int argc, char** argv) {
if (argc > 2) {
std::cerr << argv[0] << ": invalid number of arguments\n";
std::cerr << "Usage: " << argv[0] << "\n";
std::cerr << "Usage: " << argv[0] << " power_of_2\n";
return 1;
std::cout << "Worksharing Prefix Scan" << std::endl;
// initial values for testing
const int N = 9;
const int in_[N]{ 3, 1, 7, 0, 1, 4, 5, 9, 2 };
// command line arguments - none for testing, 1 for large arrays
int n, nt{ 1 };
if (argc == 1) {
n = N;
else {
n = 1 << std::atoi(argv[1]);
if (n < N) n = N;
int* in = new int[n];
int* out = new int[n];
// initialize
for (int i = 0; i < N; i++)
in[i] = in_[i];
for (int i = N; i < n; i++)
in[i] = 1;
auto add = [](int a, int b) { return a + b; };
std::chrono::steady_clock::time_point ts, te;
// Inclusive Prefix Scan - Remove Startup Cost
scan(in, out, n, incl_scan<int>, (int)0);
ts = std::chrono::steady_clock::now();
nt = scan(in, out, n, incl_scan<int>, (int)0);
te = std::chrono::steady_clock::now();
std::cout << nt << " thread" << (nt > 1 ? "s" : "") << std::endl;
std::cout << out[i] << ' ';
std::cout << out[n - 1] << std::endl;
reportTime("Inclusive Scan", te - ts);
// Exclusive Prefix Scan
nt = scan(in, out, n, excl_scan<int>, (int)0);
reportTime("Exclusive Scan", te - ts);
std::cout << 0 << ' ';
for (int i = 0; i < N - 1; i++)
std::cout << out[n - 2] << std::endl;
delete[] in;
delete[] out;
My code for no worksharing compiles successfully
// Prefix Scan Example - SIMD Scan
// scan.cpp
#include <omp.h>
int incl_scan(
#pragma omp simd reduction(inscan, +:initial)
initial += in[i];
out[i] = initial;
return 1; // 1 thread
int excl_scan(
if (size > 0) {
out[i] = initial;
initial += in[i];
int scan(
S scan_fn, // scan function (exclusive or inclusive)
I don't understand the error message: 'simd' where there is no simd directive.
Any thoughts?
Chris
Try adding simd to your parallel for
#pragma omp for simd reduction(inscan, +:initial)
etc...
Jim Dempsey
I've tried adding simd but no joy:
int incl_scan(
int nt = 1;
initial += in[i];
out[i] = initial;
return nt; // 1 thread
int excl_scan(
int nt = 1;
if (size > 0) {
out[i] = initial;
initial += in[i];
return nt;
Same error message at the scan directives: ??clusive_scan directive must be closely nested inside a simd loop directive
Chris
While I cannot address your compiler issue regarding the reduction(inscan...), I can address the topic of a parallel inclusive scan:
https://software.intel.com/content/www/us/en/develop/articles/elusive-algorithms-parallel-scan.html
Jim Dempsey
Thanks for reaching out to us. We are forwarding this issue to the SME. They will get back to you.
Warm Regards,
Abhishek
Seems like an issue with icpc. Let me work with our Compiler Developer.
Here is a smaller test case; compiled with g++ (8.1.0)
$ g++ -fopenmp scan.cpp
$ icpc -fopenmp scan.cpp
scan.cpp(7): error: inclusive_scan directive must be closely nested inside a simd loop directive
detected during instantiation of "int incl_scan(const T *, T *, int, T) [with T=int]" at line 21
compilation aborted for scan.cpp (code 2)
$ cat scan.cpp
int incl_scan( const T* in, T* out, int size, T initial) {
for (int i = 0;; i++) {
out[i] = initial;
int scan(const T* in, T* out,int size,S scan_fn, T initial)
return size ;
int n;
This simplification removes the for construct that was present in the original question
Here is the simplified version, which encounters the same error : inclusive_scan directive must be closely nested inside a simd loop directive
// scan.h
#include <omp.h>
int incl_scan(
int nt{ 1 };
initial += in[i];
out[i] = initial;
return nt;
// scan.cpp
// 2020.10.12
// Chris Szalwinski
#include <iostream>
#include "scan.h"
const int n = 9;
int* in = new int[n] { 3, 1, 7, 0, 1, 4, 5, 9, 2 };
incl_scan(in, out, n, (int)0);
delete[] in;
delete[] out;
Chris
This a coding issue. The test case doesn't compile with gcc10 or clang11
You can try those compilers on https://godbolt.org/, and will see these error messages.
<source>: In function 'int incl_scan(const T*, T*, int, T)':
<source>:7:10: error: '#pragma omp scan' may only be used in a loop construct with 'inscan' 'reduction' clause
7 | #pragma omp scan inclusive(initial)
<source>: In function 'int incl_scan(const T*, T*, int, T) [with T = int]':
<source>:11:1: warning: control reaches end of non-void function [-Wreturn-type]
11 | }
Compiler returned: 1
Our Developer said: "It looks like gcc was fixed to issue this message in 2019. The pragma over the for loop isn't correct. Also the for loop shouldn't be nested in a block."
Thanks for the test case. We'll look into it.
Hi Chris,
Is it possible to use icpx instead of icpc?
Not sure if you are aware of, but Intel Classic Compiler will enter "Legacy Product Support" mode, signaling the end of regular updates. For that reason, we won't fix this issue in icpc. Please migrate your code to icx/icpx.
I am going to close this thread as "wont fix".
Sorry for the inconvenience.
