Intel® C++ Compiler
7873 Discussions
Seg Fault with Gromacs gmx grompp command
Gedaliah_W_
This problem is consistent with the following gromacs/compiler versions:
Gromacs 2019.4/Intel Parallel Studio 2019.4
Gromacs 2019.4/Intel 2017.2
Gromacs 2018.2/Intel Parallel Studio 2019.4
Gromacs 2018.5/Intel Parallel Studio 2019.4
The command to build and install gromacs in all cases is
export CC=icc
export CXX=icpc
export FC=ifort
cmake ..  -DGMX_FFT_LIBRARY=mkl \
                  -DCMAKE_INSTALL_PREFIX=$HOME/sw/gromacs/intel/<version>  &&  make VERBOSE=1 && make install
The gcc version in the PATH is 5.4.0
The OS is:
Scientific Linux release 6.10 (Carbon)
I am running the lysozyme tutorial: http://www.mdtutorials.com/gmx/lysozyme/
The command that seg faults is
gmx grompp -f ions.mdp -c 1AKI_solv.gro -p topol.top -o ions.tpr -maxwarn 2
The gmx grompp command succeeds when using a version of gromacs compiled with GCC
Any help would be greatly appreciated.
Viet_H_Intel
We would need to have a reproducible test case to investigate.
Gedaliah_W_
What other information do you need?
Viet_H_Intel
An attached test case that we can compile and execute to see the SegFault
