I'm building the HDF4 library (version 4.2.10) and am encountering a segfault in icc 15.0.0.090 while compiling one file in particular:
/bin/sh ../../libtool --tag=CC --mode=compile icc -DHAVE_CONFIG_H -I. -DBIG_LONGS -DSWAP -O3 -ip -xHost -fPIC -O -MT dfconv.lo -MD -MP -MF .deps/dfconv.Tpo -c -o dfconv.lo dfconv.c libtool: compile: icc -DHAVE_CONFIG_H -I. -DBIG_LONGS -DSWAP -O3 -ip -xHost -fPIC -O -MT dfconv.lo -MD -MP -MF .deps/dfconv.Tpo -c dfconv.c -fPIC -DPIC -o .libs/dfconv.o ": internal error: ** segmentation violation signal raised ** Access violation or stack overflow. Please contact Support. compilation aborted for dfconv.c (code 4)
I can work around it by either turning off optimisation for that file using -O0 or using an earlier version of the compiler (14.3.174). Since I can workaround it, I didn't feel like digging through the source to find what was causing it, but since it's an ICE if you want to investigate it it's <basedir>/hdf/src/dfconv.c.
This is the version of icc that has the problem:
13:36 bjm900@raijin5 ~ > icc -V Intel(R) C Intel(R) 64 Compiler XE for applications running on Intel(R) 64, Version 15.0.0.090 Build 20140723 Copyright (C) 1985-2014 Intel Corporation. All rights reserved.
And this is the version that doesn't:
13:37 bjm900@raijin5 ~ > icc -V Intel(R) C Intel(R) 64 Compiler XE for applications running on Intel(R) 64, Version 14.0.3.174 Build 20140422 Copyright (C) 1985-2014 Intel Corporation. All rights reserved.
Cheers,
Ben
@Ben,
FYI. This issue is fixed in our mainline already. I have verified with the nightly build.
Shenghong
Hi Ben,
Thank you for reporting your issue here, I can reproduce your issue. The issue occurs when ICC is trying to optimize the routine DFKNTsize. I wil track the issue and ask dev team to fix in future versions.
Shenghong
As a side note it seems that ICC is handling its ICE without relying on OS to collect dump file.
Take a look at the source code, the function is really easy, it just contains some "switch/case" for a int parameter and return some constant values.
At the beginning, I thought the error is caused by too many switch/case statements, but after some testing, that is not the root cause, it looks like to be related to some of these "values". See below issue report:
/* ICC Version: Version 15.0.0.090 Build 20140723 Reproduce: icc foo.c -c -O1 Works with: icc foo.c -c -O0 */ int foo(int v) { switch (v) { // If I remove one of below case statement, it works. // If I change one of the value from 0x00001000 to another one, example 0x00001100, it works // If I change one of the return statement to "break", it works. case (0x00001000 | 1): return (1); case (0x00001000 | 2): return (1); case (0x00001000 | 3): return (1); case (0x00001000 | 4): return (1); case (0x00001000 | 5): return (1); // If I remove one of below case statement, it works. case 1: break; case 2: break; case 3: break; case 4: break; case 5: break; case 6: break; case 7: break; case 8: break; case 9: break; default: break; } return (-1); }
As it is a internal crash error inside ICC, I will leave more investigation work for developer and update you if there is a fix.
Shenghong
@Ben,
Shenghong
Thanks for investigating it Shenghong.
Cheers,
Ben
FYI. This issue is fixed in 2015 update 1 release.
# icc -V Intel(R) C Intel(R) 64 Compiler XE for applications running on Intel(R) 64, Version 15.0.1.133 Build 20141023 Copyright (C) 1985-2014 Intel Corporation. All rights reserved. #
Shenghong
