Intel® C++ Compiler
7956 Discussions
Segmentation fault for -O0 compilation
Dny
Hello All,
I'm running a test code using icc 11.0.074.
Following is my test code. It very sample code to sum the array element.
#include
#include
#include
#define SIZE 1024 // Size = 1G
int main(int argc, char *argv[])
float *a; //DB Init
long i,size=0,j;
float sum=0;
int k=0;
sscanf(argv[1], "%ld", &size);
a=(float *) malloc (sizeof(float)* size);
if (a == NULL){
printf("\n\n ERROR: Memory Allocation not possible\n\n");
exit(-1);
for(i=0;i a=k;
k=(k+1)%10;
for ( i =0 ; i < size; i++){
sum+=a;
// printf("\n # of Element= %ld, Sum = %f\n",size, sum );
printf("\n Addition Complete, # of Element= %ld\n", size);
free((void *)a);
return 0;
I observe that when I compiled using default flag, its working properly.
When I disabled optimization using flag -O0, it working for array size 10000, but unfortunately its giving segmentation fault error for size 100000.
See the output below
$ ./a.out 10000
Addition Complete, # of Element= 10000
$ ./a.out 100000
Segmentation fault
Can you please give any suggestion for this?
Thanking you,
Dny.
Om_S_Intel
Themalloc() declaration in stdlib.h is as as given below:
void * malloc ( size_t size );
The compiler must know the function signature to handle it properly. If we do not provide declarion to compiler, the compiler assumes that the value returned by the fuction is integer. This is called implicit declaration.
The implicit declaration will force void ponterreturned frommallocto integer, the integer is converted again to float pointer. These conversions results in improper value for returned memeory address and the application crashes.
jimdempseyatthecove
Try
a=(float *) malloc (sizeof(float)* (size+4));
If that fails, increase 4 to 128.
Your original code should not have failed.
If increasing the size to include padd space then this may indicate a compiler problem.
If the error persists then this may be some other problem
Just prior to allocation print out the value of size.
Following the allocation, on successful allocation, print a message indicating allocation succeeded and print the value of the pointer returned. The value may be significant (it could be junk).
Then following that print out
printf("probing a[0]n");
a[0] = 0.;
printf("probing a[%ld]n", size-1);
a[size-1] = 0.;
printf("probing succeededn");
Jim Dempsey
Dny
Try
a[0] = 0.;
a[size-1] = 0.;
Jim Dempsey
Hello Sir,
Thanks for your reply,
Yes , you are right its returning me garbage pointer for allocating 100,000 elements.
As you suggested I tried increasing size by 128 but it doesn't help.
Following is my modified source code and output below it.
[cpp]#include
#include
#include
        float *a; //DB Init
        long i,size=0,j;
        float sum=0;
        int k=0;
        printf("n Size before Allocation = %ldn",size);
        a=(float *) malloc (sizeof(float)* (size+128));
        if (a == NULL){
            printf("nn ERROR: Memory Allocation not possiblenn");
                exit(-1);
        else
                printf("Value of return pointer after memory allocation = %ld",a);
                printf("nn probing a[0]n");
                a[0] = 0.;
                a[size-1] = 0.;
                return 0;
        for(i=0;i< size; i++){
                        sum+=a;
//      printf("n # of Element= %ld, Sum = %fn",size, sum );
        printf("n Addition Complete, # of Element= %ldn", size);
        free((void *)a);
        return 0;
[/cpp]
$ icc -O0 mytest1.c
$ ./a.out 100000
Size before Allocation = 100000
Value of return pointer after memory allocation = -1788305392
probing a[0]
Segmentation fault
$ icc mytest1.c
$ ./a.out 100000
Value of return pointer after memory allocation = 182895288336
probing a[0]
probing a[99999]
probing succeeded
Can you give please give more suggestions?
Thanking you,
Dny
Om_S_Intel
It seems malloc() isimplicitly declared. When I included "stdlib.h" header, the issue is resolved.
Dny
Hello Sir,
Thanks for your reply and answer.
The issue is resolved.
Can you please explain what does "malloc() isimplicitly declared" means and why it was giving error, and how does "stdlib.h" helped?
Thanking you,
Dny
Om_S_Intel
srimks
New Contributor II
Omkar very true, to confirm more plz have a look on asm as generated for -O0 -
movl -20(%rbp), %eax #26.7
movl %eax, -48(%rbp) #26.7
fildl -48(%rbp) #26.7
fstps -32(%rbp) #26.2
movss -32(%rbp), %xmm0 #26.2
movq -56(%rbp), %rax #26.4
movq -64(%rbp), %rdx #26.2
movss %xmm0, (%rdx,%rax,4) #26.2
movl -20(%rbp), %eax #27.5
incl %eax #27.7
movl $10, %edx #27.2
movl %edx, -40(%rbp) #27.10
cltd #27.10
movl -40(%rbp), %ecx #27.10
idivl %ecx #27.10
movl %edx, -20(%rbp) #27.2
incq -56(%rbp) #25.17
movq -56(%rbp), %rax #25.10
movq -80(%rbp), %rdx #25.12
cmpq %rdx, %rax #25.12
jl ..B1.8 # Prob 50% #25.12
You can also check the .S for same section for default (-O2).
Somehow, people do miss trivial things, so the issue was simply calling proper system header file.
Personally, when any things works for higher level optimization of any compilers, normally in maximum, it should also work for lower level too, which means when above code works for -O2, it should work for -O0 also as these instructions are all tested.
Jim, I think you also missed the thought process in making out the call for header file rather pointing towards Compiler as a bug.
~BR
