We try to debug on Xeon Phi the code which contains the following code construction:
[cpp]
#include <iostream>
#include <memory.h>
#include <immintrin.h>
using namespace std;
void f( float* _amatr)
__m512 a;
a = _mm512_load_ps(_amatr+1);
_mm512_store_ps(_amatr+1, a);
int main(int argc, char* argv[])
__attribute__((aligned(64))) float _amatr[256];
for(int i=0; i<256; i++)
_amatr = i+1;
f(_amatr);
cout<<"It works\\n";
return 0;
[/cpp]
This code is successfully built with any compilers flags.
Application normally runs only when it built with code optimisation (without additional flags, or with anyone optimistaion flags: -O1, -O2, -O3),
[bash]
icpc -mmic PhiFunc.cpp
scp a.out mic0:~
ssh mic0
./a.out
It works
[/bash]
but segnentation fault error appears when we try to run this code compiled with -O0.
[bash]
icpc -mmic -O0 PhiFunc.cpp
scp a.out mic0:~
ssh mic0
./a.out
Segmentation fault
[/bash]
And major problem is impossibility debugging our complicated code because it have to use -O0 flag.
Hi Vitaly,
Since _amatr[0] is 64-byte aligned, _amatr[1] is not. And you attempted to load with _mm512_load_ps (at line #8), which requires your address 64-by-aligned. debugger indicates that too. See below. The reason why you didn't get a seg fault at -O2 is that icc removed the function call to f() in dead code removal phase.
$ idbc_mic -tco -rconnect=tcpip:mic0:2000
(idb) idb file-remote /root/a.out
(idb) file ~/temp/a.out
Reading symbols from /root/temp/a.out...done.
(idb) run
Starting program: /root/temp/a.out
[New Thread 17611 (LWP 17611)]
Program received signal SIGSEGV
f (_amatr=0x7fff0b86a3c0) at /root/temp/func.cpp:8
8 a = _mm512_load_ps(_amatr+1);
(idb)
Vitaly, please do not make the same post into multiple forums. For others that are reading this, use zmmintrin.h in place of xmmintrin.h and use the unaligned load and store (_mm512_loadu_ps).
Jim Dempsey
