I'm having trouble compiling code with icc 2016 update 3 on a clean install of 64-bit Ubuntu 16.04 [icc version 16.0.3 (gcc version 5.0.0 compatibility)]. In many (but by no means all) cases it produces a binary which immediately gives a segfault on execution. The simplest case I have found occurs when compiling with the flag -lirng, but I think it is a deeper problem as I have also observed it in other circumstances when -lirng is not used.
Steps to reproduce:
main.c:
#include <stdio.h> int main() { printf("Hello\n"); return 0; };
Then
icc main.c -o main.x -lirng ./main.x Segmentation fault (core dumped)
LD_LIBRARY_PATH is:
/opt/intel/compilers_and_libraries_2016.3.210/linux/compiler/lib/intel64: /opt/intel/compilers_and_libraries_2016.3.210/linux/mkl/lib/intel64: /opt/intel/compilers_and_libraries_2016.3.210/linux/mpi/intel64/lib: /opt/intel/compilers_and_libraries_2016.3.210/linux/mpi/mic/lib: /opt/intel/compilers_and_libraries_2016.3.210/linux/compiler/lib/intel64: /opt/intel/compilers_and_libraries_2016.3.210/linux/compiler/lib/intel64_lin: /opt/intel/compilers_and_libraries_2016.3.210/linux/mpi/intel64/lib: /opt/intel/compilers_and_libraries_2016.3.210/linux/mpi/mic/lib: /opt/intel/compilers_and_libraries_2016.3.210/linux/ipp/lib/intel64: /opt/intel/compilers_and_libraries_2016.3.210/linux/compiler/lib/intel64: /opt/intel/compilers_and_libraries_2016.3.210/linux/mkl/lib/intel64: /opt/intel/compilers_and_libraries_2016.3.210/linux/tbb/lib/intel64/gcc4.4: /opt/intel/debugger_2016/libipt/intel64/lib: /opt/intel/compilers_and_libraries_2016.3.210/linux/daal/lib/intel64_lin: /opt/intel/compilers_and_libraries_2016.3.210/linux/daal/../tbb/lib/intel64_lin/gcc4.4: /opt/intel/compilers_and_libraries_2016.3.210/linux/daal/../compiler/lib/intel64_lin
The gdb backtrace is as follows:
Starting program: /home/twk/tmp/executable-3/main.x Program received signal SIGSEGV, Segmentation fault. 0x00007ffff720b729 in ?? () (gdb) bt #0 0x00007ffff720b729 in ?? () #1 0x00007ffff7de4423 in elf_machine_rela (skip_ifunc=<optimised out>, reloc_addr_arg=<optimised out>, version=0x0, sym=<optimised out>, reloc=0x7ffff6d12e38, map=0x7ffff7fdba08) at ../sysdeps/x86_64/dl-machine.h:310 #2 elf_dynamic_do_Rela (skip_ifunc=<optimised out>, lazy=<optimised out>, nrelative=<optimised out>, relsize=<optimised out>, reladdr=<optimised out>, map=0x7ffff7fdba08) at do-rel.h:170 #3 _dl_relocate_object (scope=<optimised out>, reloc_mode=<optimised out>, consider_profiling=<optimised out>, consider_profiling@entry=0) at dl-reloc.c:258 #4 0x00007ffff7ddaf5b in dl_main (phdr=<optimised out>, phnum=<optimised out>, user_entry=<optimised out>, auxv=<optimised out>) at rtld.c:2072 #5 0x00007ffff7df0462 in _dl_sysdep_start (start_argptr=start_argptr@entry=0x7fffffffcac0, dl_main=dl_main@entry=0x7ffff7dd89a0 <dl_main>) at ../elf/dl-sysdep.c:249 #6 0x00007ffff7ddbe7a in _dl_start_final (arg=0x7fffffffcac0) at rtld.c:307 #7 _dl_start (arg=0x7fffffffcac0) at rtld.c:413 #8 0x00007ffff7dd7cc8 in _start () from /lib64/ld-linux-x86-64.so.2 #9 0x0000000000000001 in ?? () #10 0x00007fffffffcee1 in ?? () #11 0x0000000000000000 in ?? ()
ldd ./main.x: linux-vdso.so.1 => (0x00007fff9df23000) libirng.so => /opt/intel/compilers_and_libraries_2016.3.210/linux/compiler/lib/intel64/libirng.so (0x00007fee66312000) libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007fee65ff0000) libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1 (0x00007fee65dda000) libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007fee65a10000) libdl.so.2 => /lib/x86_64-linux-gnu/libdl.so.2 (0x00007fee6580c000) libintlc.so.5 => /opt/intel/compilers_and_libraries_2016.3.210/linux/compiler/lib/intel64/libintlc.so.5 (0x00007fee655a0000) /lib64/ld-linux-x86-64.so.2 (0x000056146db8f000)
I appreciate that Ubuntu 16.04 is not yet officially supported by the Intel compilers, but I would be very grateful if you could confirm you see the same problem and let me know if there is any workaround for the issue.
Hi Tom,
We are working on getting the env for Ubuntu 16.04 setup and reproduce this problem.
Thanks and Regards
Anoop
i have compile the Sample with the icc 17.0 from Intel Parallel Studio XE Beta update 1 on following Linux OS:
1) openSUSE 13.3 64 Bit Tumbleweed Kernel 4.6.2
2) openSUSE Leap 42.1 / 42.2 64 Bit
3) SUSE Enterprise Server 12 SP 1
and 4) Fedora 23 no Problems , no Errors all works fine , i think its seems a Problem from Ubuntu 16.04
Franz
We can reproduce this problem and have notified the compiler engineering on this. Thanks for reporting this issue. Once we are officially compatible with Ubuntu 16.04, this problem should go away. Will keep you posted when we start supporting Ubuntu 16.04.
Thanks and Regards
Anoop
Thanks for looking into this Anoop. Do you know if the plan is to make Intel 2016 officially compatible with Ubuntu 16.04 via an update or will this start with Intel 2017? (and is there an estimated release date for 2017?)
Tom
I am experiencing the same issue. Spent a long time debugging this only to land up here :(
icc (ICC) 16.0.3 20160415
Michael
PS: fwiw
icc (ICC) 15.0.6 20151119
works fine
Hi Michael,
I've found that falling back to 16.0.2 also avoids the problem if that helps.
Tom
Same issue here. I'm in process of setting up a supported platform that also has a Phi coprocessor, but that is, unfortunately, several weeks away and I've been struggling with this issue for a month now. I guess I'll fall back to 16.2 for the time being.
icc version 16.0.4 fails also... quite disappointing to see Intel ignoring this problem for so long :(
It is confined to linking stage, not using icc as linker works fine. i.e. using gcc with
gcc -o test test.o -L/opt/intel/compilers_and_libraries_2016.4.258/linux/compiler/lib/intel64 -lintlc -lirng
works.
Not adding libirng.so avoids the issue as this seems to be related with the dynamic linker failing to initialize it and crashing when linked with icc.
p.s.
besides this excellent example to isolate the issue this happens in "real" programs too e.g. wavpack.
icc 17 does work so after some testing I found that replacing under compilers_and_libraries_2016.4.258/linux/compiler/lib/intel64_lin the file
libintlc.so.5
with the one from 16.0.2 (perhaps best) or the newest 17.0.0 can fix this issue. Hopefully, no other problems are introduced...
I have not tested but it is very likely the same must be done for the redistributable libraries as well.
