Hello everyone, I am experiencing a nasty bug with icpc version 19.0.1.144. When compiling the following code, that I am also attaching,
class nseh12_cell_integral_0_0 { public: virtual void tabulate_tensor(double* A, const double * const * w) const; }; void nseh12_cell_integral_0_0::tabulate_tensor(double* A, const double * const * w) const { static const double FE0_D001[14][2] = \ {{-1.0, 1.0}, {-1.0, 1.0}, {-1.0, 1.0}, {-1.0, 1.0}, {-1.0, 1.0}, {-1.0, 1.0}, {-1.0, 1.0}, {-1.0, 1.0}, {-1.0, 1.0}, {-1.0, 1.0}, {-1.0, 1.0}, {-1.0, 1.0}, {-1.0, 1.0}, {-1.0, 1.0}}; static const unsigned int nzc2[2] = {0, 1}; static const unsigned int nzc1[2] = {0, 2}; A[0] = 0.0; for (unsigned int ip = 0; ip < 14; ip++) { double F0 = 0.0; double F1 = 0.0; for (unsigned int r = 0; r < 2; r++) { F0 += FE0_D001[ip]*w[1][nzc2 ]; F1 += FE0_D001[ip] *w[1][nzc1 ]; }// end loop over 'r' double I[1]; I[0] = F0*F1; A[0] += I[0]; }// end loop over 'ip' }
I get
$ icpc -c NSEH12.cpp ": internal error: ** The compiler has encountered an unexpected problem. ** Segmentation violation signal raised. ** Access violation or stack overflow. Please contact Intel Support for assistance. icpc: error #10105: /cfs/klemming/pdc.vol.beskow/intel/19.0.1.144/compilers_and_libraries_2019.1.144/linux/bin/intel64/mcpcom: core dumped icpc: warning #10102: unknown signal(1029699696) icpc: error #10106: Fatal error in /cfs/klemming/pdc.vol.beskow/intel/19.0.1.144/compilers_and_libraries_2019.1.144/linux/bin/intel64/mcpcom, terminated by unknown compilation aborted for NSEH12.cpp (code 1)
This used to work with icpc v17 and stopped with v18, so it seems to be a regression.
Can anyone reproduce it and, if yes, report the bug upstream?
By the way, compiling with
$ icpc -fast -c NSEH12.cpp
works fine.
Thanks and best regards,
Massimiliano Leoni
- Tags:
- Bug
- CC++
- Development Tools
- Intel® C++ Compiler
- Intel® Parallel Studio XE
- Intel® System Studio
- Optimization
- Parallel Computing
- Vectorization
Hi Massimiliano,
We are able to reproduce the error which you are facing. We will forward this issue to the concerned team.
Goutham
I have reported this bug to our compiler Developer (CMPLRIL0-32645). Thanks
Thanks for your patience. The issue raised by you has been fixed in the latest OneAPI version 2021.2. Please download and let us know your experience with it.
We haven't heard back from you. Please let us know your feedback after testing the latest version.
Prasanth
We are closing this thread as the issue has been resolved in the latest version.
We will no longer respond to this thread. If you require additional assistance from Intel, please start a new thread. Any further interaction in this thread will be considered community only
Prasanth
