Intel® C++ Compiler
Set the environment variables
grasswater
I installed the compiler as root user, and everything is fine after setting enviroment.
Latter I login as normal user and I want to run the compiler. I set the inviroment as told: $ source install-dir/bin/compilervars.sh intel64.
Error information is :
PROD_DIR=/opt/intel/composer_xe_2011_sp1.8.273: Command not found.
if: Expression Syntax.
I am new to linux and intel C++ compiler.Any hints? Thank you!
Georg_Z_Intel
which shell ($SHELL) are you using? If you use CSH use compilervars.csh instead.
Thanks & best regards,
Georg Zitzlsberger
Georg_Z_Intel
Georg Zitzlsberger
grasswater
Thank you very much! I though normal user and root user would use same type of shell.
TimP
That's entirely up to the administrator. In either case, you can open the shell of your choice, and your scripts should have their shell specified.
