Intel® C++ Compiler
Support and discussions for creating C++ code that runs on platforms based on Intel® processors.
Setting gcc version
marko_l_
I have several versions of gcc installed on my system, the latest, 8.1.0 is not compatible with Intel's compiler (18 update 3). So I've been trying to convince the compiler to compile using an older version of gcc. I've tried setting
-gxx-name=g++-7
to the command line options, but was greeted by an error:
icpc: error #10417: Problem setting up the Intel(R) Compiler compilation environment.  Requires 'C++ include files' setting gathered from '/usr/bin/g++-7'
I've been unable to find a reliable solution. What other options should I set?
Bastian_B_
Hi Marko,
I don't know if this is the 'official' way to do it, but I've had success with:
$ export GXX_INCLUDE=/usr/lib/gcc/x86_64-pc-linux-gnu/6.4.1/include/c++
$ icc -gcc-name=gcc-6 ...
$ icpc -gxx-name=g++-6 ...
Cheers
Bastian
Viet_H_Intel
Hi Mark,
Please set -gxx-name=/usr/bin/g++-7/bin/g++
Viet
marko_l_
Hi Viet!
That directory does not exist on my system, g++-7 is the binary available in /usr/bin/. What exactly is the compiler trying to find?
Best, Marko
Viet_H_Intel
HI Marko,
It tries to find the name and location of g++. Please set it to an existing location.
Viet
marko_l_
Hi Viet
It does find "g++-7", if I set it to something that does not exist I get a different error:
icpc: error #10417: Problem setting up the Intel(R) Compiler compilation environment.  Requires 'install path' setting gathered from 'g++test'
Also, setting it to the absolute path (although /usr/bin/ is in PATH so this should not matter) "/usr/bin/g++-7" gives the same error as using "g++-7". So apparently it can find the install path but then fails to find the relevant include files.
Best,
Marko
Bastian_B_
Hi Marko,
Cheers
Bastian
Daniel_H
Bastian B. wrote:
Hi Marko,
Cheers
Bastian
Thanks Bastian
Exactly what I was looking for. Until now I was relying on a systemd-nspawn based sub-system to compile. I did also expect that "-gxx-name" would be sufficient to give icpc a full access to the full environment.
Daniel
marko_l_
That seems to do the trick, thank you Bastian!
My makefile is a little uglier than it used to be but at least now I can compile again.
Marko
sahoo__sadashiv
Hi
I have installed intel parallel studio xe 2019 5 update
I want to use intel c++ compiler as a default c++ in my ubuntu 18.04
so I have done this in my bashrc
export CC=icc
export LD_SHARED="icc -shared
but when when I am doing ./configure  its show the g++ gnu 7.4.0 rather than icpc or icc the
please tell me how to make my default c++ and python compiler as intel compiler
pythia8:http://home.thep.lu.se/Pythia/
http://home.thep.lu.se/~torbjorn/pythia8/pythia8243.tgz
best,
sadashiv
Viet_H_Intel
did your source /installed_dir/bin/iccvars.sh intel64
sahoo__sadashiv
yes I did
