How do I share a variable in a parallel loop.
I.e.:
#pragma omp parallel for
for(i=0;i {
for(j=0;j {
indigo=array1*array2;
sausage=sqrt(indigo);
array3=sausage;
The problem is that sausage and indigo need to be independent for each thread. Now I guess I could use the thread number and the total number of threads to somehow create an array for each indigo and sausage but I'm sure there's something built into openmp where you can just say "give each thread their own version of indigo and sausage".
Any ideas?
AFAIK, #pragma omp parallel for private(indigo, sausage)
but I'm a newbie, so dont trust me.
Not only do sausage and indigo need to be thread private but also j needs to be thread private.
An alternate way from using the private or shared on the pragman is to declare the private variables inside the scope of the parallel loop.
for(i=0;i { // i private by default
int j; // private j
for(j=0;j {
// private indego
float indigo=array1*array2;
// private sausage
float sausage=sqrt(indigo);
array3=sausage;
Note, variables j, indigo and sausage are declared inside the scope of the parallel loop and therefore will be stack local to each thread.
A cautionary note.
Often a programmer may code a loop with an early exit and that the code following the major loop will examine the index variable to see if it expired early. This will not work in parallel programming. Instead you should use a shared variable to indicate an abnormal exit.
volatile bool abEnd = FALSE;
for(i=0;i {
int j; // seperate j per thread
for(j=0;j {
array3=sausage;
// do not remove following if expression
// i.e. do not use "abEnd = fpInvalid(sausage);"
// as other thread may clear the abEnd
if(fpInvalid(sausage)) abEnd = TRUE;
// do test outside statement scope of above if
// because other thread may have abEnded.
if(abEnd) break;
if(abEnd) break;
if(abEnd) doAbEndProcess();
Where fpInvalid tests for NaN, overflow, and or other non-sensical results.
Jim Dempsey
Jim, when you write code blocks here be sure to replace < with & lt ; and > with & gt ; (just remove spaces around lt and gt) or it will get mangled beyond recognition.
