Intel® C++ Compiler
7956 Discussions
Should I mark my short functions as "inline"?
jlperla
With Intel 11.1 on windows, I haven't been marking my functions as "inline" when I would guess they probably should be. I hear that compilers often ignore the directive and choose on their own when it makes sense. Is this safe to assume here?
TimP
By default, the compiler looks for the most attractive opportunities for inter-procedural optimization, including in-lining. If, as I do, you prefer to disable the whole program link-time optimization (/Qipo), setting /Qip makes it more aggressive for in-lining among functions in a single source file. There are other options in the help file to control in-lining thresholds. If you know that a function should be in-lined, it may be helpful to so mark it.
JenniferJ
As Tim says, it's depending on what options you used.
1. /Ob0: no inlining at all. "inline" keyword does not matter
2. /Ob1: "inline" will help, and some C++ inlining (default constructs etc.)
3. /Ob2: more than /Ob1; and compiler will do more aggressive inlining as well for small fundtions without "inline" if the small functions are in the same file (compiling unit)
4. /Qipo: more than /Ob2, for small functions that are even in other files.
There is a default setting for "small" functions. But it's controlable as well using the following options:
/Qinline-min-size: set size limit for inlining small routines
/Qinline-min-size- no size limit for inlining small routines
/Qinline-max-size: set size limit for inlining large routines
/Qinline-max-size- no size limit for inlining large routines
/Qinline-max-total-size:maximum increase in size for inline function expansion
/Qinline-max-total-size- no size limit for inline function expansion
/Qinline-max-per-routine: maximum number of inline instances in any function
/Qinline-max-per-routine- no maximum number of inline instances in any function
/Qinline-max-per-compile: maximum number of inline instances in the current compilation
/Qinline-max-per-compile- no maximum number of inline instances in the current compilation
/Qinline-factor: set inlining upper limits by n percentage
/Qinline-factor- do not set set inlining upper limits
/Qinline-forceinline treat inline routines as forceinline
/Qinline-dllimport allow(DEFAULT)/disallow functions declared __declspec(dllimport) tobe inlined
/Qinline-calloc directs the compiler to inline calloc() calls as malloc()/memset()
Note: those fine tune optimization optionsare only available in the 11.x professional edition of the Intel C++ Compiler.
Jennifer
