Intel® C++ Compiler
7952 Discussions
Simple program using wide strings won't link using OneAPI Classic/Visual Studio 2019/C++17
AndrewC
New Contributor III
Intel® C++ Compiler Classic – toolkit version: 2021.4.0, extension version 19.2.8.16, Package ID: w_oneAPI_2021.4.0.364
Set the C++ compiler language to C++17
I have reported this bug numerous times for 2 years.
It makes, for example, using std::filesystem impossible
#include <string>
int main()
std::wstring a(L"abc");
std::wstring b(L"cde");
bool result = a == b;
testwstring.obj : : error LNK2019: unresolved external symbol wmemcmp referenced in function "public: static int __cdecl std::_WChar_traits<wchar_t>::compare(wchar_t const * const,wchar_t const * const,unsigned __int64)
HemanthCH_Intel
The Intel C++ Classic Compiler will enter "Legacy Product Support" mode signaling the end of regular updates. For more details please refer to the below link:
https://www.intel.com/content/www/us/en/developer/articles/technical/adoption-of-llvm-complete-icx.html
In the below link, a workaround is provided. You can use the workaround for this issue or you can migrate to the ICX compiler.
https://community.intel.com/t5/Intel-C-Compiler/Intel-C-19-1-Link-error-unresolved-Symbol-with-C-17/td-p/1179168
However, this issue is not shown in the ICX Compiler. So, could you please try to use the ICX compiler and let us know whether your issue is resolved or not?
Thanks & Regards,
Hemanth.
HemanthCH_Intel
We are able to reproduce your issue at our end using oneAPI 2021.4, VS 2019 16.10.3 on Windows Machine.
But, you can use "/MT" option as the workaround for resolving your issue.
In visual studio, go to Project >>properties >>C/C++ >> Commandline and add "/MT" in the "additional options" as shown in screenshot attached.
Thanks & Regards,
Hemanth.
AndrewC
New Contributor III
Changing to /MT is not an option for us ( or likely anyone else). That's a completely different runtime  as opposed to /MD and incompatible with most other libraries and code.
My frustration is that I reported this maybe 2 years ago through the official support channel.
The workaround is to  define a version of _wmemcmp in a separate file
As I said, it makes using <filesystem> not possible which is quite annoying and we have to  use boost::filesystem as an alternate
HemanthCH_Intel
We are working on your issue and will get back to you soon.
Thanks & regards,
Hemanth.
HemanthCH_Intel
Thanks & Regards,
Hemanth.
AndrewC
New Contributor III
I confirm the issue is not present when using "Intel Compiler 2021".
I realize there is a workaround to add a user defined function to satisfy the linker issue.
Since this will not get fixed I will use either of these options.
HemanthCH_Intel
Thanks for accepting our solution. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Thanks & Regards,
Hemanth.
