Intel® C++ Compiler
Support and discussions for creating C++ code that runs on platforms based on Intel® processors.
The Intel sign-in experience is changing in February to support enhanced security controls. If you sign in, click here for more information.
7747 Discussions
Simple wstring comparison causes link failure on Windows. VS 2019 16.7 , ICC 19.1 Update 4
AndrewC
New Contributor III
#include <string>
int main()
std::wstring a(L"abc");
std::wstring b(L"cde");
bool result = a == b;
error LNK2019: unresolved external symbol wmemcmp
This was reported a year ago, and re-reported at each release. It makes <filesystem> pretty useless.
PrasanthD_intel
Hi Andrew,
Could you please specify for which version of Visual studio you are getting this issue? You have already mentioned the version as 16.7 but I need the subversion too in format 16.7.x, so I can upgrade to that specific version and check.
I have already tested your code with 2020u4 compiler on VS 16.3 and found no errors.
Prasanth
PrasanthD_intel
Hi Andrew,
We haven't heard back from you. Please let us know the Visual Studio version you are getting this bug.
I am providing a document for reference to check which Visual Studio version should be used for each Parallel studio version. I have tested the code in Visual Studio 16.7.2, which according to the document is the latest compatible version, and found no errors.
https://software.intel.com/content/www/us/en/develop/articles/intel-compilers-compatibility-with-mic...
Prasanth
AndrewC
New Contributor III
You are correct the problem appears to be fixed in the latest 19.1 Update
PrasanthD_intel
Hi Andrew,
Thanks for the confirmation.
We are closing this thread; we will no longer monitor the thread. Please raise a new thread if you have any further queries. any discussion will be considered community only
Prasanth
