Intel® C++ Compiler
7876 Discussions
Simple wstring comparison causes link failure on Windows. VS 2019 16.7 , ICC 19.1 Update 4
AndrewC
New Contributor III
#include <string>
int main()
std::wstring a(L"abc");
std::wstring b(L"cde");
bool result = a == b;
error LNK2019: unresolved external symbol wmemcmp
This was reported a year ago, and re-reported at each release. It makes <filesystem> pretty useless.
PrasanthD_intel
Hi Andrew,
Could you please specify for which version of Visual studio you are getting this issue? You have already mentioned the version as 16.7 but I need the subversion too in format 16.7.x, so I can upgrade to that specific version and check.
I have already tested your code with 2020u4 compiler on VS 16.3 and found no errors.
Prasanth
PrasanthD_intel
Hi Andrew,
We haven't heard back from you. Please let us know the Visual Studio version you are getting this bug.
I am providing a document for reference to check which Visual Studio version should be used for each Parallel studio version. I have tested the code in Visual Studio 16.7.2, which according to the document is the latest compatible version, and found no errors.
https://software.intel.com/content/www/us/en/develop/articles/intel-compilers-compatibility-with-microsoft-visual-studio-and-xcode.html
Prasanth
AndrewC
New Contributor III
You are correct the problem appears to be fixed in the latest 19.1 Update
PrasanthD_intel
Hi Andrew,
Thanks for the confirmation.
We are closing this thread; we will no longer monitor the thread. Please raise a new thread if you have any further queries. any discussion will be considered community only
Prasanth
