Intel® C++ Compiler
Support and discussions for creating C++ code that runs on platforms based on Intel® processors.
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
For the latest information on Intel’s response to the Log4j/Log4Shell vulnerability, please see Intel-SA-00646
7597 Discussions
Solution for Broken compilervars.sh with zsh (on MacOS 10.15.7) after latest compiler update.
FDuncanH
The most recent version of the shell script compilervars.sh added a section  to
remove duplicate paths.     Its fine for bash, but breaks zsh (whis no default in MacOS.
"echo $(!arg) "  is incorrect  syntax in  the zshell scripting.
 I found the fix below ,   It might be useful for anyone using zhell on macos.
Broken script
------------------function remove_duplicate_paths----------------------------
remove_duplicate_paths() {
local arg=$1
if [ "${INTEL_HOST_PLATFORM}" = "Darwin" ]; then
local arr=(`echo ${!arg} | sed 's/:/\'$'\n/g'`)
else
local arr=(`echo ${!arg} | sed 's/:/\n/g'`)
fi
fixed script below
# ------------------function remove_duplicate_paths----------------------------
local arg=$1
eval "value=\"\${$arg}\""
local arr=(`echo ${value} | sed 's/:/\'$'\n/g'`)
else
fi
GouthamK_Intel
Thanks for reporting this issue and providing the workaround.
We will forward this thread to the concerned internal team to verify and get it fixed accordingly if possible.
Have a Good day!
Thanks & Regards
Goutham
Viet_H_Intel
I've reported this to our Developer.
Ron_Green
Kerry_K_
Thanks, I confirm this worked for me on 10.15.7 with zsh.  Now onto the next problems with updating macos+intel+openmpi...
Minoru1
Thank you so much for your more beneficial advice so that I could work around the same as problem in my case.
$ source .zshrc (return)
After this command, there is nothing such as error messages at all.
PrasanthD_intel
Thanks for the confirmation.
As your issue has been resolved, we are closing this thread. We will no longer respond to this thread. If you require additional assistance from Intel, please start a new thread. Any further interaction in this thread will be considered community only
Prasanth
