Community
cancel
Showing results for
Search instead for
Did you mean:
Solution for Broken compilervars.sh with zsh (on MacOS 10.15.7) after latest compiler update.
The most recent version of the shell script compilervars.sh added a section  to
remove duplicate paths.     Its fine for bash, but breaks zsh (whis no default in MacOS.
"echo $(!arg) "  is incorrect  syntax in  the zshell scripting.
 I found the fix below ,   It might be useful for anyone using zhell on macos.
Broken script
------------------function remove_duplicate_paths----------------------------
remove_duplicate_paths() {
local arg=$1
if [ "${INTEL_HOST_PLATFORM}" = "Darwin" ]; then
local arr=(`echo ${!arg} | sed 's/:/\'$'\n/g'`)
else
local arr=(`echo ${!arg} | sed 's/:/\n/g'`)
fi
fixed script below
# ------------------function remove_duplicate_paths----------------------------
local arg=$1
eval "value=\"\${$arg}\""
local arr=(`echo ${value} | sed 's/:/\'$'\n/g'`)
else
fi
Thanks for reporting this issue and providing the workaround.
We will forward this thread to the concerned internal team to verify and get it fixed accordingly if possible.
Have a Good day!
Thanks & Regards
Goutham
I've reported this to our Developer.
Thanks, I confirm this worked for me on 10.15.7 with zsh.  Now onto the next problems with updating macos+intel+openmpi...
Thank you so much for your more beneficial advice so that I could work around the same as problem in my case.
$ source .zshrc (return)
After this command, there is nothing such as error messages at all.
