I'm having trouble with the installation of the Intel C++ Compiler for Linux (not in /opt but in /usr because of the available disk space).
Here is the content of the log file (same issue with C++) :
Adrien
Solved : I installed libstdc++5 and it works now. Sorry...
Intel C Compiler for applications running on IA-32, Version 10.1 Build 20080312 Package ID: l_cc_p_10.1.015Copyright (C) 1985-2008 Intel Corporation. All rights reserved.
FOR NON-COMMERCIAL USE ONLY
/usr/intel/cc/10.1.015/bin/mcpcom: error while loading shared libraries: libstdc++.so.5: cannot open shared object file: No such file or directory
compilation aborted for /tmp/install_cc.sh15059/test_cc.15059.c (code 127)
Problems with C compiler: <>!=
Linux OS : Debian 4.0
G++ version : g++ (GCC) 4.1.2 20061115 (prerelease) (Debian 4.1.1-21)
And if I try to compile C++ code with icpc I've got the same error.
What can I do ?
Thanks in advance for your answer.
Adrien
