Intel® C++ Compiler
Starting Guide
Swapnil_J_
Hello Firend,
      I am new in Xe_sudio composer of intel. I have good knowlege of Parallel Programing on GPU with CUDA and OPenCL. I want to learen intel xe composer icc , mkl & ipp. I have read all installtion guide and tutorial. But Can any one suggest me how will i start programing.
That Means,
How I will use single core and multiple core of my processor.
How will i divide my execution on diffrent cores.
Please Help me! I am using Intel i7 Processor.
Sukruth_H_Intel
Hi, Welcome to X86 parallel programming. I would ask you to start with our compiler User and Reference guides to know about the Intel compiler (ICC) usage. http://software.intel.com/sites/products/documentation/doclib/stdxe/2013/composerxe/compiler/cpp-mac/index.htm This document have discussed about the various Multi-Threading models supported by Intel ICC compiler, Using which you can take advantage of running your code efficiently on all the available cores of your system. Have you purchased an Intel compiler or any other suite like Parallel studio and so on? Or you can download the evaluation copy from http://software.intel.com/en-us/intel-parallel-studio-XE-2013-evaluation-options . Please feel free to put up your queries. Regards, Sukruth H V
Swapnil_J_
It's very good i want more. Please I am checking Sample example
SergeyKostrov
Valued Contributor II
Take a look at a folder [ CompilerDIR ]\Samples\en_US\C++... ( or so ) and you could find there several C/C++ examples.
Georg_Z_Intel
Hello, take a look at our Content Library: http://software.intel.com/en-us/search/site Search for everything you're interested in (e.g. OpenMP*, Intel(R) Threading Building Blocks, Intel(R) Cilk(TM) Plus, ...). Make sure to select the proper filters as you'll get flooded with results otherwise. I suggest to filter for either "Article", "Blog post" and "Courseware". Those three also can contain interesting examples. Best regards, Georg Zitzlsberger
Swapnil_J_
Swapnil_J_
Hello, Can anyone give me link where all mkl Liberary function WITH DESCRIPTION available? I have read following link http://software.intel.com/sites/products/documentation/hpc/mkl/mkl_userguide_lnx/index.htm
TimP
I've been searching myself, and I don't think there is a single satisfactory guide to "all" MKL functions. In several categories (e.g. BLAS, LAPACK, fftw), compatibility with open source libraries is maintained so literature on those libraries is applicable. Specific questions about MKL should be posed on the MKL forum http://software.intel.com/en-us/forums/intel-math-kernel-library Unfortunately, today I don't see the additional references which ought to be at the top of that forum.
Swapnil_J_
Okey, Thank You very Much!!! :)
Swapnil_J_
When I have installed Intel XE COMPOSER it will give me following messages. ERROR: Package is corrupted. Installation cannot continue. Like follow (But i have downloaded from Intel site) Please tell me what i have to do? Step no: 6 of 7 | Installation -------------------------------------------------------------------------------- Each component will be installed individually. If you cancel the installation, components that have been completely installed will remain on your system. This installation may take several minutes, depending on your system and the options you selected. -------------------------------------------------------------------------------- Installing Amplifier XE Command line interface component... ERROR: Package is corrupted. Installation cannot continue. -------------------------------------------------------------------------------- Installing Inspector XE Command line interface component... ERROR: Package is corrupted. Installation cannot continue. -------------------------------------------------------------------------------- Installing Advisor XE Command line interface component... ERROR: Package is corrupted. Installation cannot continue. -------------------------------------------------------------------------------- Installing Intel C++ Compiler XE 13.0 Update 1 on IA-32 component... failed -------------------------------------------------------------------------------- Installing Intel C++ Compiler XE 13.0 Update 1 on Intel(R) 64 component... done -------------------------------------------------------------------------------- Installing Intel Debugger 13.0 Update 1 on IA-32 component... failed -------------------------------------------------------------------------------- Installing Intel Debugger 13.0 Update 1 on Intel(R) 64 component... done -------------------------------------------------------------------------------- Installing Intel Math Kernel Library 11.0 Update 1 on IA-32 component... failed -------------------------------------------------------------------------------- Installing Intel Math Kernel Library 11.0 Update 1 on Intel(R) 64 component... done -------------------------------------------------------------------------------- Installing Intel Integrated Performance Primitives 7.1 Update 1 on IA-32 component... failed -------------------------------------------------------------------------------- Installing Intel Integrated Performance Primitives 7.1 Update 1 on Intel(R) 64 component... done -------------------------------------------------------------------------------- Installing Intel Threading Building Blocks 4.1 Update 1 core files and examples component... done -------------------------------------------------------------------------------- Finalizing installation... done --------------------------------------------------------------------------------
Georg_Z_Intel
Hello, in that case I'd recommend to download it again. There are known issues where the download is interrupted. Please, always verify the size of the downloaded tar-ball. And, in addition you can compare the MD5 sum with the latest Intel(R) Composer XE 2013 Update 1 packages: [bash] $ md5sum l_ccompxe_2013.1.117.tgz 8796a1a1e5c98107ca69c75a7aa2b379 l_ccompxe_2013.1.117.tgz $ md5sum l_fcompxe_2013.1.117.tgz 355c201ef30167580e5b0dfc217fbbe8 l_fcompxe_2013.1.117.tgz [/bash] Use the link "Start download with a download manager" when downloading the packages. This should always work. Best regards, Georg Zitzlsberger
Swapnil_J_
Thanks, i will Download new file and then i will try to install it.
Swapnil_J_
Hi Friend Georg Zitzlsberger, I am trying to write program that calculate the aggregate sum of vector element. Example suppose A={1,2,3,4,5,6,7,8,9,0} Result = 45 i got max through put time 140 to 150 milliseconds for 600,000,000 (600 million number) Can we reduce time for execution time? I have write following program. #include #include #include #include unsigned int compute(unsigned int i) { return i; // return a value computed from i } int main(int argc, char* argv[]) { unsigned int n = 400000000; int *A = (int *)malloc(sizeof(int)*n); for(unsigned int i = 0; i < n; i++) { A=1; } cilk::reducer_opadd total; // Compute 1..n std::clock_t start = std::clock(); cilk_for(unsigned int i = 0; i <= n; ++i) { total += A; } std::cout << "Total (" << total.get_value() << ") is correct"; std::cout << "Total Time : "<<( double( std::clock() - start ) /double(CLOCKS_PER_SEC/1000)) <<'\n'; return 0; } Command for execution : #icc -fast -prallel filename.c filename
Swapnil_J_
Is there any MKL function for aggregate sum of vector element?
TimP
Do you mean the BLAS ?sum functions? Evidently, with only 9 elements, those will be slower than any reasonable in-lined method, such as accumulate() or __sec_reduce_add(). Even the compilers' inline optimizations for sum reduction optimization may not be effective for such a short vector, and it may be worth while to prevent the compiler using AVX. If you succeed in forcing threading on such a small case, you may succeed in running slower than MKL.
Swapnil_J_
yes friend i had given only sample example of program i have used 600,000,000 element and find sum of that number and it was giving result in 140 to 150 ms i want more optimzation.
Georg_Z_Intel
Hello, I doubt that this simple example has much room for improvements. The compiler should already create sufficiently fast code. Using threading for this (trivial) workload is likely overhead. Intel(R) Cilk(TM) Plus runtime takes care about the right balancing of grain size, though. Hence, I don't see further room for improvement that would justify the effort for this example. Best regards, Georg Zitzlsberger
Swapnil_J_
Means, It's an optimized code Thanks,
Swapnil_J_
How will i Download videos from www.software.intel.com?
Georg_Z_Intel
Hello, you cannot download the videos. You need a Flash* player to view them. Best regards, Georg Zitzlsberger
jimdempseyatthecove
A common practice is to reduce the frequency of reductions: [cpp] #include "stdafx.h" #include #include #include #include #include #include int _tmain(int argc, _TCHAR* argv[]) { unsigned int n = 400000000; int *A = (int *)malloc(sizeof(int)*n); for(unsigned int i = 0; i < n; i++) { A=1; } cilk::reducer_opadd total; // Compute 1..n total.set_value(0); clock_t start = clock(); cilk_for(unsigned int i = 0; i < n; ++i) { total += A; } std::cout << "Total (" << total.get_value() << ") is correct"; std::cout << "Total Time : "<< ( double( clock() - start ) /double(CLOCKS_PER_SEC/1000)) << '\n'; //============== total.set_value(0); start = clock(); cilk_for(unsigned int i = 0; i < n; i+=65536) { unsigned int jend = std::min(i + 65536, n); int my_total = 0; for(unsigned int j=i; j < jend; ++j) my_total += A; total += my_total; } std::cout << "Total (" << total.get_value() << ") is correct"; std::cout << " Total Time : "<< ( double( clock() - start ) /double(CLOCKS_PER_SEC/1000)) << '\n'; return 0; } [/cpp] Total (400000000) is correctTotal Time : 2944 Total (400000000) is correct Total Time : 354 Jim Dempsey
