I have Intel Composer 2012 XE with Intel IPP 7.1.0.089.
I set in the project properties under Intel Libraries - "Use IPP: Single Threaded Static Library".
Yet after compiling I still get dependency of 'ippcore-7.1' and only 'ippcore-7.1'.
I use Intel Compiler for the compiling process.
How could that be? How could that be resolved? I think it is a bug since I use MS Compiler I don't have that dependency (Same settings).
Moreover, If I turn off the option "Use Intel Optimized Headers" (Under Configuration Properties -> C / C++ -> Optimization [Intel C++]) the dependency is removed.
Could that be explained?
I use Windows 7 64 Bit.
All paths are defined well.
