The current version of the LLVM OpenMP runtime seems to not implement OpenMP task priorities.
Does the Intel compiler support them (eg. using another runtime compatible with the IOMP interface)?
If no, does the IOMP interface between the compiler and the runtime support this (ie. passing the information about the priority of each task to the runtime through a function call or something else)?
Thank You.
