Intel® C++ Compiler
TRACKER : : error TRK0002:
DPart1
I just installed Parallel Studio XE and just tried to build my project using Intel C++ instead of MSVC.
When I try to build I get:
1>TRACKER : : error TRK0002: Failed to execute command: ""C:\Program Files (x86)\IntelSWTools\compilers_and_libraries_2020\windows\bin\Intel64\icl.exe" @C:\Users\amonra\AppData\Local\Temp\tmpcd93e637ab564ee4b93b363a73c649f8.rsp". The parameter is incorrect.
If this is the wrong forum I apologise, but I didn't find one for Parallel Studio XE.
Thanks David
DPart1
10>    Touching ".\x64\Debug\DeepSkyStacker.tlog\unsuccessfulbuild".
10>  Done executing task "Touch".
10>Target "PrepareProjectReferences" skipped. Previously built successfully.
10>Target BuildGenerateSourcesTraverse:
10>  Task "MSBuild" skipped, due to false condition; ('$(BuildPassReferences)' == 'true' and '@(ProjectReferenceWithConfiguration)' != '' and '@(_MSBuildProjectReferenceExistent)' != '' and '%(_MSBuildProjectReferenceExistent.BuildReference)' == 'true') was evaluated as ('' == 'true' and '..\libjpg\libjpg.vcxproj;..\LibRaw\buildfiles\libraw.vcxproj;..\LibTiff\libtiff.vcxproj;..\QHTML_Static\datasource\datasource.vcxproj;..\QHTML_Static\debughlp\DebugHlp.vcxproj;..\QHTML_Static\guitools\guitools.vcxproj;..\QHTML_Static\imglib\imglib.vcxproj;..\QHTML_Static\qhtm\qhtm.vcxproj;..\ZCLass\ZCLass.vcxproj' != '' and '..\libjpg\libjpg.vcxproj;..\LibRaw\buildfiles\libraw.vcxproj;..\LibTiff\libtiff.vcxproj;..\QHTML_Static\datasource\datasource.vcxproj;..\QHTML_Static\debughlp\DebugHlp.vcxproj;..\QHTML_Static\guitools\guitools.vcxproj;..\QHTML_Static\imglib\imglib.vcxproj;..\QHTML_Static\qhtm\qhtm.vcxproj;..\ZCLass\ZCLass.vcxproj' != '' and 'true' == 'true').
10>Target "PrepareForBuild" skipped. Previously built successfully.
10>Target "ResolveReferences" skipped. Previously built successfully.
10>Target BeforeBuildGenerateSources:
10>Target PreBuildEvent:
10>  Task "Message" skipped, due to false condition; ('%(PreBuildEvent.Message)' != '' and '%(PreBuildEvent.Command)' != '') was evaluated as ('' != '' and '' != '').
10>  Task "Exec" skipped, due to false condition; ('%(PreBuildEvent.Command)' != '') was evaluated as ('' != '').
10>Target "CustomBuild" skipped, due to false condition; ('@(CustomBuild)' != '') was evaluated as ('' != '').
10>Target "FxExport" skipped, due to false condition; ('@(FxCompile)' != '') was evaluated as ('' != '').
10>Target "FxCompile" skipped, due to false condition; ('@(FxCompile)' != '') was evaluated as ('' != '').
10>Target "_CreateCopyFileItems" skipped, due to false condition; ('@(CopyFileToFolders)' != '') was evaluated as ('' != '').
10>Target "InitializeBuildStatus" skipped. Previously built successfully.
10>Target "SetBuildDefaultEnvironmentVariables" skipped. Previously built successfully.
10>Target "SetUserMacroEnvironmentVariables" skipped. Previously built successfully.
10>Target _SelectedFiles:
10>Target CopyFileToFolders:
10>  Using "GetOutOfDateItems" task from assembly "C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\Common7\IDE\VC\VCTargets\Microsoft.Build.CppTasks.Common.dll".
10>  Task "GetOutOfDateItems"
10>  Done executing task "GetOutOfDateItems".
10>  Task "Copy" skipped, due to false condition; ('@(_OutOfDateCopyFile)' != '') was evaluated as ('' != '').
10>Target "Xsd" skipped, due to false condition; ('@(Xsd)' != '') was evaluated as ('' != '').
10>Target _Xsd:
10>Target MakeDirsForMidl:
10>  Task "Makedir"
10>  Done executing task "Makedir".
10>Target "Midl" skipped, due to false condition; ('@(Midl)' != '') was evaluated as ('' != '').
10>Target ComputeMIDLGeneratedCompileInputs:
10>Target AfterMidl:
10>Target _Midl:
10>Target AfterBuildGenerateSources:
10>Target AfterBuildGenerateSourcesEvent:
10>Target _BuildGenerateSourcesAction:
10>Target BuildGenerateSources:
10>Target BuildCompileTraverse:
10>Target MessageBuildingWithCompiler:
10>  Using "ICMessage" task from assembly "C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\Common7\IDE\VC\VCTargets\Intel.Build.ICLTasks.v150.dll".
10>  Task "ICMessage"
10>    Building with Intel(R) C++ Compiler 19.1
10>  Done executing task "ICMessage".
10>Target WarningAboutICInstallDir:
10>  Task "ICMessage" skipped, due to false condition; ('$(ICInstallDir)'=='' AND '$(UseEnv)' != 'true') was evaluated as ('C:\Program Files (x86)\IntelSWTools\compilers_and_libraries_2020\windows\'=='' AND '' != 'true').
10>Target BeforeClCompile:
10>Target "ComputeMIDLGeneratedCompileInputs" skipped. Previously built successfully.
10>Target ComputeCLInputPDBName:
10>Target ComputeReferenceCLInput:
10>  Task "WriteLinesToFile" skipped, due to false condition; (('@(_ReferenceCopyLocalPaths)'!='') and '$(DesignTimeBuild)' != 'true') was evaluated as ((''!='') and '' != 'true').
10>  Task "Message" skipped, due to false condition; ('$(_REFERENCE_DEBUG)'=='true') was evaluated as (''=='true').
10>Target WarnCompileDuplicatedFilename:
10>  Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'BitmapSlider.cpp' != 'BitmapSlider.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10>  Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'BtnST.cpp' != 'BtnST.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10>  Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'ButtonToolbar.cpp' != 'ButtonToolbar.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10>  Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'cdxCRot90DC.cpp' != 'cdxCRot90DC.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10>  Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'cdxCRotBevelLine.cpp' != 'cdxCRotBevelLine.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10>  Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'cgfiltyp.cpp' != 'cgfiltyp.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10>  Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'childprop.cpp' != 'childprop.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10>  Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'ControlPos.cpp' != 'ControlPos.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10>  Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'CtrlCache.cpp' != 'CtrlCache.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10>  Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'CustomTabCtrl.cpp' != 'CustomTabCtrl.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10>  Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'FolderDlg.cpp' != 'FolderDlg.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10>  Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'Gradient.cpp' != 'Gradient.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10>  Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'GradientCtrl.cpp' != 'GradientCtrl.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10>  Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'GradientCtrlImpl.cpp' != 'GradientCtrlImpl.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10>  Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'Label.cpp' != 'Label.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10>  Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'ListViewCtrlEx.cpp' != 'ListViewCtrlEx.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10>  Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'Registry.cpp' != 'Registry.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10>  Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'RegMFC.cpp' != 'RegMFC.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10>  Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'RichToolTipCtrl.cpp' != 'RichToolTipCtrl.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10>  Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'ScrollDialog.cpp' != 'ScrollDialog.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10>  Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'SplitterControl.cpp' != 'SplitterControl.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10>  Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'ThemeUtil.cpp' != 'ThemeUtil.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10>  Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'ToolTipButton.cpp' != 'ToolTipButton.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10>  Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'WndImage.cpp' != 'WndImage.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10>  Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'About.cpp' != 'About.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10>  Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'AHDDemosaicing.cpp' != 'AHDDemosaicing.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10>  Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'AlignmentParameters.cpp' != 'AlignmentParameters.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10>  Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'AskRegistering.cpp' != 'AskRegistering.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10>  Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'BackgroundCalibration.cpp' != 'BackgroundCalibration.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10>  Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'BackgroundLoading.cpp' != 'BackgroundLoading.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10>  Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'BackgroundOptions.cpp' != 'BackgroundOptions.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10>  Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'BatchStacking.cpp' != 'BatchStacking.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10>  Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'BitmapExt.cpp' != 'BitmapExt.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10>  Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'ChannelAlign.cpp' != 'ChannelAlign.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10>  Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'CheckAbove.cpp' != 'CheckAbove.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10>  Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'CometStacking.cpp' != 'CometStacking.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10>  Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'CosmeticEngine.cpp' != 'CosmeticEngine.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10>  Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'DarkFrame.cpp' != 'DarkFrame.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10>  Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'DeBloom.cpp' != 'DeBloom.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10>  Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'DeepSkyStacker.cpp' != 'DeepSkyStacker.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10>  Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'DeepStack.cpp' != 'DeepStack.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10>  Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'DeepStackerDlg.cpp' != 'DeepStackerDlg.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10>  Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'Delaunay.cpp' != 'Delaunay.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10>  Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'DropFilesDlg.cpp' != 'DropFilesDlg.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10>  Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'EntropyInfo.cpp' != 'EntropyInfo.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10>  Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'ExplorerBar.cpp' != 'ExplorerBar.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10>  Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'FileProperty.cpp' != 'FileProperty.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10>  Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'Filters.cpp' != 'Filters.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10>  Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'FitsFilesTab.cpp' != 'FitsFilesTab.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10>  Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'FITSUtil.cpp' != 'FITSUtil.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10>  Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'FlatFrame.cpp' != 'FlatFrame.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10>  Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'FrameInfo.cpp' != 'FrameInfo.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10>  Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'FrameList.cpp' != 'FrameList.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10>  Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'ImageSinks.cpp' != 'ImageSinks.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10>  Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'IntermediateFiles.cpp' != 'IntermediateFiles.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10>  Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'Library.cpp' != 'Library.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10>  Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'LibraryDlg.cpp' != 'LibraryDlg.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10>  Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'LuminanceTab.cpp' != 'LuminanceTab.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10>  Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'MasterFrames.cpp' != 'MasterFrames.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10>  Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'MatchingStars.cpp' != 'MatchingStars.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10>  Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'MultiBitmapProcess.cpp' != 'MultiBitmapProcess.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10>  Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'Multitask.cpp' != 'Multitask.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10>  Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'OutputTab.cpp' != 'OutputTab.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10>  Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'PCLTools.cpp' != 'PCLTools.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10>  Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'PictureListCtrl.cpp' != 'PictureListCtrl.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10>  Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'PostCalibration.cpp' != 'PostCalibration.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10>  Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'ProcessingDlg.cpp' != 'ProcessingDlg.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10>  Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'ProcessSettingsSheet.cpp' != 'ProcessSettingsSheet.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10>  Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'ProgressDlg.cpp' != 'ProgressDlg.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10>  Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'RawDDPSettings.cpp' != 'RawDDPSettings.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10>  Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'RawFilesTab.cpp' != 'RawFilesTab.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10>  Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'RAWUtils.cpp' != 'RAWUtils.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10>  Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'RecommandedSettings.cpp' != 'RecommandedSettings.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10>  Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'RegisterEngine.cpp' != 'RegisterEngine.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10>  Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'RegisterSettings.cpp' != 'RegisterSettings.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10>  Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'RegisterSettings_Actions.cpp' != 'RegisterSettings_Actions.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10>  Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'RegisterSettings_Advanced.cpp' != 'RegisterSettings_Advanced.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10>  Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'ResultParameters.cpp' != 'ResultParameters.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10>  Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'RGBTab.cpp' != 'RGBTab.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10>  Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'RunningStackingEngine.cpp' != 'RunningStackingEngine.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10>  Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'SaturationTab.cpp' != 'SaturationTab.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10>  Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'SaveEditChanges.cpp' != 'SaveEditChanges.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10>  Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'SavePicture.cpp' != 'SavePicture.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10>  Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'Settings.cpp' != 'Settings.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10>  Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'SettingsDlg.cpp' != 'SettingsDlg.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10>  Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'SetUILanguage.cpp' != 'SetUILanguage.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10>  Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'StackedBitmap.cpp' != 'StackedBitmap.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10>  Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'StackingDlg.cpp' != 'StackingDlg.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10>  Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'StackingEngine.cpp' != 'StackingEngine.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10>  Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'StackingParameters.cpp' != 'StackingParameters.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10>  Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'StackingTasks.cpp' != 'StackingTasks.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10>  Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'StackRecap.cpp' != 'StackRecap.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10>  Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'StackSettings.cpp' != 'StackSettings.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10>  Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'StarMask.cpp' != 'StarMask.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10>  Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'StarMaskDlg.cpp' != 'StarMaskDlg.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10>  Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'StdAfx.cpp' != 'StdAfx.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10>  Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'TIFFUtil.cpp' != 'TIFFUtil.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10>  Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'Workspace.cpp' != 'Workspace.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10>Target FixupCLCompileOptions:
10>Target MakeDirsForCl:
10>  Task "MakeDir"
10>  Done executing task "MakeDir".
10>Target "PrepareDirForCodeCoverage" skipped, due to false condition; ('$(CodeCoverageOperations)' != 'Disabled' AND '$(ProfileDirectory)' != '') was evaluated as ('Disabled' != 'Disabled' AND '.\x64\Debug\' != '').
10>Target "PrepareDirForPGO" skipped, due to false condition; ('$(ProfileGuidedOptimization)' != 'Disabled' AND '$(ProfileDirectory)' != '') was evaluated as ('Disabled' != 'Disabled' AND '.\x64\Debug\' != '').
10>Target "_SelectedFiles" skipped. Previously built successfully.
10>Target "ComputeCLInputPDBName" skipped. Previously built successfully.
10>Target "ComputeReferenceCLInput" skipped. Previously built successfully.
10>Target "WarnCompileDuplicatedFilename" skipped. Previously built successfully.
10>Target "FixupCLCompileOptions" skipped. Previously built successfully.
10>Target SelectCustomBuild:
10>Target SelectClCompile:
10>Target CheckInstalledICLibsIPP:
10>  Task "ICMessage" skipped, due to false condition; ('$(IPPSingleThreaded)'=='0' AND '$(IPPMajorVersion)' != '' AND ('$(UseIntelIPP)' == 'Sequential' OR '$(UseIntelIPP)' == 'Sequential_Dynamic' OR ('$(UseIntelIPP)' == 'true' AND '%(ClCompile.OpenMP)' != 'GenerateParallelCode' AND '%(ClCompile.Parallelization)' != 'true'))) was evaluated as (''=='0' AND '' != '' AND ('false' == 'Sequential' OR 'false' == 'Sequential_Dynamic' OR ('false' == 'true' AND 'None' != 'GenerateParallelCode' AND 'false' != 'true'))).
10>  Task "ICMessage" skipped, due to false condition; ('$(IPPMultiThreaded)'=='0' AND '$(IPPMajorVersion)' != '' AND ('$(UseIntelIPP)' == 'Parallel_Static' OR '$(UseIntelIPP)' == 'Parallel_Dynamic' OR ('$(UseIntelIPP)' == 'true' AND ('%(ClCompile.OpenMP)' == 'GenerateParallelCode' OR '%(ClCompile.Parallelization)' == 'true')))) was evaluated as (''=='0' AND '' != '' AND ('false' == 'Parallel_Static' OR 'false' == 'Parallel_Dynamic' OR ('false' == 'true' AND ('None' == 'GenerateParallelCode' OR 'false' == 'true')))).
10>Target "SetICMKLEnvironment" skipped, due to false condition; ('$(UseIntelMKL)' != '' AND '$(UseIntelMKL)' != 'No' AND '$(MKLProductDir)' != '') was evaluated as ('No' != '' AND 'No' != 'No' AND '' != '').
10>Target "CheckInstalledICLibsMKL" skipped, due to false condition; ('$(UseIntelMKL)' != '' AND '$(UseIntelMKL)' != 'No') was evaluated as ('No' != '' AND 'No' != 'No').
10>Target "CheckInstalledVCLibsIPP" skipped, due to false condition; ('$(PlatformToolset)' == 'v141') was evaluated as ('Intel C++ Compiler 19.1' == 'v141').
10>Target "SetVCMKLEnvironment" skipped, due to false condition; ('$(UseIntelMKL)' != '' AND '$(UseIntelMKL)' != 'No' AND '$(PlatformToolset)' == 'v141' AND '$(MKLProductDir)' != '') was evaluated as ('No' != '' AND 'No' != 'No' AND 'Intel C++ Compiler 19.1' == 'v141' AND '' != '').
10>Target "CheckInstalledVCLibsMKL" skipped, due to false condition; ('$(UseIntelMKL)' != '' AND '$(UseIntelMKL)' != 'No' AND '$(PlatformToolset)' == 'v141') was evaluated as ('No' != '' AND 'No' != 'No' AND 'Intel C++ Compiler 19.1' == 'v141').
10>Target "GenerateTargetFrameworkMonikerAttribute" skipped, due to false condition; ('$(GenerateTargetFrameworkAttribute)' == 'true') was evaluated as ('false' == 'true').
10>Target "ManagedIncrementalBuildPreProcessDependencyGraph" skipped, due to false condition; ('@(ClCompile)' != '' and '$(EnableManagedIncrementalBuild)' == 'True') was evaluated as ('..\Tools\BitmapSlider.cpp;..\Tools\BtnST.cpp;..\Tools\ButtonToolbar.cpp;..\Tools\cdxCRot90DC.cpp;..\Tools\cdxCRotBevelLine.cpp;..\Tools\cgfiltyp.cpp;..\Tools\childprop.cpp;..\Tools\ControlPos.cpp;..\Tools\CtrlCache.cpp;..\Tools\CustomTabCtrl.cpp;..\Tools\FolderDlg.cpp;..\Tools\Gradient.cpp;..\Tools\GradientCtrl.cpp;..\Tools\GradientCtrlImpl.cpp;..\Tools\Label.cpp;..\Tools\ListViewCtrlEx.cpp;..\Tools\Registry.cpp;..\Tools\RegMFC.cpp;..\Tools\RichToolTipCtrl.cpp;..\Tools\ScrollDialog.cpp;..\Tools\SplitterControl.cpp;..\Tools\ThemeUtil.cpp;..\Tools\ToolTipButton.cpp;..\Tools\WndImage.cpp;About.cpp;AHDDemosaicing.cpp;AlignmentParameters.cpp;AskRegistering.cpp;BackgroundCalibration.cpp;BackgroundLoading.cpp;BackgroundOptions.cpp;BatchStacking.cpp;BitmapExt.cpp;ChannelAlign.cpp;CheckAbove.cpp;CometStacking.cpp;CosmeticEngine.cpp;DarkFrame.cpp;DeBloom.cpp;DeepSkyStacker.cpp;DeepStack.cpp;DeepStackerDlg.cpp;Delaunay.cpp;DropFilesDlg.cpp;EntropyInfo.cpp;ExplorerBar.cpp;FileProperty.cpp;Filters.cpp;FitsFilesTab.cpp;FITSUtil.cpp;FlatFrame.cpp;FrameInfo.cpp;FrameList.cpp;ImageSinks.cpp;IntermediateFiles.cpp;Library.cpp;LibraryDlg.cpp;LuminanceTab.cpp;MasterFrames.cpp;MatchingStars.cpp;MultiBitmapProcess.cpp;Multitask.cpp;OutputTab.cpp;PCLTools.cpp;PictureListCtrl.cpp;PostCalibration.cpp;ProcessingDlg.cpp;ProcessSettingsSheet.cpp;ProgressDlg.cpp;RawDDPSettings.cpp;RawFilesTab.cpp;RAWUtils.cpp;RecommandedSettings.cpp;RegisterEngine.cpp;RegisterSettings.cpp;RegisterSettings_Actions.cpp;RegisterSettings_Advanced.cpp;ResultParameters.cpp;RGBTab.cpp;RunningStackingEngine.cpp;SaturationTab.cpp;SaveEditChanges.cpp;SavePicture.cpp;Settings.cpp;SettingsDlg.cpp;SetUILanguage.cpp;StackedBitmap.cpp;StackingDlg.cpp;StackingEngine.cpp;StackingParameters.cpp;StackingTasks.cpp;StackRecap.cpp;StackSettings.cpp;StarMask.cpp;StarMaskDlg.cpp;StdAfx.cpp;TIFFUtil.cpp;Workspace.cpp' != '' and 'false' == 'True').
10>Target "CheckIntelEnvironmentForVCLibsDAAL" skipped, due to false condition; ('$(UseIntelDAAL)' != '' AND '$(UseIntelDAAL)' != 'false' AND '$(UseEnv)' != 'true' AND '$(PlatformToolset)' == 'v141') was evaluated as ('false' != '' AND 'false' != 'false' AND '' != 'true' AND 'Intel C++ Compiler 19.1' == 'v141').
10>Target "CheckIntelEnvironmentForVCLibsIPP" skipped, due to false condition; ('$(PlatformToolset)' == 'v141' AND '$(UseIntelIPP)' != '' AND '$(UseIntelIPP)' != 'false' AND '$(UseEnv)' != 'true') was evaluated as ('Intel C++ Compiler 19.1' == 'v141' AND 'false' != '' AND 'false' != 'false' AND '' != 'true').
10>Target "CheckIntelEnvironmentForVCLibsMKL" skipped, due to false condition; ('$(UseIntelMKL)' != '' AND '$(UseIntelMKL)' != 'No' AND '$(UseEnv)' != 'true' AND '$(PlatformToolset)' == 'v141') was evaluated as ('No' != '' AND 'No' != 'No' AND '' != 'true' AND 'Intel C++ Compiler 19.1' == 'v141').
10>Target "CheckIntelEnvironmentForVCLibsTBB" skipped, due to false condition; ('$(PlatformToolset)' == 'v141' AND '$(UseIntelTBB)' == 'true' AND '$(UseEnv)' != 'true') was evaluated as ('Intel C++ Compiler 19.1' == 'v141' AND 'false' == 'true' AND '' != 'true').
10>Target "CheckIntelEnvironmentForICLibsDAAL" skipped, due to false condition; ('$(UseIntelDAAL)' != '' AND '$(UseIntelDAAL)' != 'false' AND '$(UseEnv)' != 'true') was evaluated as ('false' != '' AND 'false' != 'false' AND '' != 'true').
10>Target "CheckIntelEnvironmentForICLibsIPP" skipped, due to false condition; ('$(UseIntelIPP)' != '' AND '$(UseIntelIPP)' != 'false' AND '$(UseEnv)' != 'true') was evaluated as ('false' != '' AND 'false' != 'false' AND '' != 'true').
10>Target "CheckIntelEnvironmentForICLibsMKL" skipped, due to false condition; ('$(UseIntelMKL)' != '' AND '$(UseIntelMKL)' != 'No' AND '$(UseEnv)' != 'true') was evaluated as ('No' != '' AND 'No' != 'No' AND '' != 'true').
10>Target "CheckIntelEnvironmentForICLibsTBB" skipped, due to false condition; ('$(UseIntelTBB)' == 'true' AND '$(UseEnv)' != 'true') was evaluated as ('false' == 'true' AND '' != 'true').
10>Target ClCompile:
10>  Task "Message"
10>    ***** ClCompile (x64 - Intel C++)
10>  Done executing task "Message".
10>  Task "Delete" skipped, due to false condition; ('%(ClCompile.DebugInformationFormat)' != '' AND '%(ClCompile.DebugInformationFormat)' != 'OldStyle' AND '%(ClCompile.ProgramDataBaseFileName)' != '' AND !Exists(%(ClCompile.ProgramDataBaseFileName))
10>               AND '%(ClCompile.UseMSVC)'!='true' AND '%(ClCompile.InterproceduralOptimization)'!='MultiFile' AND '%(ClCompile.LevelOfStaticAnalysis)'!='Brief' AND
10>               '%(ClCompile.LevelOfStaticAnalysis)'!='Medium' AND '%(ClCompile.LevelOfStaticAnalysis)'!='Verbose') was evaluated as ('ProgramDatabase' != '' AND 'ProgramDatabase' != 'OldStyle' AND 'C:\Users\amonra\Documents\GitHub\DSS\x64\Debug\DeepSkyStacker.pdb' != '' AND !Exists(C:\Users\amonra\Documents\GitHub\DSS\x64\Debug\DeepSkyStacker.pdb)
10>               AND 'false'!='true' AND 'NoIPO'!='MultiFile' AND 'None'!='Brief' AND
10>               'None'!='Medium' AND 'None'!='Verbose').
10>  Task "ICL" skipped, due to false condition; ('%(ClCompile.PrecompiledHeader)' == 'Create' AND '%(ClCompile.ExcludedFromBuild)'!='true' AND '%(ClCompile.UseMSVC)'!='true') was evaluated as ('Use' == 'Create' AND ''!='true' AND 'false'!='true').
10>  Using "ICL" task from assembly "C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\Common7\IDE\VC\VCTargets\Intel.Build.ICLTasks.v150.dll".
10>  Task "ICL"
10>    Read Tracking Logs:
10>    	.\x64\Debug\DeepSkyStacker.tlog\icl.read.1.tlog
10>    	.\x64\Debug\DeepSkyStacker.tlog\icl-mcpcom.read.1.tlog
10>    Outputs for C:\USERS\AMONRA\DOCUMENTS\GITHUB\DSS\DEEPSKYSTACKER\STDAFX.CPP:
10>    	C:\USERS\AMONRA\DOCUMENTS\GITHUB\DSS\DEEPSKYSTACKER\X64\DEBUG\STDAFX.OBJ
10>    	C:\USERS\AMONRA\DOCUMENTS\GITHUB\DSS\DEEPSKYSTACKER\X64\DEBUG\DEEPSKYSTACKER.PCHI
10>    StdAfx.cpp will be compiled because it was not found in the tracking log.
10>    Environment Variables passed to tool:
10>      VS_UNICODE_OUTPUT=2288
10>    C:\Program Files (x86)\IntelSWTools\compilers_and_libraries_2020\windows\bin\Intel64\icl.exe /c /Qm64 /I"C:\Program Files (x86)\Visual Leak Detector\include" /I.\ /I../Libraw /I..\ZClass /I..\tools /I..\LibTIFF /I..\CFitsIO /I..\Zlib /I"C:\Program Files (x86)\Visual Leak Detector\include" /Zi /nologo /W3 /WX /MP /Od /Ob0 /D __INTEL_COMPILER=1910 /D _UNICODE /D UNICODE /D NOMINMAX /D LIBRAW_NODLL /D WIN32 /D _DEBUG /D _CRT_SECURE_NO_DEPRECATE /D USE_LIBTIFF_STATIC /D Z_TRACE_DEVELOP /D _VC80_UPGRADE=0x0600 /D _MBCS /D _AFXDLL /EHsc /RTC1 /MDd /GS /fp:precise /Zc:wchar_t /Zc:forScope /GR /Qstd=c++14 /Yc"stdafx.h" /Fp".\x64\Debug\DeepSkyStacker.pch" /Fo".\x64\Debug\\" /Fd"C:\Users\amonra\Documents\GitHub\DSS\x64\Debug\DeepSkyStacker.pdb" /TP /FC StdAfx.cpp
10>    Tracking command:
10>    C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\MSBuild\15.0\Bin\Tracker.exe /d "C:\Program Files (x86)\MSBuild\15.0\FileTracker\FileTracker32.dll" /i C:\Users\amonra\Documents\GitHub\DSS\DeepSkyStacker\x64\Debug\DeepSkyStacker.tlog /r C:\USERS\AMONRA\DOCUMENTS\GITHUB\DSS\DEEPSKYSTACKER\STDAFX.CPP /b MSBuildConsole_CancelEvent8c2d7c7c6ea54eed8f62cd5cb66c1869  /c "C:\Program Files (x86)\IntelSWTools\compilers_and_libraries_2020\windows\bin\Intel64\icl.exe"  /c /Qm64 /I"C:\Program Files (x86)\Visual Leak Detector\include" /I.\ /I../Libraw /I..\ZClass /I..\tools /I..\LibTIFF /I..\CFitsIO /I..\Zlib /I"C:\Program Files (x86)\Visual Leak Detector\include" /Zi /nologo /W3 /WX /MP /Od /Ob0 /D __INTEL_COMPILER=1910 /D _UNICODE /D UNICODE /D NOMINMAX /D LIBRAW_NODLL /D WIN32 /D _DEBUG /D _CRT_SECURE_NO_DEPRECATE /D USE_LIBTIFF_STATIC /D Z_TRACE_DEVELOP /D _VC80_UPGRADE=0x0600 /D _MBCS /D _AFXDLL /EHsc /RTC1 /MDd /GS /fp:precise /Zc:wchar_t /Zc:forScope /GR /Qstd=c++14 /Yc"stdafx.h" /Fp".\x64\Debug\DeepSkyStacker.pch" /Fo".\x64\Debug\\" /Fd"C:\Users\amonra\Documents\GitHub\DSS\x64\Debug\DeepSkyStacker.pdb" /TP /FC StdAfx.cpp
10>    TRACKER : : error TRK0002: Failed to execute command: ""C:\Program Files (x86)\IntelSWTools\compilers_and_libraries_2020\windows\bin\Intel64\icl.exe" @C:\Users\amonra\AppData\Local\Temp\tmp62d68a95871943d7a8985004e1d65f7c.rsp". The parameter is incorrect.
10>
10>
10>    The command exited with code 2.
10>  Done executing task "ICL" -- FAILED.
10>Done building target "ClCompile" in project "DeepSkyStacker.vcxproj" -- FAILED.
10>
10>Done building project "DeepSkyStacker.vcxproj" -- FAILED.
10>
10>Build FAILED.
10>
10>TRACKER : : error TRK0002: Failed to execute command: ""C:\Program Files (x86)\IntelSWTools\compilers_and_libraries_2020\windows\bin\Intel64\icl.exe" @C:\Users\amonra\AppData\Local\Temp\tmp62d68a95871943d7a8985004e1d65f7c.rsp". The parameter is incorrect.
10>    0 Warning(s)
10>    1 Error(s)
10>
10>Time Elapsed 00:00:00.55
DPart1
Here's some MSBuild output that may help:
Target ClCompile:
10>  Task "Message"
10>  Task "ICL"
10>      VS_UNICODE_OUTPUT=1912
10>    C:\Program Files (x86)\IntelSWTools\compilers_and_libraries_2020\windows\bin\Intel64\icl.exe /c /Qm64 /I"C:\Program Files (x86)\Visual Leak Detector\include" /I.\ /I../Libraw /I..\ZClass /I..\tools /I..\LibTIFF /I..\CFitsIO /I..\Zlib /I"C:\Program Files (x86)\Visual Leak Detector\include" /Zi /nologo /W3 /WX /MP /Od /Ob0 /D __INTEL_COMPILER=1910 /D _UNICODE /D UNICODE /D NOMINMAX /D LIBRAW_NODLL /D WIN32 /D _DEBUG /D _CRT_SECURE_NO_DEPRECATE /D USE_LIBTIFF_STATIC /D Z_TRACE_DEVELOP /D _VC80_UPGRADE=0x0600 /D _MBCS /D _AFXDLL /EHsc /RTC1 /MDd /GS /fp:precise /Zc:wchar_t /Zc:forScope /GR /Yc"stdafx.h" /Fp".\x64\Debug\DeepSkyStacker.pch" /Fo".\x64\Debug\\" /Fd"C:\Users\amonra\Documents\GitHub\DSS\x64\Debug\DeepSkyStacker.pdb" /TP /FC StdAfx.cpp
10>    C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\MSBuild\15.0\Bin\Tracker.exe /d "C:\Program Files (x86)\MSBuild\15.0\FileTracker\FileTracker32.dll" /i C:\Users\amonra\Documents\GitHub\DSS\DeepSkyStacker\x64\Debug\DeepSkyStacker.tlog /r C:\USERS\AMONRA\DOCUMENTS\GITHUB\DSS\DEEPSKYSTACKER\STDAFX.CPP /b MSBuildConsole_CancelEvent87e97dd3b04943baa92e415f55178857  /c "C:\Program Files (x86)\IntelSWTools\compilers_and_libraries_2020\windows\bin\Intel64\icl.exe"  /c /Qm64 /I"C:\Program Files (x86)\Visual Leak Detector\include" /I.\ /I../Libraw /I..\ZClass /I..\tools /I..\LibTIFF /I..\CFitsIO /I..\Zlib /I"C:\Program Files (x86)\Visual Leak Detector\include" /Zi /nologo /W3 /WX /MP /Od /Ob0 /D __INTEL_COMPILER=1910 /D _UNICODE /D UNICODE /D NOMINMAX /D LIBRAW_NODLL /D WIN32 /D _DEBUG /D _CRT_SECURE_NO_DEPRECATE /D USE_LIBTIFF_STATIC /D Z_TRACE_DEVELOP /D _VC80_UPGRADE=0x0600 /D _MBCS /D _AFXDLL /EHsc /RTC1 /MDd /GS /fp:precise /Zc:wchar_t /Zc:forScope /GR /Yc"stdafx.h" /Fp".\x64\Debug\DeepSkyStacker.pch" /Fo".\x64\Debug\\" /Fd"C:\Users\amonra\Documents\GitHub\DSS\x64\Debug\DeepSkyStacker.pdb" /TP /FC StdAfx.cpp
10>    TRACKER : : error TRK0002: Failed to execute command: ""C:\Program Files (x86)\IntelSWTools\compilers_and_libraries_2020\windows\bin\Intel64\icl.exe" @C:\Users\amonra\AppData\Local\Temp\tmpd318524d19284c21b2737f5e940ee164.rsp". The parameter is incorrect.
10>
10>
10>
10>
10>Build FAILED.
10>
10>TRACKER : : error TRK0002: Failed to execute command: ""C:\Program Files (x86)\IntelSWTools\compilers_and_libraries_2020\windows\bin\Intel64\icl.exe" @C:\Users\amonra\AppData\Local\Temp\tmpd318524d19284c21b2737f5e940ee164.rsp". The parameter is incorrect.
10>    0 Warning(s)
10>    1 Error(s)
10>
10>Time Elapsed 00:00:00.49
========== Build: 0 succeeded, 1 failed, 9 up-to-date, 0 skipped ==========
PrasanthD_intel
Hi David,
Thanks for reporting the error.
We are forwarding your query to the concerned team.
We will get back to you soon.
Prasanth
Viet_H_Intel
What MSVS 2017 update version are you using?
It seems that this is a problem with tracker.exe.
Will Stdafx.cpp compile if you do:
And does it work if you replace icl.exe with cl.exe?
DPart1
VS2017 Community edition 15.9.14
I can't compile the rsp file as it is deleted by MsBuild on completion of the failed build.
Copyright (C) 2009-2020 Intel Corporation. All rights reserved.
Intel(R) Inspector 2020 (build 604266)
Intel(R) Advisor 2020 (build 605410)
Intel(R) Trace Analyzer and Collector 2020 Update 1 for Windows* OS for Intel(R) 64 applications
Copyright (C) 1996-2020 Intel Corporation. All rights reserved.
Intel(R) MPI Library 2019 Update 7 for Windows* Target Build Environment for Intel(R) 64 applications
Copyright 2007-2020 Intel Corporation.
Copyright (C) 1985-2019 Intel Corporation. All rights reserved.
Intel(R) Compiler 19.1 Update 1 (package 216)
** Visual Studio 2017 Developer Command Prompt v15.9.14
** Copyright (c) 2017 Microsoft Corporation
[vcvarsall.bat] Environment initialized for: 'x64'
C:\Program Files (x86)\IntelSWTools>cd \users\amonra\Documents\GitHub\DSS\DeepSkyStacker
C:\Users\amonra\Documents\GitHub\DSS\DeepSkyStacker>icl.exe /c /Qm64 /I"C:\Program Files (x86)\Visual Leak Detector\include" /I.\ /I../Libraw /I..\ZClass /I..\tools /I..\LibTIFF /I..\CFitsIO /I..\Zlib /I"C:\Program Files (x86)\Visual Leak Detector\include" /Zi /nologo /W3 /WX /MP /Od /Ob0 /D __INTEL_COMPILER=1910 /D _UNICODE /D UNICODE /D NOMINMAX /D LIBRAW_NODLL /D WIN32 /D _DEBUG /D _CRT_SECURE_NO_DEPRECATE /D USE_LIBTIFF_STATIC /D Z_TRACE_DEVELOP /D _VC80_UPGRADE=0x0600 /D _MBCS /D _AFXDLL /EHsc /RTC1 /MDd /GS /fp:precise /Zc:wchar_t /Zc:forScope /GR /Yc"stdafx.h" /Fp".\x64\Debug\DeepSkyStacker.pch" /Fo".\x64\Debug\\" /Fd"C:\Users\amonra\Documents\GitHub\DSS\x64\Debug\DeepSkyStacker.pdb" /TP /FC StdAfx.cpp
StdAfx.cpp
C:\Users\amonra\Documents\GitHub\DSS\DeepSkyStacker>cl.exe /c /Qm64 /I"C:\Program Files (x86)\Visual Leak Detector\include" /I.\ /I../Libraw /I..\ZClass /I..\tools /I..\LibTIFF /I..\CFitsIO /I..\Zlib /I"C:\Program Files (x86)\Visual Leak Detector\include" /Zi /nologo /W3 /WX /MP /Od /Ob0 /D __INTEL_COMPILER=1910 /D _UNICODE /D UNICODE /D NOMINMAX /D LIBRAW_NODLL /D WIN32 /D _DEBUG /D _CRT_SECURE_NO_DEPRECATE /D USE_LIBTIFF_STATIC /D Z_TRACE_DEVELOP /D _VC80_UPGRADE=0x0600 /D _MBCS /D _AFXDLL /EHsc /RTC1 /MDd /GS /fp:precise /Zc:wchar_t /Zc:forScope /GR /Yc"stdafx.h" /Fp".\x64\Debug\DeepSkyStacker.pch" /Fo".\x64\Debug\\" /Fd"C:\Users\amonra\Documents\GitHub\DSS\x64\Debug\DeepSkyStacker.pdb" /TP /FC StdAfx.cpp
cl : Command line warning D9002 : ignoring unknown option '/Qm64'
StdAfx.cpp
c:\program files (x86)\intelswtools\compilers_and_libraries_2020.1.216\windows\compiler\include\math.h(145): fatal error C1021: invalid preprocessor command 'include_next'
Viet_H_Intel
looks like StdAfx.cpp were able to compile with Intel Compiler.
Could be that Tracker.exe doesn't support icl.exe?
DPart1
Surely you have that the wrong way about - isn't it your job to ensure that icl.exe is compatible with the tracker?
David
DPart1
Bump - is anyone in Parallel Studio land looking at this?   If not why not?
David
Viet_H_Intel
I have been working with my team, seems like Tracker.exe isn't supported by ICL.
DPart1
Well that's a royal pain as it means I cannot build my projects using Intel Compiler
A Parallel Studio XE license I can't use doesn't feel like a good deal :(>
When might I expect a solution?
David
Viet_H_Intel
What do you see when you run: C:\temp> where icl?
DPart1
C:\Users\amonra>cd \temp
C:\temp>where icl
INFO: Could not find files for the given pattern(s).
C:\temp>
Viet_H_Intel
Please run "where icl" on a Windows which you can successfully execute icl
Viet_H_Intel
C:\temp>icl
Intel(R) C++ Intel(R) 64 Compiler for applications running on Intel(R) 64, Version 19.1.1.216 Build 20200306
Copyright (C) 1985-2020 Intel Corporation.  All rights reserved.
icl: command line error: no files specified; for help type "icl /help"
C:\temp>where icl
C:\Program Files (x86)\IntelSWTools\compilers_and_libraries_2020.1.216\windows\bin\intel64\icl.exe
C:\temp>
DPart1
Intel(R) Trace Analyzer and Collector 2020 Update 2 for Windows* OS for Intel(R) 64 applications
Intel(R) MPI Library 2019 Update 8 for Windows* Target Build Environment for Intel(R) 64 applications
Intel(R) Compiler 19.1 Update 2 (package 254)
** Visual Studio 2019 Developer Command Prompt v16.6.4
** Copyright (c) 2020 Microsoft Corporation
C:\Program Files (x86)\IntelSWTools>where icl
C:\Program Files (x86)\IntelSWTools\compilers_and_libraries_2020.2.254\windows\bin\intel64\icl.exe
C:\Program Files (x86)\IntelSWTools>cd \temp
C:\temp>where icl
C:\temp>
Viet_H_Intel
The ICL's directory differed between Tracker vs. the actual one, which is a problem in your env.
C:\temp>where icl
DPart1
No it's a problem with whatever the VS2017 integration did - I did nothing to specify that path that you say is incorrect - that will have been set by your Visual Studio integration code.
So, the problem is still in your court:
C:\Program Files (x86)\IntelSWTools>dir icl.exe /s
 Volume in drive C is Apollo
 Volume Serial Number is 172D-FED0
 Directory of C:\Program Files (x86)\IntelSWTools\compilers_and_libraries\windows\bin\intel64
23/06/2020  08:55         5,309,296 icl.exe
               1 File(s)      5,309,296 bytes
 Directory of C:\Program Files (x86)\IntelSWTools\compilers_and_libraries\windows\bin\intel64_ia32
23/06/2020  08:55         2,310,000 icl.exe
               1 File(s)      2,310,000 bytes
 Directory of C:\Program Files (x86)\IntelSWTools\compilers_and_libraries_2020\windows\bin\intel64
 Directory of C:\Program Files (x86)\IntelSWTools\compilers_and_libraries_2020\windows\bin\intel64_ia32
 Directory of C:\Program Files (x86)\IntelSWTools\compilers_and_libraries_2020.1.216\windows\bin\intel64
06/03/2020  19:32         4,868,464 icl.exe
               1 File(s)      4,868,464 bytes
 Directory of C:\Program Files (x86)\IntelSWTools\compilers_and_libraries_2020.1.216\windows\bin\intel64_ia32
06/03/2020  19:32         2,038,640 icl.exe
               1 File(s)      2,038,640 bytes
 Directory of C:\Program Files (x86)\IntelSWTools\compilers_and_libraries_2020.2.254\windows\bin\intel64
 Directory of C:\Program Files (x86)\IntelSWTools\compilers_and_libraries_2020.2.254\windows\bin\intel64_ia32
 Directory of C:\Program Files (x86)\IntelSWTools\parallel_studio_xe_2020\compilers_and_libraries_2020\windows\bin\intel64
 Directory of C:\Program Files (x86)\IntelSWTools\parallel_studio_xe_2020\compilers_and_libraries_2020\windows\bin\intel64_ia32
 Directory of C:\Program Files (x86)\IntelSWTools\parallel_studio_xe_2020.1.086\compilers_and_libraries_2020\windows\bin\intel64
 Directory of C:\Program Files (x86)\IntelSWTools\parallel_studio_xe_2020.1.086\compilers_and_libraries_2020\windows\bin\intel64_ia32
 Directory of C:\Program Files (x86)\IntelSWTools\parallel_studio_xe_2020.2.899\compilers_and_libraries_2020\windows\bin\intel64
 Directory of C:\Program Files (x86)\IntelSWTools\parallel_studio_xe_2020.2.899\compilers_and_libraries_2020\windows\bin\intel64_ia32
     Total Files Listed:
              14 File(s)     51,910,688 bytes
               0 Dir(s)  1,469,059,031,040 bytes free
Viet_H_Intel
Let me get in touch with the integration team and will get back to you.
Viet_H_Intel
C:\temp>where icl
Viet_H_Intel
Can you downgrade your VS2017 to versions which released before the compiler build date (e.g.  VS2017 version 15.9.12)?
