I just installed Parallel Studio XE and just tried to build my project using Intel C++ instead of MSVC.
When I try to build I get:
1>TRACKER : : error TRK0002: Failed to execute command: ""C:\Program Files (x86)\IntelSWTools\compilers_and_libraries_2020\windows\bin\Intel64\icl.exe" @C:\Users\amonra\AppData\Local\Temp\tmpcd93e637ab564ee4b93b363a73c649f8.rsp". The parameter is incorrect.
If this is the wrong forum I apologise, but I didn't find one for Parallel Studio XE.
Thanks David
10> Touching ".\x64\Debug\DeepSkyStacker.tlog\unsuccessfulbuild".
10> Done executing task "Touch".
10>Target "PrepareProjectReferences" skipped. Previously built successfully.
10>Target BuildGenerateSourcesTraverse:
10> Task "MSBuild" skipped, due to false condition; ('$(BuildPassReferences)' == 'true' and '@(ProjectReferenceWithConfiguration)' != '' and '@(_MSBuildProjectReferenceExistent)' != '' and '%(_MSBuildProjectReferenceExistent.BuildReference)' == 'true') was evaluated as ('' == 'true' and '..\libjpg\libjpg.vcxproj;..\LibRaw\buildfiles\libraw.vcxproj;..\LibTiff\libtiff.vcxproj;..\QHTML_Static\datasource\datasource.vcxproj;..\QHTML_Static\debughlp\DebugHlp.vcxproj;..\QHTML_Static\guitools\guitools.vcxproj;..\QHTML_Static\imglib\imglib.vcxproj;..\QHTML_Static\qhtm\qhtm.vcxproj;..\ZCLass\ZCLass.vcxproj' != '' and '..\libjpg\libjpg.vcxproj;..\LibRaw\buildfiles\libraw.vcxproj;..\LibTiff\libtiff.vcxproj;..\QHTML_Static\datasource\datasource.vcxproj;..\QHTML_Static\debughlp\DebugHlp.vcxproj;..\QHTML_Static\guitools\guitools.vcxproj;..\QHTML_Static\imglib\imglib.vcxproj;..\QHTML_Static\qhtm\qhtm.vcxproj;..\ZCLass\ZCLass.vcxproj' != '' and 'true' == 'true').
10>Target "PrepareForBuild" skipped. Previously built successfully.
10>Target "ResolveReferences" skipped. Previously built successfully.
10>Target BeforeBuildGenerateSources:
10>Target PreBuildEvent:
10> Task "Message" skipped, due to false condition; ('%(PreBuildEvent.Message)' != '' and '%(PreBuildEvent.Command)' != '') was evaluated as ('' != '' and '' != '').
10> Task "Exec" skipped, due to false condition; ('%(PreBuildEvent.Command)' != '') was evaluated as ('' != '').
10>Target "CustomBuild" skipped, due to false condition; ('@(CustomBuild)' != '') was evaluated as ('' != '').
10>Target "FxExport" skipped, due to false condition; ('@(FxCompile)' != '') was evaluated as ('' != '').
10>Target "FxCompile" skipped, due to false condition; ('@(FxCompile)' != '') was evaluated as ('' != '').
10>Target "_CreateCopyFileItems" skipped, due to false condition; ('@(CopyFileToFolders)' != '') was evaluated as ('' != '').
10>Target "InitializeBuildStatus" skipped. Previously built successfully.
10>Target "SetBuildDefaultEnvironmentVariables" skipped. Previously built successfully.
10>Target "SetUserMacroEnvironmentVariables" skipped. Previously built successfully.
10>Target _SelectedFiles:
10>Target CopyFileToFolders:
10> Using "GetOutOfDateItems" task from assembly "C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\Common7\IDE\VC\VCTargets\Microsoft.Build.CppTasks.Common.dll".
10> Task "GetOutOfDateItems"
10> Done executing task "GetOutOfDateItems".
10> Task "Copy" skipped, due to false condition; ('@(_OutOfDateCopyFile)' != '') was evaluated as ('' != '').
10>Target "Xsd" skipped, due to false condition; ('@(Xsd)' != '') was evaluated as ('' != '').
10>Target _Xsd:
10>Target MakeDirsForMidl:
10> Task "Makedir"
10> Done executing task "Makedir".
10>Target "Midl" skipped, due to false condition; ('@(Midl)' != '') was evaluated as ('' != '').
10>Target ComputeMIDLGeneratedCompileInputs:
10>Target AfterMidl:
10>Target _Midl:
10>Target AfterBuildGenerateSources:
10>Target AfterBuildGenerateSourcesEvent:
10>Target _BuildGenerateSourcesAction:
10>Target BuildGenerateSources:
10>Target BuildCompileTraverse:
10>Target MessageBuildingWithCompiler:
10> Using "ICMessage" task from assembly "C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\Common7\IDE\VC\VCTargets\Intel.Build.ICLTasks.v150.dll".
10> Task "ICMessage"
10> Building with Intel(R) C++ Compiler 19.1
10> Done executing task "ICMessage".
10>Target WarningAboutICInstallDir:
10> Task "ICMessage" skipped, due to false condition; ('$(ICInstallDir)'=='' AND '$(UseEnv)' != 'true') was evaluated as ('C:\Program Files (x86)\IntelSWTools\compilers_and_libraries_2020\windows\'=='' AND '' != 'true').
10>Target BeforeClCompile:
10>Target "ComputeMIDLGeneratedCompileInputs" skipped. Previously built successfully.
10>Target ComputeCLInputPDBName:
10>Target ComputeReferenceCLInput:
10> Task "WriteLinesToFile" skipped, due to false condition; (('@(_ReferenceCopyLocalPaths)'!='') and '$(DesignTimeBuild)' != 'true') was evaluated as ((''!='') and '' != 'true').
10> Task "Message" skipped, due to false condition; ('$(_REFERENCE_DEBUG)'=='true') was evaluated as (''=='true').
10>Target WarnCompileDuplicatedFilename:
10> Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'BitmapSlider.cpp' != 'BitmapSlider.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10> Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'BtnST.cpp' != 'BtnST.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10> Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'ButtonToolbar.cpp' != 'ButtonToolbar.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10> Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'cdxCRot90DC.cpp' != 'cdxCRot90DC.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10> Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'cdxCRotBevelLine.cpp' != 'cdxCRotBevelLine.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10> Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'cgfiltyp.cpp' != 'cgfiltyp.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10> Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'childprop.cpp' != 'childprop.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10> Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'ControlPos.cpp' != 'ControlPos.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10> Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'CtrlCache.cpp' != 'CtrlCache.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10> Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'CustomTabCtrl.cpp' != 'CustomTabCtrl.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10> Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'FolderDlg.cpp' != 'FolderDlg.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10> Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'Gradient.cpp' != 'Gradient.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10> Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'GradientCtrl.cpp' != 'GradientCtrl.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10> Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'GradientCtrlImpl.cpp' != 'GradientCtrlImpl.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10> Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'Label.cpp' != 'Label.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10> Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'ListViewCtrlEx.cpp' != 'ListViewCtrlEx.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10> Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'Registry.cpp' != 'Registry.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10> Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'RegMFC.cpp' != 'RegMFC.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10> Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'RichToolTipCtrl.cpp' != 'RichToolTipCtrl.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10> Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'ScrollDialog.cpp' != 'ScrollDialog.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10> Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'SplitterControl.cpp' != 'SplitterControl.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10> Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'ThemeUtil.cpp' != 'ThemeUtil.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10> Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'ToolTipButton.cpp' != 'ToolTipButton.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10> Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'WndImage.cpp' != 'WndImage.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10> Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'About.cpp' != 'About.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10> Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'AHDDemosaicing.cpp' != 'AHDDemosaicing.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10> Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'AlignmentParameters.cpp' != 'AlignmentParameters.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10> Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'AskRegistering.cpp' != 'AskRegistering.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10> Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'BackgroundCalibration.cpp' != 'BackgroundCalibration.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10> Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'BackgroundLoading.cpp' != 'BackgroundLoading.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10> Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'BackgroundOptions.cpp' != 'BackgroundOptions.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10> Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'BatchStacking.cpp' != 'BatchStacking.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10> Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'BitmapExt.cpp' != 'BitmapExt.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10> Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'ChannelAlign.cpp' != 'ChannelAlign.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10> Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'CheckAbove.cpp' != 'CheckAbove.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10> Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'CometStacking.cpp' != 'CometStacking.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10> Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'CosmeticEngine.cpp' != 'CosmeticEngine.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10> Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'DarkFrame.cpp' != 'DarkFrame.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10> Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'DeBloom.cpp' != 'DeBloom.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10> Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'DeepSkyStacker.cpp' != 'DeepSkyStacker.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10> Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'DeepStack.cpp' != 'DeepStack.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10> Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'DeepStackerDlg.cpp' != 'DeepStackerDlg.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10> Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'Delaunay.cpp' != 'Delaunay.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10> Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'DropFilesDlg.cpp' != 'DropFilesDlg.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10> Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'EntropyInfo.cpp' != 'EntropyInfo.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10> Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'ExplorerBar.cpp' != 'ExplorerBar.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10> Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'FileProperty.cpp' != 'FileProperty.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10> Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'Filters.cpp' != 'Filters.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10> Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'FitsFilesTab.cpp' != 'FitsFilesTab.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10> Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'FITSUtil.cpp' != 'FITSUtil.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10> Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'FlatFrame.cpp' != 'FlatFrame.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10> Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'FrameInfo.cpp' != 'FrameInfo.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10> Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'FrameList.cpp' != 'FrameList.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10> Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'ImageSinks.cpp' != 'ImageSinks.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10> Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'IntermediateFiles.cpp' != 'IntermediateFiles.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10> Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'Library.cpp' != 'Library.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10> Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'LibraryDlg.cpp' != 'LibraryDlg.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10> Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'LuminanceTab.cpp' != 'LuminanceTab.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10> Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'MasterFrames.cpp' != 'MasterFrames.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10> Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'MatchingStars.cpp' != 'MatchingStars.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10> Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'MultiBitmapProcess.cpp' != 'MultiBitmapProcess.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10> Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'Multitask.cpp' != 'Multitask.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10> Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'OutputTab.cpp' != 'OutputTab.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10> Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'PCLTools.cpp' != 'PCLTools.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10> Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'PictureListCtrl.cpp' != 'PictureListCtrl.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10> Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'PostCalibration.cpp' != 'PostCalibration.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10> Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'ProcessingDlg.cpp' != 'ProcessingDlg.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10> Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'ProcessSettingsSheet.cpp' != 'ProcessSettingsSheet.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10> Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'ProgressDlg.cpp' != 'ProgressDlg.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10> Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'RawDDPSettings.cpp' != 'RawDDPSettings.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10> Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'RawFilesTab.cpp' != 'RawFilesTab.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10> Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'RAWUtils.cpp' != 'RAWUtils.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10> Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'RecommandedSettings.cpp' != 'RecommandedSettings.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10> Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'RegisterEngine.cpp' != 'RegisterEngine.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10> Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'RegisterSettings.cpp' != 'RegisterSettings.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10> Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'RegisterSettings_Actions.cpp' != 'RegisterSettings_Actions.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10> Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'RegisterSettings_Advanced.cpp' != 'RegisterSettings_Advanced.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10> Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'ResultParameters.cpp' != 'ResultParameters.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10> Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'RGBTab.cpp' != 'RGBTab.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10> Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'RunningStackingEngine.cpp' != 'RunningStackingEngine.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10> Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'SaturationTab.cpp' != 'SaturationTab.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10> Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'SaveEditChanges.cpp' != 'SaveEditChanges.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10> Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'SavePicture.cpp' != 'SavePicture.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10> Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'Settings.cpp' != 'Settings.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10> Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'SettingsDlg.cpp' != 'SettingsDlg.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10> Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'SetUILanguage.cpp' != 'SetUILanguage.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10> Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'StackedBitmap.cpp' != 'StackedBitmap.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10> Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'StackingDlg.cpp' != 'StackingDlg.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10> Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'StackingEngine.cpp' != 'StackingEngine.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10> Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'StackingParameters.cpp' != 'StackingParameters.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10> Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'StackingTasks.cpp' != 'StackingTasks.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10> Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'StackRecap.cpp' != 'StackRecap.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10> Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'StackSettings.cpp' != 'StackSettings.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10> Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'StarMask.cpp' != 'StarMask.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10> Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'StarMaskDlg.cpp' != 'StarMaskDlg.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10> Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'StdAfx.cpp' != 'StdAfx.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10> Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'TIFFUtil.cpp' != 'TIFFUtil.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10> Task "VCMessage" skipped, due to false condition; ('%(ClCompile.ExcludedFromBuild)' != 'true' and '%(Filename)%(Extension)' != '@(ClCompile->'%(Filename)%(Extension)')' and '%(ObjectFileName)' == '@(ClCompile->Metadata(ObjectFileName)->Distinct())') was evaluated as ('' != 'true' and 'Workspace.cpp' != 'Workspace.cpp' and '.\x64\Debug\' == '.\x64\Debug\').
10>Target FixupCLCompileOptions:
10>Target MakeDirsForCl:
10> Task "MakeDir"
10> Done executing task "MakeDir".
10>Target "PrepareDirForCodeCoverage" skipped, due to false condition; ('$(CodeCoverageOperations)' != 'Disabled' AND '$(ProfileDirectory)' != '') was evaluated as ('Disabled' != 'Disabled' AND '.\x64\Debug\' != '').
10>Target "PrepareDirForPGO" skipped, due to false condition; ('$(ProfileGuidedOptimization)' != 'Disabled' AND '$(ProfileDirectory)' != '') was evaluated as ('Disabled' != 'Disabled' AND '.\x64\Debug\' != '').
10>Target "_SelectedFiles" skipped. Previously built successfully.
10>Target "ComputeCLInputPDBName" skipped. Previously built successfully.
10>Target "ComputeReferenceCLInput" skipped. Previously built successfully.
10>Target "WarnCompileDuplicatedFilename" skipped. Previously built successfully.
10>Target "FixupCLCompileOptions" skipped. Previously built successfully.
10>Target SelectCustomBuild:
10>Target SelectClCompile:
10>Target CheckInstalledICLibsIPP:
10> Task "ICMessage" skipped, due to false condition; ('$(IPPSingleThreaded)'=='0' AND '$(IPPMajorVersion)' != '' AND ('$(UseIntelIPP)' == 'Sequential' OR '$(UseIntelIPP)' == 'Sequential_Dynamic' OR ('$(UseIntelIPP)' == 'true' AND '%(ClCompile.OpenMP)' != 'GenerateParallelCode' AND '%(ClCompile.Parallelization)' != 'true'))) was evaluated as (''=='0' AND '' != '' AND ('false' == 'Sequential' OR 'false' == 'Sequential_Dynamic' OR ('false' == 'true' AND 'None' != 'GenerateParallelCode' AND 'false' != 'true'))).
10> Task "ICMessage" skipped, due to false condition; ('$(IPPMultiThreaded)'=='0' AND '$(IPPMajorVersion)' != '' AND ('$(UseIntelIPP)' == 'Parallel_Static' OR '$(UseIntelIPP)' == 'Parallel_Dynamic' OR ('$(UseIntelIPP)' == 'true' AND ('%(ClCompile.OpenMP)' == 'GenerateParallelCode' OR '%(ClCompile.Parallelization)' == 'true')))) was evaluated as (''=='0' AND '' != '' AND ('false' == 'Parallel_Static' OR 'false' == 'Parallel_Dynamic' OR ('false' == 'true' AND ('None' == 'GenerateParallelCode' OR 'false' == 'true')))).
10>Target "SetICMKLEnvironment" skipped, due to false condition; ('$(UseIntelMKL)' != '' AND '$(UseIntelMKL)' != 'No' AND '$(MKLProductDir)' != '') was evaluated as ('No' != '' AND 'No' != 'No' AND '' != '').
10>Target "CheckInstalledICLibsMKL" skipped, due to false condition; ('$(UseIntelMKL)' != '' AND '$(UseIntelMKL)' != 'No') was evaluated as ('No' != '' AND 'No' != 'No').
10>Target "CheckInstalledVCLibsIPP" skipped, due to false condition; ('$(PlatformToolset)' == 'v141') was evaluated as ('Intel C++ Compiler 19.1' == 'v141').
10>Target "SetVCMKLEnvironment" skipped, due to false condition; ('$(UseIntelMKL)' != '' AND '$(UseIntelMKL)' != 'No' AND '$(PlatformToolset)' == 'v141' AND '$(MKLProductDir)' != '') was evaluated as ('No' != '' AND 'No' != 'No' AND 'Intel C++ Compiler 19.1' == 'v141' AND '' != '').
10>Target "CheckInstalledVCLibsMKL" skipped, due to false condition; ('$(UseIntelMKL)' != '' AND '$(UseIntelMKL)' != 'No' AND '$(PlatformToolset)' == 'v141') was evaluated as ('No' != '' AND 'No' != 'No' AND 'Intel C++ Compiler 19.1' == 'v141').
10>Target "GenerateTargetFrameworkMonikerAttribute" skipped, due to false condition; ('$(GenerateTargetFrameworkAttribute)' == 'true') was evaluated as ('false' == 'true').
10>Target "ManagedIncrementalBuildPreProcessDependencyGraph" skipped, due to false condition; ('@(ClCompile)' != '' and '$(EnableManagedIncrementalBuild)' == 'True') was evaluated as ('..\Tools\BitmapSlider.cpp;..\Tools\BtnST.cpp;..\Tools\ButtonToolbar.cpp;..\Tools\cdxCRot90DC.cpp;..\Tools\cdxCRotBevelLine.cpp;..\Tools\cgfiltyp.cpp;..\Tools\childprop.cpp;..\Tools\ControlPos.cpp;..\Tools\CtrlCache.cpp;..\Tools\CustomTabCtrl.cpp;..\Tools\FolderDlg.cpp;..\Tools\Gradient.cpp;..\Tools\GradientCtrl.cpp;..\Tools\GradientCtrlImpl.cpp;..\Tools\Label.cpp;..\Tools\ListViewCtrlEx.cpp;..\Tools\Registry.cpp;..\Tools\RegMFC.cpp;..\Tools\RichToolTipCtrl.cpp;..\Tools\ScrollDialog.cpp;..\Tools\SplitterControl.cpp;..\Tools\ThemeUtil.cpp;..\Tools\ToolTipButton.cpp;..\Tools\WndImage.cpp;About.cpp;AHDDemosaicing.cpp;AlignmentParameters.cpp;AskRegistering.cpp;BackgroundCalibration.cpp;BackgroundLoading.cpp;BackgroundOptions.cpp;BatchStacking.cpp;BitmapExt.cpp;ChannelAlign.cpp;CheckAbove.cpp;CometStacking.cpp;CosmeticEngine.cpp;DarkFrame.cpp;DeBloom.cpp;DeepSkyStacker.cpp;DeepStack.cpp;DeepStackerDlg.cpp;Delaunay.cpp;DropFilesDlg.cpp;EntropyInfo.cpp;ExplorerBar.cpp;FileProperty.cpp;Filters.cpp;FitsFilesTab.cpp;FITSUtil.cpp;FlatFrame.cpp;FrameInfo.cpp;FrameList.cpp;ImageSinks.cpp;IntermediateFiles.cpp;Library.cpp;LibraryDlg.cpp;LuminanceTab.cpp;MasterFrames.cpp;MatchingStars.cpp;MultiBitmapProcess.cpp;Multitask.cpp;OutputTab.cpp;PCLTools.cpp;PictureListCtrl.cpp;PostCalibration.cpp;ProcessingDlg.cpp;ProcessSettingsSheet.cpp;ProgressDlg.cpp;RawDDPSettings.cpp;RawFilesTab.cpp;RAWUtils.cpp;RecommandedSettings.cpp;RegisterEngine.cpp;RegisterSettings.cpp;RegisterSettings_Actions.cpp;RegisterSettings_Advanced.cpp;ResultParameters.cpp;RGBTab.cpp;RunningStackingEngine.cpp;SaturationTab.cpp;SaveEditChanges.cpp;SavePicture.cpp;Settings.cpp;SettingsDlg.cpp;SetUILanguage.cpp;StackedBitmap.cpp;StackingDlg.cpp;StackingEngine.cpp;StackingParameters.cpp;StackingTasks.cpp;StackRecap.cpp;StackSettings.cpp;StarMask.cpp;StarMaskDlg.cpp;StdAfx.cpp;TIFFUtil.cpp;Workspace.cpp' != '' and 'false' == 'True').
10>Target "CheckIntelEnvironmentForVCLibsDAAL" skipped, due to false condition; ('$(UseIntelDAAL)' != '' AND '$(UseIntelDAAL)' != 'false' AND '$(UseEnv)' != 'true' AND '$(PlatformToolset)' == 'v141') was evaluated as ('false' != '' AND 'false' != 'false' AND '' != 'true' AND 'Intel C++ Compiler 19.1' == 'v141').
10>Target "CheckIntelEnvironmentForVCLibsIPP" skipped, due to false condition; ('$(PlatformToolset)' == 'v141' AND '$(UseIntelIPP)' != '' AND '$(UseIntelIPP)' != 'false' AND '$(UseEnv)' != 'true') was evaluated as ('Intel C++ Compiler 19.1' == 'v141' AND 'false' != '' AND 'false' != 'false' AND '' != 'true').
10>Target "CheckIntelEnvironmentForVCLibsMKL" skipped, due to false condition; ('$(UseIntelMKL)' != '' AND '$(UseIntelMKL)' != 'No' AND '$(UseEnv)' != 'true' AND '$(PlatformToolset)' == 'v141') was evaluated as ('No' != '' AND 'No' != 'No' AND '' != 'true' AND 'Intel C++ Compiler 19.1' == 'v141').
10>Target "CheckIntelEnvironmentForVCLibsTBB" skipped, due to false condition; ('$(PlatformToolset)' == 'v141' AND '$(UseIntelTBB)' == 'true' AND '$(UseEnv)' != 'true') was evaluated as ('Intel C++ Compiler 19.1' == 'v141' AND 'false' == 'true' AND '' != 'true').
10>Target "CheckIntelEnvironmentForICLibsDAAL" skipped, due to false condition; ('$(UseIntelDAAL)' != '' AND '$(UseIntelDAAL)' != 'false' AND '$(UseEnv)' != 'true') was evaluated as ('false' != '' AND 'false' != 'false' AND '' != 'true').
10>Target "CheckIntelEnvironmentForICLibsIPP" skipped, due to false condition; ('$(UseIntelIPP)' != '' AND '$(UseIntelIPP)' != 'false' AND '$(UseEnv)' != 'true') was evaluated as ('false' != '' AND 'false' != 'false' AND '' != 'true').
10>Target "CheckIntelEnvironmentForICLibsMKL" skipped, due to false condition; ('$(UseIntelMKL)' != '' AND '$(UseIntelMKL)' != 'No' AND '$(UseEnv)' != 'true') was evaluated as ('No' != '' AND 'No' != 'No' AND '' != 'true').
10>Target "CheckIntelEnvironmentForICLibsTBB" skipped, due to false condition; ('$(UseIntelTBB)' == 'true' AND '$(UseEnv)' != 'true') was evaluated as ('false' == 'true' AND '' != 'true').
10>Target ClCompile:
10> Task "Message"
10> ***** ClCompile (x64 - Intel C++)
10> Done executing task "Message".
10> Task "Delete" skipped, due to false condition; ('%(ClCompile.DebugInformationFormat)' != '' AND '%(ClCompile.DebugInformationFormat)' != 'OldStyle' AND '%(ClCompile.ProgramDataBaseFileName)' != '' AND !Exists(%(ClCompile.ProgramDataBaseFileName))
10> AND '%(ClCompile.UseMSVC)'!='true' AND '%(ClCompile.InterproceduralOptimization)'!='MultiFile' AND '%(ClCompile.LevelOfStaticAnalysis)'!='Brief' AND
10> '%(ClCompile.LevelOfStaticAnalysis)'!='Medium' AND '%(ClCompile.LevelOfStaticAnalysis)'!='Verbose') was evaluated as ('ProgramDatabase' != '' AND 'ProgramDatabase' != 'OldStyle' AND 'C:\Users\amonra\Documents\GitHub\DSS\x64\Debug\DeepSkyStacker.pdb' != '' AND !Exists(C:\Users\amonra\Documents\GitHub\DSS\x64\Debug\DeepSkyStacker.pdb)
10> AND 'false'!='true' AND 'NoIPO'!='MultiFile' AND 'None'!='Brief' AND
10> 'None'!='Medium' AND 'None'!='Verbose').
10> Task "ICL" skipped, due to false condition; ('%(ClCompile.PrecompiledHeader)' == 'Create' AND '%(ClCompile.ExcludedFromBuild)'!='true' AND '%(ClCompile.UseMSVC)'!='true') was evaluated as ('Use' == 'Create' AND ''!='true' AND 'false'!='true').
10> Using "ICL" task from assembly "C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\Common7\IDE\VC\VCTargets\Intel.Build.ICLTasks.v150.dll".
10> Task "ICL"
10> Read Tracking Logs:
10> .\x64\Debug\DeepSkyStacker.tlog\icl.read.1.tlog
10> .\x64\Debug\DeepSkyStacker.tlog\icl-mcpcom.read.1.tlog
10> Outputs for C:\USERS\AMONRA\DOCUMENTS\GITHUB\DSS\DEEPSKYSTACKER\STDAFX.CPP:
10> C:\USERS\AMONRA\DOCUMENTS\GITHUB\DSS\DEEPSKYSTACKER\X64\DEBUG\STDAFX.OBJ
10> C:\USERS\AMONRA\DOCUMENTS\GITHUB\DSS\DEEPSKYSTACKER\X64\DEBUG\DEEPSKYSTACKER.PCHI
10> StdAfx.cpp will be compiled because it was not found in the tracking log.
10> Environment Variables passed to tool:
10> VS_UNICODE_OUTPUT=2288
10> C:\Program Files (x86)\IntelSWTools\compilers_and_libraries_2020\windows\bin\Intel64\icl.exe /c /Qm64 /I"C:\Program Files (x86)\Visual Leak Detector\include" /I.\ /I../Libraw /I..\ZClass /I..\tools /I..\LibTIFF /I..\CFitsIO /I..\Zlib /I"C:\Program Files (x86)\Visual Leak Detector\include" /Zi /nologo /W3 /WX /MP /Od /Ob0 /D __INTEL_COMPILER=1910 /D _UNICODE /D UNICODE /D NOMINMAX /D LIBRAW_NODLL /D WIN32 /D _DEBUG /D _CRT_SECURE_NO_DEPRECATE /D USE_LIBTIFF_STATIC /D Z_TRACE_DEVELOP /D _VC80_UPGRADE=0x0600 /D _MBCS /D _AFXDLL /EHsc /RTC1 /MDd /GS /fp:precise /Zc:wchar_t /Zc:forScope /GR /Qstd=c++14 /Yc"stdafx.h" /Fp".\x64\Debug\DeepSkyStacker.pch" /Fo".\x64\Debug\\" /Fd"C:\Users\amonra\Documents\GitHub\DSS\x64\Debug\DeepSkyStacker.pdb" /TP /FC StdAfx.cpp
10> Tracking command:
10> C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\MSBuild\15.0\Bin\Tracker.exe /d "C:\Program Files (x86)\MSBuild\15.0\FileTracker\FileTracker32.dll" /i C:\Users\amonra\Documents\GitHub\DSS\DeepSkyStacker\x64\Debug\DeepSkyStacker.tlog /r C:\USERS\AMONRA\DOCUMENTS\GITHUB\DSS\DEEPSKYSTACKER\STDAFX.CPP /b MSBuildConsole_CancelEvent8c2d7c7c6ea54eed8f62cd5cb66c1869 /c "C:\Program Files (x86)\IntelSWTools\compilers_and_libraries_2020\windows\bin\Intel64\icl.exe" /c /Qm64 /I"C:\Program Files (x86)\Visual Leak Detector\include" /I.\ /I../Libraw /I..\ZClass /I..\tools /I..\LibTIFF /I..\CFitsIO /I..\Zlib /I"C:\Program Files (x86)\Visual Leak Detector\include" /Zi /nologo /W3 /WX /MP /Od /Ob0 /D __INTEL_COMPILER=1910 /D _UNICODE /D UNICODE /D NOMINMAX /D LIBRAW_NODLL /D WIN32 /D _DEBUG /D _CRT_SECURE_NO_DEPRECATE /D USE_LIBTIFF_STATIC /D Z_TRACE_DEVELOP /D _VC80_UPGRADE=0x0600 /D _MBCS /D _AFXDLL /EHsc /RTC1 /MDd /GS /fp:precise /Zc:wchar_t /Zc:forScope /GR /Qstd=c++14 /Yc"stdafx.h" /Fp".\x64\Debug\DeepSkyStacker.pch" /Fo".\x64\Debug\\" /Fd"C:\Users\amonra\Documents\GitHub\DSS\x64\Debug\DeepSkyStacker.pdb" /TP /FC StdAfx.cpp
10> TRACKER : : error TRK0002: Failed to execute command: ""C:\Program Files (x86)\IntelSWTools\compilers_and_libraries_2020\windows\bin\Intel64\icl.exe" @C:\Users\amonra\AppData\Local\Temp\tmp62d68a95871943d7a8985004e1d65f7c.rsp". The parameter is incorrect.
10>
10>
10> The command exited with code 2.
10> Done executing task "ICL" -- FAILED.
10>Done building target "ClCompile" in project "DeepSkyStacker.vcxproj" -- FAILED.
10>
10>Done building project "DeepSkyStacker.vcxproj" -- FAILED.
10>
10>Build FAILED.
10>
10>TRACKER : : error TRK0002: Failed to execute command: ""C:\Program Files (x86)\IntelSWTools\compilers_and_libraries_2020\windows\bin\Intel64\icl.exe" @C:\Users\amonra\AppData\Local\Temp\tmp62d68a95871943d7a8985004e1d65f7c.rsp". The parameter is incorrect.
10> 0 Warning(s)
10> 1 Error(s)
10>
10>Time Elapsed 00:00:00.55
Here's some MSBuild output that may help:
Target ClCompile:
10> Task "Message"
10> Task "ICL"
10> VS_UNICODE_OUTPUT=1912
10> C:\Program Files (x86)\IntelSWTools\compilers_and_libraries_2020\windows\bin\Intel64\icl.exe /c /Qm64 /I"C:\Program Files (x86)\Visual Leak Detector\include" /I.\ /I../Libraw /I..\ZClass /I..\tools /I..\LibTIFF /I..\CFitsIO /I..\Zlib /I"C:\Program Files (x86)\Visual Leak Detector\include" /Zi /nologo /W3 /WX /MP /Od /Ob0 /D __INTEL_COMPILER=1910 /D _UNICODE /D UNICODE /D NOMINMAX /D LIBRAW_NODLL /D WIN32 /D _DEBUG /D _CRT_SECURE_NO_DEPRECATE /D USE_LIBTIFF_STATIC /D Z_TRACE_DEVELOP /D _VC80_UPGRADE=0x0600 /D _MBCS /D _AFXDLL /EHsc /RTC1 /MDd /GS /fp:precise /Zc:wchar_t /Zc:forScope /GR /Yc"stdafx.h" /Fp".\x64\Debug\DeepSkyStacker.pch" /Fo".\x64\Debug\\" /Fd"C:\Users\amonra\Documents\GitHub\DSS\x64\Debug\DeepSkyStacker.pdb" /TP /FC StdAfx.cpp
10> C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\MSBuild\15.0\Bin\Tracker.exe /d "C:\Program Files (x86)\MSBuild\15.0\FileTracker\FileTracker32.dll" /i C:\Users\amonra\Documents\GitHub\DSS\DeepSkyStacker\x64\Debug\DeepSkyStacker.tlog /r C:\USERS\AMONRA\DOCUMENTS\GITHUB\DSS\DEEPSKYSTACKER\STDAFX.CPP /b MSBuildConsole_CancelEvent87e97dd3b04943baa92e415f55178857 /c "C:\Program Files (x86)\IntelSWTools\compilers_and_libraries_2020\windows\bin\Intel64\icl.exe" /c /Qm64 /I"C:\Program Files (x86)\Visual Leak Detector\include" /I.\ /I../Libraw /I..\ZClass /I..\tools /I..\LibTIFF /I..\CFitsIO /I..\Zlib /I"C:\Program Files (x86)\Visual Leak Detector\include" /Zi /nologo /W3 /WX /MP /Od /Ob0 /D __INTEL_COMPILER=1910 /D _UNICODE /D UNICODE /D NOMINMAX /D LIBRAW_NODLL /D WIN32 /D _DEBUG /D _CRT_SECURE_NO_DEPRECATE /D USE_LIBTIFF_STATIC /D Z_TRACE_DEVELOP /D _VC80_UPGRADE=0x0600 /D _MBCS /D _AFXDLL /EHsc /RTC1 /MDd /GS /fp:precise /Zc:wchar_t /Zc:forScope /GR /Yc"stdafx.h" /Fp".\x64\Debug\DeepSkyStacker.pch" /Fo".\x64\Debug\\" /Fd"C:\Users\amonra\Documents\GitHub\DSS\x64\Debug\DeepSkyStacker.pdb" /TP /FC StdAfx.cpp
10> TRACKER : : error TRK0002: Failed to execute command: ""C:\Program Files (x86)\IntelSWTools\compilers_and_libraries_2020\windows\bin\Intel64\icl.exe" @C:\Users\amonra\AppData\Local\Temp\tmpd318524d19284c21b2737f5e940ee164.rsp". The parameter is incorrect.
10>
10>
10>
10>
10>Build FAILED.
10>
10>TRACKER : : error TRK0002: Failed to execute command: ""C:\Program Files (x86)\IntelSWTools\compilers_and_libraries_2020\windows\bin\Intel64\icl.exe" @C:\Users\amonra\AppData\Local\Temp\tmpd318524d19284c21b2737f5e940ee164.rsp". The parameter is incorrect.
10> 0 Warning(s)
10> 1 Error(s)
10>
10>Time Elapsed 00:00:00.49
========== Build: 0 succeeded, 1 failed, 9 up-to-date, 0 skipped ==========
Hi David,
Thanks for reporting the error.
We are forwarding your query to the concerned team.
We will get back to you soon.
Prasanth
What MSVS 2017 update version are you using?
It seems that this is a problem with tracker.exe.
Will Stdafx.cpp compile if you do:
And does it work if you replace icl.exe with cl.exe?
VS2017 Community edition 15.9.14
I can't compile the rsp file as it is deleted by MsBuild on completion of the failed build.
Copyright (C) 2009-2020 Intel Corporation. All rights reserved.
Intel(R) Inspector 2020 (build 604266)
Intel(R) Advisor 2020 (build 605410)
Intel(R) Trace Analyzer and Collector 2020 Update 1 for Windows* OS for Intel(R) 64 applications
Copyright (C) 1996-2020 Intel Corporation. All rights reserved.
Intel(R) MPI Library 2019 Update 7 for Windows* Target Build Environment for Intel(R) 64 applications
Copyright 2007-2020 Intel Corporation.
Copyright (C) 1985-2019 Intel Corporation. All rights reserved.
Intel(R) Compiler 19.1 Update 1 (package 216)
** Visual Studio 2017 Developer Command Prompt v15.9.14
** Copyright (c) 2017 Microsoft Corporation
[vcvarsall.bat] Environment initialized for: 'x64'
C:\Program Files (x86)\IntelSWTools>cd \users\amonra\Documents\GitHub\DSS\DeepSkyStacker
C:\Users\amonra\Documents\GitHub\DSS\DeepSkyStacker>icl.exe /c /Qm64 /I"C:\Program Files (x86)\Visual Leak Detector\include" /I.\ /I../Libraw /I..\ZClass /I..\tools /I..\LibTIFF /I..\CFitsIO /I..\Zlib /I"C:\Program Files (x86)\Visual Leak Detector\include" /Zi /nologo /W3 /WX /MP /Od /Ob0 /D __INTEL_COMPILER=1910 /D _UNICODE /D UNICODE /D NOMINMAX /D LIBRAW_NODLL /D WIN32 /D _DEBUG /D _CRT_SECURE_NO_DEPRECATE /D USE_LIBTIFF_STATIC /D Z_TRACE_DEVELOP /D _VC80_UPGRADE=0x0600 /D _MBCS /D _AFXDLL /EHsc /RTC1 /MDd /GS /fp:precise /Zc:wchar_t /Zc:forScope /GR /Yc"stdafx.h" /Fp".\x64\Debug\DeepSkyStacker.pch" /Fo".\x64\Debug\\" /Fd"C:\Users\amonra\Documents\GitHub\DSS\x64\Debug\DeepSkyStacker.pdb" /TP /FC StdAfx.cpp
StdAfx.cpp
C:\Users\amonra\Documents\GitHub\DSS\DeepSkyStacker>cl.exe /c /Qm64 /I"C:\Program Files (x86)\Visual Leak Detector\include" /I.\ /I../Libraw /I..\ZClass /I..\tools /I..\LibTIFF /I..\CFitsIO /I..\Zlib /I"C:\Program Files (x86)\Visual Leak Detector\include" /Zi /nologo /W3 /WX /MP /Od /Ob0 /D __INTEL_COMPILER=1910 /D _UNICODE /D UNICODE /D NOMINMAX /D LIBRAW_NODLL /D WIN32 /D _DEBUG /D _CRT_SECURE_NO_DEPRECATE /D USE_LIBTIFF_STATIC /D Z_TRACE_DEVELOP /D _VC80_UPGRADE=0x0600 /D _MBCS /D _AFXDLL /EHsc /RTC1 /MDd /GS /fp:precise /Zc:wchar_t /Zc:forScope /GR /Yc"stdafx.h" /Fp".\x64\Debug\DeepSkyStacker.pch" /Fo".\x64\Debug\\" /Fd"C:\Users\amonra\Documents\GitHub\DSS\x64\Debug\DeepSkyStacker.pdb" /TP /FC StdAfx.cpp
cl : Command line warning D9002 : ignoring unknown option '/Qm64'
StdAfx.cpp
c:\program files (x86)\intelswtools\compilers_and_libraries_2020.1.216\windows\compiler\include\math.h(145): fatal error C1021: invalid preprocessor command 'include_next'
looks like StdAfx.cpp were able to compile with Intel Compiler.
Could be that Tracker.exe doesn't support icl.exe?
Surely you have that the wrong way about - isn't it your job to ensure that icl.exe is compatible with the tracker?
David
Bump - is anyone in Parallel Studio land looking at this? If not why not?
David
I have been working with my team, seems like Tracker.exe isn't supported by ICL.
Well that's a royal pain as it means I cannot build my projects using Intel Compiler
A Parallel Studio XE license I can't use doesn't feel like a good deal :(>
When might I expect a solution?
David
What do you see when you run: C:\temp> where icl?
C:\Users\amonra>cd \temp
C:\temp>where icl
INFO: Could not find files for the given pattern(s).
C:\temp>
Please run "where icl" on a Windows which you can successfully execute icl
C:\temp>icl
Intel(R) C++ Intel(R) 64 Compiler for applications running on Intel(R) 64, Version 19.1.1.216 Build 20200306
Copyright (C) 1985-2020 Intel Corporation. All rights reserved.
icl: command line error: no files specified; for help type "icl /help"
C:\temp>where icl
C:\Program Files (x86)\IntelSWTools\compilers_and_libraries_2020.1.216\windows\bin\intel64\icl.exe
C:\temp>
Intel(R) Trace Analyzer and Collector 2020 Update 2 for Windows* OS for Intel(R) 64 applications
Intel(R) MPI Library 2019 Update 8 for Windows* Target Build Environment for Intel(R) 64 applications
Intel(R) Compiler 19.1 Update 2 (package 254)
** Visual Studio 2019 Developer Command Prompt v16.6.4
** Copyright (c) 2020 Microsoft Corporation
C:\Program Files (x86)\IntelSWTools>where icl
C:\Program Files (x86)\IntelSWTools\compilers_and_libraries_2020.2.254\windows\bin\intel64\icl.exe
C:\Program Files (x86)\IntelSWTools>cd \temp
C:\temp>where icl
C:\temp>
The ICL's directory differed between Tracker vs. the actual one, which is a problem in your env.
C:\temp>where icl
No it's a problem with whatever the VS2017 integration did - I did nothing to specify that path that you say is incorrect - that will have been set by your Visual Studio integration code.
So, the problem is still in your court:
C:\Program Files (x86)\IntelSWTools>dir icl.exe /s
Volume in drive C is Apollo
Volume Serial Number is 172D-FED0
Directory of C:\Program Files (x86)\IntelSWTools\compilers_and_libraries\windows\bin\intel64
23/06/2020 08:55 5,309,296 icl.exe
1 File(s) 5,309,296 bytes
Directory of C:\Program Files (x86)\IntelSWTools\compilers_and_libraries\windows\bin\intel64_ia32
23/06/2020 08:55 2,310,000 icl.exe
1 File(s) 2,310,000 bytes
Directory of C:\Program Files (x86)\IntelSWTools\compilers_and_libraries_2020\windows\bin\intel64
Directory of C:\Program Files (x86)\IntelSWTools\compilers_and_libraries_2020\windows\bin\intel64_ia32
Directory of C:\Program Files (x86)\IntelSWTools\compilers_and_libraries_2020.1.216\windows\bin\intel64
06/03/2020 19:32 4,868,464 icl.exe
1 File(s) 4,868,464 bytes
Directory of C:\Program Files (x86)\IntelSWTools\compilers_and_libraries_2020.1.216\windows\bin\intel64_ia32
06/03/2020 19:32 2,038,640 icl.exe
1 File(s) 2,038,640 bytes
Directory of C:\Program Files (x86)\IntelSWTools\compilers_and_libraries_2020.2.254\windows\bin\intel64
Directory of C:\Program Files (x86)\IntelSWTools\compilers_and_libraries_2020.2.254\windows\bin\intel64_ia32
Directory of C:\Program Files (x86)\IntelSWTools\parallel_studio_xe_2020\compilers_and_libraries_2020\windows\bin\intel64
Directory of C:\Program Files (x86)\IntelSWTools\parallel_studio_xe_2020\compilers_and_libraries_2020\windows\bin\intel64_ia32
Directory of C:\Program Files (x86)\IntelSWTools\parallel_studio_xe_2020.1.086\compilers_and_libraries_2020\windows\bin\intel64
Directory of C:\Program Files (x86)\IntelSWTools\parallel_studio_xe_2020.1.086\compilers_and_libraries_2020\windows\bin\intel64_ia32
Directory of C:\Program Files (x86)\IntelSWTools\parallel_studio_xe_2020.2.899\compilers_and_libraries_2020\windows\bin\intel64
Directory of C:\Program Files (x86)\IntelSWTools\parallel_studio_xe_2020.2.899\compilers_and_libraries_2020\windows\bin\intel64_ia32
Total Files Listed:
14 File(s) 51,910,688 bytes
0 Dir(s) 1,469,059,031,040 bytes free
Let me get in touch with the integration team and will get back to you.
C:\temp>where icl
Can you downgrade your VS2017 to versions which released before the compiler build date (e.g. VS2017 version 15.9.12)?
