Intel® C++ Compiler
Template and inheritance
asd__asdqwe
Hello, the following trivial program doesn't compile with icpc, but it's fine with g++ and clang++ :
[cpp] template< unsigned char S > class A { public: A(int a) : a(a) { } int a; }; class B : A< 's' > { public: B(int b) : A(b) { } }; [/cpp]
That explains some of the problems in http://software.intel.com/en-us/forums/topic/401384. Who is wrong, icpc, or g++ and clang++ ?
jimdempseyatthecove
How about:
class A { public: A(int _a) : a(_a) { } int a; };
Jim Dempsey
asd__asdqwe
Hello Jim,
I don't see how that would change the outcome of the compilation (and in fact, it doesn't). The problem comes from "error: argument list for class template "A" is missing B(int b) : A(b) { }", but of course the argument of the class template "A" should (IMO) be inferred from the definition of class B. Hence I think icpc is wrong, and clang++ and g++ are right, but maybe this is not the case.
Changing the constructor of B to B(int b) : A<'s'>(b) { }, makes the file compilable, but it shouldn't be necessary to redefine the template argument again, right ?
JenniferJ
I do not see this issue with the 14.0 beta update 1. You can still download the beta update1. See this thread about the beta.
Jennifer
asd__asdqwe
Ok thanks, I was indeed using icpc 13.1. Hopefully this will also fix compilation issues with g++ 4.8.1 headers, in the meantime, back to g++.
SergeyKostrov
Valued Contributor II
>>...I do not see this issue with the 14.0 beta update 1... Did you create an instance of class B? it is reproducible even with older version of Intel C++ compiler:: ..\Tests>icl.exe /MD Test33.cpp Intel(R) C++ Compiler XE for applications running on IA-32, Version 12.1.7.371 Build 20120928 Copyright (C) 1985-2012 Intel Corporation. All rights reserved. Test33.cpp Test33.cpp(22): error: no default constructor exists for class "B" B b; ^ compilation aborted for Test33.cpp (code 2) What error did you have? Was it with 32-bit or 64-bit compiler? Test case is attached.
SergeyKostrov
Attached is a modified test cases and take a look. Once again, please post a compilation error you had. Take into account that different C++ compilers do a different processing when it comes to templates. For example, GCC-like compilers detect errors in templates even if there no an instance declared. Intel, Microsoft, Borland and Turbo C++ compilers do not detect errors in templates if there is no declared instance of some template class. Outputs are as follows: [ Compilation ] Intel(R) C++ Compiler XE for applications running on IA-32, Version 12.1.7.371 Build 20120928 Copyright (C) 1985-2012 Intel Corporation. All rights reserved. Test33.cpp Microsoft (R) Incremental Linker Version 8.00.50727.762 Copyright (C) Microsoft Corporation. All rights reserved. -out:Test33.exe Test33.obj [ Runtime ] ..\Tests>Test33.exe a1.a: 3 b1.a: 5 b2.a: 7
SergeyKostrov
Sorry, I forgot to attach a new version of Test33.cpp file. Here it is.
SergeyKostrov
This is a short follow up. >>...Who is wrong, icpc, or g++ and clang++? Please post compilation outputs for all these three compilers using initial test case ( from the 1st post ) and my latest test Test33.cpp ( see previous post ). Thanks.
asd__asdqwe
Hello Sergey,
Your initial test case obviously won't compile with any of the compilers, since there is no default constructor for class B, and you have a line with "B b;", which implies a call to the default constructor.
Your last test case doesn't compile with icpc 13.1, but as Jennifer said, it should be fixed in 14.0. The error is still the same with icpc, "error: argument list for class template "A" is missing"
SergeyKostrov
>>...Your last test case doesn't compile with icpc 13.1, but as Jennifer said, it should be fixed in 14.0. The error is still the same >>with icpc, "error: argument list for class template "A" is missing"... Thanks and I will do additional verification with version 13.x for Windows.
SergeyKostrov
Here are results of verification of your initial test-case with a legacy Borland C++ compiler: ... ..\Tests>bcc32.exe Test033b.cpp Borland C++ 5.5.1 for Win32 Copyright (c) 1993, 2000 Borland Test033b.cpp: Error E2102 Test033b.cpp 17: Cannot use template 'A' without specifying specialization parameters in function B::B(int) Error E2272 Test033b.cpp 17: Identifier expected in function B::B(int) Error E2251 Test033b.cpp 17: Cannot find default constructor to initialize base class 'A<115>' in function B::B(int) ... *** 3 errors in Compile *** >>...doesn't compile with icpc, but it's fine with g++ and clang++ >>... >>...Who is wrong, icpc, or g++ and clang++ ? So, g++ and clang++ C++ compilers deviated from the C++ standard and by some unknown reason supported Non Standard features ( declarations ). I consider Borland C++ compiler as a Supreme Verificator of fundamental C++ features and compliance / compatibility to 2000-year-like C++ standard(s).
asd__asdqwe
Source for stating that "g++ and clang++ are deviated from the C++ standard" for that example, please ?
"Cannot use template 'A' without specifying specialization parameters in function B::B(int)" <= well, that's the problem, the specialization parameter for 'A' is specified by the defintion of 'B' !
I attached an example for which I'm curious as to what Borland says about it. The intel compiler error says:
intel.cpp(16): error: "A" is not a nonstatic data member or base class of class "B"
          B(int b) : A< 'd' >(b) { }
meaning that the compiler knows that the specialization parameter is not 'd'.
asd__asdqwe
Casey
GCC does support exntensions to the published standards and those extensions are listed in the GCC documentation.  The extensions are enabled by default but you can control thier inclusion with the -std= flag.  Legal options (in gcc 4.7.3) include c89,c90,c99,gnu89,gnu90,gnu99,c++98,c++0x,gnu++98,gnu++0x.  The default standard for C code is gnu89 and for C++ code gnu++98 so by default the compiler will accept certain extensions to the standard.
Try compiling your code in g++ with -std=c++98 and see if it still compiles.  That will narrow down if the problem is in standards compliance or with the compilers implementations of the standard.
SergeyKostrov
>>...Try compiling your code in g++ with -std=c++98 and see if it still compiles... Why wouldn't you do your won verifications with as many as possible C++ compilers in order to understnand what could be possibly wrong and to help all the rest users?
asd__asdqwe
That is why I was asking for a source on the C++ standard about that specific example, not about the compiler itself, sorry if it was not clear. (btw, it also compiles with c++98)
SergeyKostrov
>>...I attached an example for which I'm curious as to what Borland says about it... ..\Tests>bcc32.exe intel.cpp Borland C++ 5.5.1 for Win32 Copyright (c) 1993, 2000 Borland intel.cpp: Error E2312 intel.cpp 16: 'A<100>' is not an unambiguous base class of 'B' in function B::B(int) Error E2251 intel.cpp 16: Cannot find default constructor to initialize base class 'A<115>' in function B::B(int) *** 2 errors in Compile *** You're Not arguing with me ( have you ever used Borland C++ compiler? ) and I see that GCC and Clang teams are trying to "undermine" some fundamental features of C++ language and, unfortunately, I can't justify such deviations. I regret to see that Intel C++ compiler team follows that wrong path. It would be nice to see additional information on why they decided to support it by default without creating additional compiler flags, like '-full-clang-compatibility' or '-full-gcc-compatibility' ( similar to an option to provide a full compatibility with Microsoft C++ compiler ). Note: Please download Borland C++ compiler version 5.5.1 for all the rest verifications on your side(s).
asd__asdqwe
intel.cpp:
Sergey, I would like to assure you that I'm not arguing with you in any way. I just want to understand the problem here. What is not clear from my side, is that you are saying that G++ and clang++ (and now icpc) are violating the C++ standards. My previous question was then to naturally ask for a "proof" of that violation, by just giving me a pointer to the standards about that specific example. Do you have such a pointer, or are you just inferring that there is a violation because the Borland compiler can't compile the example ?
Thanks a lot for your help and time.
SergeyKostrov
>>...My previous question was then to naturally ask for a "proof" of that violation, by just giving me a pointer to the standards >>about that specific example. Do you have such a pointer, or are you just inferring that there is a violation because >>the Borland compiler can't compile the example? 1. Borland C++ doesn't allow such declarations and needs explicit declarations for all cases like this one, I mean when default constructors are needed, and that is why it fails. 2. If this is a new feature of C++11 Standard, or some another C/C++ Standard, then it needs to be confirmed. Of course, Borland C++ compiler doesn't support it and it will never support. 3. My understanding is that GCC and Clang C++ compilers, and possibly all the rest modern C++ compilers, implicitly create a default constructor and that is why the test case could be successfully compiled. 4. I won't be surprised if Microsoft C++ compilers also support that feature, I mean related to your latest test case, and please do your own verifications. 5. In case of Intel C++ compiler I don't see that feature listed on: http://software.intel.com/en-us/articles/c0x-features-supported-by-intel-c-compiler. Here are a couple of advises ( please ignore them if you understand everything ): - Take a look at C++ Standards published on the Internet and released between 1990 and 2001 years, or later between 2001 and 2010 years - Try to contact developers of GCC and Clang C++ compilers with questions why they allowed to create an instance of the object in that case when a default constructor needs to be declared. If this is a part of some C/C++ Standard then this is what you need and it will explain all these compilation errors Thanks for your time.
