Intel® C++ Compiler
Support and discussions for creating C++ code that runs on platforms based on Intel® processors.
7763 Discussions
Template code compilation issue #2
de666
this code does not compile with icc11 however is valid c++
it compiles with msvc versions 7, 7.1 & 8
[cpp]#include
template struct s;
template<> struct s {};
template<> struct s : public s
struct Int : public s {};
template
void foo(const s&)
{ std::cout << "in foo(const s<" << typeid(type).name() << ">&)n"; }
int main()
  Int i;
  foo(i);  //here an error appears
  return 0;
}[/cpp]
previous discussion: http://software.intel.com/en-us/forums/showthread.php?t=70491
Judith_W_Intel
Quoting - de666
[cpp]#include
template struct s;
template
void foo(const s&)
int main()
  Int i;
  return 0;
}[/cpp]
this is the same issue as in the previous discussion (link above)
de666
ok
let's continue in the old thread
you may want to delete this one
