this code does not compile with icc11 however is valid c++
it compiles with msvc versions 7, 7.1 & 8
previous discussion: http://software.intel.com/en-us/forums/showthread.php?t=70491
[cpp]#includetemplate struct s; template<> struct s {}; template<> struct s : public s {}; struct Int : public s {}; template void foo(const s &) { std::cout << "in foo(const s<" << typeid(type).name() << ">&)n"; } int main() { Int i; foo(i); //here an error appears return 0; }[/cpp]
Quoting - de666
this is the same issue as in the previous discussion (link above)
ok
let's continue in the old thread
you may want to delete this one
