Intel® C++ Compiler
7956 Discussions
Template code compilation issue
de666
hi all
here is a code which does not compile with icc11
i think there is a bug in the compiler
#include
using std::cout;
using std::endl;
namespace tag {
struct storage {};
template struct expression {};
}//namespace tag
template
struct tag_complexity { enum { value = 0 }; };
template
struct tag_complexity<:EXPRESSION> > { enum { value = c }; };
struct general {};
struct shapeX {};
template
struct expression : public expression::value>, general>
template
struct expression
struct too : public expression
struct gives : public expression
template
void foo(const expression &a)
{ cout << "foo reports\n " << typeid(a).name() << "\n\n"; return; }
template struct subexpression;
template
struct subexpression > :
public expression >,
tag::expression::value>,
shape
subexpression(const expr_t&) {}
template inline
subexpression >
bar(const expression &a)
cout << "bar reports\n " << typeid(a).name() << "\n\n";
return static_cast(a);
int main()
too trivial;
foo(trivial);
foo(bar(trivial));
gives error;
foo(error);
foo >(error);
foo(bar(error)); //comment this line in order to compile
foo(
/*icc 11.0.066 can not match an instance of bar() with 'error'
given hierarchy for 'gives' class
expression, general>
expression
gives
template arguments for bar() should be deduced at least as*/
bar(error)
);//foo(
return 0;
JenniferJ
Quoting - de666
hi all
Is it on Linux? IA32 or Intel 64 etc.
please post the full compiler version and the compile options.
Jennifer
de666
intel c++ compiler for windows* ia32 v.11.0.066
compiler options are that msvs2005 offers after project conversion (from msvc to intel project) in other words they are pretty much standard
if you need more information i try to collect and post it tomorrow
JenniferJ
Quoting - de666
I copy/pasted the code to tp.cpp and VC2005 can not compile as well. Attached the tp.cpp. could you fix it?
>>cl /Od /EHsc tp.cpp
Microsoft 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
Copyright (C) Microsoft Corporation. All rights reserved.
tp.cpp
tp.cpp(64) : error C2784: 'void foo(const expression &)' : could not deduce template argument for
'const expression &' from 'gives'
tp.cpp(32) : see declaration of 'foo'
tp.cpp(64) : error C2782: 'void foo(const expression &)' : template parameter 'tag' is ambiguous
could be 'tag::expression'
with
c=0
or 'tag::storage'
C:temp
de666
a funny thing about this piece is that it does not compile with msvc80 either...
if you comment the line "foo(error);" wich contains the error (in msvc view) it should compile
ps
i posted the same code to ms technet pointingto that very issue
JenniferJ
Quoting - de666
ps
Ok. I can see the error now.
I'll file a bug report for it. Thanks for getting a small testcase!
Jennifer
>>icl /c /EHsc /Od tp.cpp
Intel C++ Compiler Professional for applications running on IA-32, Version 11.1 Build 20091012 Package ID: w_cproc
_p_11.1.051
Copyright (C) 1985-2009 Intel Corporation. All rights reserved.
tp.cpp
tp.cpp(66): error: no instance of function template "bar" matches the argument list
argument types are: (gives)
tp.cpp(66): error: no instance of function template "foo" matches the argument list
argument types are: ()
compilation aborted for tp.cpp (code 2)
de666
thanks for your response
i would like to know if this "little" testcase really is legal since it would be a VERY convenient feature (at least for me)
ps
i attached the msvc/icc project just in case
JenniferJ
I got our engineer's response. Your code is ilegal. It's strange that VC compiles.
You should change the following code:
to:
foo(bar((expression) error)); //comment this line in order to compile
Jennifer
de666
hi there
distressingly this really is an illegal code because primary template inherits a specialization wich is incompleteat the point and unfortunately there is no way to define a specialization before the primary template
sad
however icc11 compiles that part, that is you can create an object of type derived from an incomplete typeat the point of declaration (don't bother understanding this paragraph)
the happiness was so close...
Judith_W_Intel
Here is a simpler example which compiles with cl but not icl.
template
struct expression : public expression {};
template
struct gives : public expression {};
template void bar(expression);
int main()
gives error;
bar(error);
return 0;
Actually the reason your code is illegal is because the template argument deduction rules don't distinguish between the direct and indirect base classes of "gives", so there's an ambiguity and deduction fails. The ambiguity in the example above is between expression (direct base class) and expression(indirect baseclass).FWIW, the Gnu compilergives an errortoo.
de666
yeah, continuing the investigation of this problem i came to a very simple test case
here it is
[cpp]#include
template struct s;
template<> struct s {};
template<> struct s : public s
struct Int : public s {};
template
void foo(const s&)
{ std::cout << "in foo(const s<" << typeid(type).name() << ">&)n"; }
int main()
  Int i;
  foo(i);  //here an error appears
  return 0;
}[/cpp]
i read the standard and found no things that invalidate this code
contrary the standard gives an example like
[cpp]template
struct s {};
struct a : public s {};
template
void foo(const s&) {}
int main()
  a object;
  foo(object);  //calls foo(const s&)
  return 0;
}[/cpp]
and the second thing the standard states is that while picking the best function among oveloaded versions involving conversions
- given class A, B derived from A and C derived from B
- conversion from C* to B* is better than C* to A*,
- conversion from C& to B& is better than C& to A&
which renders the following algorithm for the first piece of code:
- template arguments can obviously be void or int giving function instances
foo(const s&) and
foo(const s&)
- following the rule for overloaded functions (above)we choose the variant
foo(const s&)
because s is the direct base class for Int rather than s
i think that compilers fail to deduce arguments because there are two instances of the same template class in same hierarchy
but if there were only one all goes ok
Judith_W_Intel
Quoting - de666
here it is
[cpp]#include
template struct s;
template
void foo(const s&)
int main()
  Int i;
  return 0;
}[/cpp]
[cpp]template
struct s {};
template
int main()
  a object;
  return 0;
}[/cpp]
foo(const s&) and
foo(const s&)
foo(const s&)
The example in the standard you cited aboveis not applicable since there's only one possible deduction for what the template argument "type" is and that is int. The rules you quoted above apply to choosing between overloaded functions, not template argument deduction. The template argument deduction rules are in section 14.8.2 of the 1998 standard. I see nothing in there that favors a deduction to a direct base class over an indirect base class.
Your last sentence is exactly correct and is what I tried tosay was theprobleminmy earlier note. Choosing between the two instances are ambiguous and that is why template argument deduction (not overloading)fails. The Microsoft compiler is not following the standard.
de666
afaik template functions take part in overload resolution
it is said in the standard before the rules i cited that a set of viable functions is built and an instance of a template function can be a viable function if the template arguments can be deduced
in this case arguments can be deduced in two ways and both instances go to the set of viable functions
then the mentiioned rule applies and function taking reference to the most derived class wins
furthermore all this reasoning is not counterintuitive and a user encountering a pattern like the one above expects just what i described
Judith_W_Intel
Quoting - de666
As explained in the Microsoft documentation here:
http://msdn.microsoft.com/en-us/library/s016dfe8.aspx
Note that it says that if template argument deduction fails then the potential specializations resulting fromthe deduction of that function templateare not added to the overload resolution set of viable functions.
I'm not going to argue that this behaviour might be non-intuitive. If you feel strongly about it you should probably submit an issue to the C++ standards committee.
Judy
de666
you are absolutely right in that part about deduction fail and further consequences
i even won't try to argue about it
my question is: why does the template argument deduction fail?
because the template arguments in the lastcode pieceare obviously either void or int
at least it must be int because s is the direct base class of class a
de666
i see the forum has been modified and i'm afraid this thread is lost
so iremind you and --are we going to get at the heart of the matter?
