here is a code which does not compile with icc11
i think there is a bug in the compiler
#include
using std::cout;
using std::endl;
namespace tag {
struct storage {};
template
}//namespace tag
template
struct tag_complexity { enum { value = 0 }; };
template
struct tag_complexity<:EXPRESSION>
struct general {};
struct shapeX {};
template
struct expression : public expression
template
struct expression
struct too : public expression
struct gives : public expression
template
void foo(const expression
{ cout << "foo reports\n " << typeid(a).name() << "\n\n"; return; }
template
template
struct subexpression
public expression
tag::expression
shape
subexpression(const expr_t&) {}
template
subexpression
bar(const expression
cout << "bar reports\n " << typeid(a).name() << "\n\n";
return static_cast
int main()
too trivial;
foo(trivial);
foo(bar(trivial));
gives error;
foo(error);
foo
foo(bar(error)); //comment this line in order to compile
foo(
/*icc 11.0.066 can not match an instance of bar() with 'error'
given hierarchy for 'gives' class
expression
expression
gives
template arguments for bar() should be deduced at least as*/
bar
);//foo(
return 0;
please post the full compiler version and the compile options.
Jennifer
compiler options are that msvs2005 offers after project conversion (from msvc to intel project) in other words they are pretty much standard
if you need more information i try to collect and post it tomorrow
I copy/pasted the code to tp.cpp and VC2005 can not compile as well. Attached the tp.cpp. could you fix it?
>>cl /Od /EHsc tp.cpp
Microsoft 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
Copyright (C) Microsoft Corporation. All rights reserved.
tp.cpp
tp.cpp(64) : error C2784: 'void foo(const expression
'const expression
tp.cpp(32) : see declaration of 'foo'
'const expression
tp.cpp(64) : error C2782: 'void foo(const expression
could be 'tag::expression
with
c=0
or 'tag::storage'
C:temp
a funny thing about this piece is that it does not compile with msvc80 either...
if you comment the line "foo(error);" wich contains the error (in msvc view) it should compile
ps
i posted the same code to ms technet pointingto that very issue
ps
Ok. I can see the error now.
I'll file a bug report for it. Thanks for getting a small testcase!
Jennifer
>>icl /c /EHsc /Od tp.cpp
Intel C++ Compiler Professional for applications running on IA-32, Version 11.1 Build 20091012 Package ID: w_cproc
_p_11.1.051
Copyright (C) 1985-2009 Intel Corporation. All rights reserved.tp.cpp
tp.cpp(66): error: no instance of function template "bar" matches the argument list
argument types are: (gives)
^tp.cpp(66): error: no instance of function template "foo" matches the argument list
argument types are: ()
^compilation aborted for tp.cpp (code 2)
I got our engineer's response. Your code is ilegal. It's strange that VC compiles.
You should change the following code:
to:
foo(bar((expression) error)); //comment this line in order to compile
Jennifer
distressingly this really is an illegal code because primary template inherits a specialization wich is incompleteat the point and unfortunately there is no way to define a specialization before the primary template
sad
however icc11 compiles that part, that is you can create an object of type derived from an incomplete typeat the point of declaration (don't bother understanding this paragraph)
the happiness was so close...
Here is a simpler example which compiles with cl but not icl.
template
template
struct expression
template
int main()
gives error;
bar(error);
return 0;
here it is
[cpp]#includei read the standard and found no things that invalidate this codetemplate struct s; template<> struct s {}; template<> struct s : public s {}; struct Int : public s {}; template void foo(const s &) { std::cout << "in foo(const s<" << typeid(type).name() << ">&)n"; } int main() { Int i; foo(i); //here an error appears return 0; }[/cpp]
contrary the standard gives an example like
[cpp]templatestruct s {}; struct a : public s {}; template void foo(const s &) {} int main() { a object; foo(object); //calls foo (const s &) return 0; }[/cpp]
- given class A, B derived from A and C derived from B
- conversion from C* to B* is better than C* to A*,
- conversion from C& to B& is better than C& to A&
which renders the following algorithm for the first piece of code:
- template arguments can obviously be void or int giving function instances
foo
foo
- following the rule for overloaded functions (above)we choose the variant
foo
because s
i think that compilers fail to deduce arguments because there are two instances of the same template class in same hierarchy
but if there were only one all goes ok
here it is
foo
foo
foo
because s
The example in the standard you cited aboveis not applicable since there's only one possible deduction for what the template argument "type" is and that is int. The rules you quoted above apply to choosing between overloaded functions, not template argument deduction. The template argument deduction rules are in section 14.8.2 of the 1998 standard. I see nothing in there that favors a deduction to a direct base class over an indirect base class.
Your last sentence is exactly correct and is what I tried tosay was theprobleminmy earlier note. Choosing between the two instances are ambiguous and that is why template argument deduction (not overloading)fails. The Microsoft compiler is not following the standard.
afaik template functions take part in overload resolution
it is said in the standard before the rules i cited that a set of viable functions is built and an instance of a template function can be a viable function if the template arguments can be deduced
in this case arguments can be deduced in two ways and both instances go to the set of viable functions
then the mentiioned rule applies and function taking reference to the most derived class wins
furthermore all this reasoning is not counterintuitive and a user encountering a pattern like the one above expects just what i described
As explained in the Microsoft documentation here:
http://msdn.microsoft.com/en-us/library/s016dfe8.aspx
Note that it says that if template argument deduction fails then the potential specializations resulting fromthe deduction of that function templateare not added to the overload resolution set of viable functions.
I'm not going to argue that this behaviour might be non-intuitive. If you feel strongly about it you should probably submit an issue to the C++ standards committee.
Judy
i even won't try to argue about it
my question is: why does the template argument deduction fail?
because the template arguments in the lastcode pieceare obviously either void or int
at least it must be int because s
i see the forum has been modified and i'm afraid this thread is lost
so iremind you and --are we going to get at the heart of the matter?
