Community
cancel
Showing results for
Search instead for
Did you mean:
Pavel_J_
Templated user-defined type conversion to abstract reference type
I have the following (very simplified) "container" class to store objects of "any" type in shared pointers:
class container
     public:
        template<typename T> container(const boost::shared_ptr<T> &rhs)
        : m_content(rhs) { }
        operator T const & () const
            return get<T>();
        T const & get() const
            return *boost::any_cast< boost::shared_ptr<T> >(m_content);
        private:
            boost::any m_content;
If I store an object of some type in the container, I would like to get the reference simply by a user-defined conversion which would allow to do something like this:
boost::shared_ptr<some_type> x(new some_type);
container c_x = x;
// Two methods of getting the reference to the instance stored
// in c_x are possible:
// 1) using a user-defined conversion:
const some_type &y = c_x;
// 2) using a const-reference using a "getter":
const some_type &y = c_x.get<some_type>();
Of course, the first approach is preferred by me as it is much simpler. Sometimes, I need to store objects derived from some abstract type and do the same sort of type conversion to the reference of this abstract type, for example, like this:
boost::shared_ptr<some_abstract_type> x(new some_derived_type);
container c_x = x;
// Obtain the reference to the abstract type:
const some_abstract_type &y = c_x;
const some_abstract_type &y = c_x.get<some_abstract_type>();
Now the problem arises with the Intel compiler (I use the version 13.1). Both approaches (1) and (2) work fine with GCC. However, the Intel compiler seems to have a problem with using the defined type conversion when the template type is abstract.
For example, the following code works fine with GCC but fails with Intel:
#include <iostream>
#include <boost/any.hpp>
#include <boost/shared_ptr.hpp>
class container
    public:
            return get<T>();
    private:
class base
    public:
        virtual ~base() { }
        virtual void f() const = 0;
class derived : public base
    public:
        virtual ~derived() { }
        virtual void f() const { std::cout << "hello\n"; }
void foo(const container &c)
    const base & a = c;
    a.f();
int main()
    boost::shared_ptr<base> a(new derived);
    container c = a;
    foo(c);
With Intel, I get this error:
    test.cpp(44): error: no suitable user-defined conversion from "const container" to "const base" exists
          const base & a = c;
    compilation aborted for test.cpp (code 2)
On the other hand, if I replace "base" with "derived" in both "main()" and "foo()" (or use the reference "getter" instead of the type conversion in "foo()"), everything works fine with Intel too. Is it possible to convince the compiler to use the user-defined type conversion to the reference type when T is an abstract class? Am I doing something wrong or is this a missing feature (a bug?) in the Intel C++ compiler?
Interestingly, the conversion to the const pointer is not a problem. If I add
operator T const * () const
    return &get<T>();
to the "container" class and replace "foo()" with
    const base * a = c;
    a->f();
then the code works also with Intel.
Thanks in advance for any feedback.
Judith_W_Intel
This looks like an Intel compiler bug to me (both Microsoft and GNU accept the small example below but Intel does not):
struct container
   template<typename T> operator T const & () const;
struct base
#ifdef OK
   virtual void f();
#else
   virtual void f() = 0; // causes conversion error
#endif
  const base& a = c;
int main()
  container c;
  foo(c);
  return 0;
I have entered this in our bug tracking system as DPD200254930. Thanks for reporting it to us. A possible workaround is making the pure virtual function base:;f() a non pure virtual function.
Judy
