Here is some program.
It was compiled with three compilers.
BOOST Version: 1_34
--- HP-UX, aCC ---
aCC: HP C/aC++ B3910B A.06.15 [May 16 2007]
> aCC +DD64 -AA -I/adjhome/ip/ccadj/ccadj/BOOST/boost_1_34_0 prog1.cpp
// No errors
--- AIX, xlC ---
IBM XL C/C++ Enterprise Edition V8.0 for AIX
xlC_r -q64 -qwarn64 -I/usr/local64/boost_1_34_0 prog1.cpp
// No errors
--- Linux, icpc ---
Intel C++ Intel 64 Compiler Professional for applications running on Intel 64, Version 11.0
> icpc -I/adjhome/adj/ccadj/ccadj/BOOST/boost_1_34_0 prog1.cpp
prog1.cpp(47): error: expected an expression
v.push_back (t.get());
prog1.cpp(62): error: expected an expression
v.push_back (t.get<0>());
detected during instantiation of "std::vector<:TUPLES::ELEMENT><0, T>::type, std::allocator<:TUPLES::ELEMENT><0, T>::type>> Foo::tuple2vector(const T &) [with T=boost::tuples::tuple, I=1UL]" at line 80
compilation aborted for prog1.cpp (code 2)
Something is wrong?
Alex Vinokur
========= prog1.cpp =========
#include
#include
#include
#include
#include
#include
template<:SIZE_T n=""> struct uniform_tuple;
template
struct uniform_tuple<1,T>
typedef typename boost::tuple type;
template
struct uniform_tuple<2,T>
template
struct uniform_tuple<3,T>
template
struct uniform_tuple<4,T>
template
class Foo
BOOST_STATIC_ASSERT (I < boost::tuples::length::value);
public:
typedef typename boost::tuples::element<0,T>::type LocalType;
static std::vector tuple2vector (const T& t)
std::vector v = Foo::tuple2vector(t);
return v;
template
class Foo
public:
std::vector v;
return v;
template
class DoIt : public Foo::value - 1>
int main(void)
typedef uniform_tuple<2, int>::type Tuple2;
std::vector v;
v = DoIt::tuple2vector(boost::tuples::make_tuple (100, 200));
for (std::size_t i = 0; i < v.size(); i++)
std::cout << v << " ";
std::cout << std::endl;
return 0;
BOOST Version: 1_34
--- HP-UX, aCC ---
// No errors
--- AIX, xlC ---
// No errors
--- Linux, icpc ---
Something is wrong?
Alex Vinokur
#include
#include
#include
#include
#include
#include
template
template
template
template
template
class Foo
public:
static std::vector
std::vector
return v;
template
class Foo
public:
static std::vector
std::vector
return v;
template
int main(void)
std::vector
v = DoIt
return 0;
what version of icc are you using? The output shows 11.0. But which package?
I tried only on Windows so far, it can be compiled fine with 11.0.074 or 11.1 or Parallel Composer.
Jennifer
Jennifer
Quoting - Jennifer Jiang (Intel)
Jennifer
Jennifer
1. > icpc -V
Intel C++ Intel 64 Compiler Professional for applications running on Intel 64, Version 11.0 Build 20090318 Package ID: l_cproc_p_11.0.083
Copyright (C) 1985-2009 Intel Corporation. All rights reserved.
By the way, is it possible to get Intel Compiler package within C/C++ program?
Neither __INTEL_COMPILER, nor __INTEL_COMPILER_BUILD_DATE contain package number.
2. The question answered in http://groups.google.com/group/comp.lang.c++/msg/0f91ee0ecf02d640 :
Use v.push_back (t.template get()); instead of v.push_back (t.get());
Quoting - alexvi
From our compiler engineer the code "v.push_back(t.get());" is not correct according to C++ standard. It's why our compiler gives error. So this is not a compiler bug.
Thanks!
Jennifer
