Live example: https://godbolt.org/z/TqM35b
Env.: macOS 10.15.7, ICC 2021.1 Beta 20201112
The following example compiles without error, but the internalCheck function doesn't depend on one of the template parameters, so we should get a compile-time error (according to the https://eel.is/c++draft/temp.res#general-10)
template<typename Context,
typename Protocol>
auto createSocket(Context& context, const Protocol& protocol) -> auto
using Socket = typename Protocol::Socket;
internalCheck();
return Socket { context, protocol };
Our Developer said: "This is not really a bug; but perhaps a compatibility/usability issue (Microsoft doesn't emit error)"
The C++ standard does not require a compiler to give diagnostics on a template that has not been used/instantiated.
From the standard: This is a quality of implementation issue, it is ill-formed but if it is not instantiated no diagnostic is required as per [temp.res#8.1]p:
The validity of a template may be checked prior to any instantiation. [ Note: Knowing which names are type names allows the syntax of every template to be checked in this way. — end note ] The program is ill-formed, no diagnostic required, if:
no valid specialization can be generated for a template or a substatement of a constexpr if statement within a template and the template is not instantiated.
Thanks for reporting this bug. I have escalated this to the concerned team for a fix.
Rahul
Thank you for reporting this issue. I've filed a bug with our compiler Developer.
We are closing the thread as the issue has been resolved and we will no longer respond to this thread. If you require additional assistance from Intel, please start a new thread. Any further interaction in this thread will be considered community only.
